Solderer Posted December 3, 2019 Author Report Posted December 3, 2019 Извињавам се, упао је цитат Лазаровог поста неочекивано, а не знам како да га едитујем, тј. уклоним. Quote
Solderer Posted December 12, 2019 Author Report Posted December 12, 2019 Решио сам да употребим плочице за Парадајз фоно које сам које сам наручио да се израде код конеске фирме. Вендета ми је тренутно на стендбају. Овог пута ћу направити и шант регулатор који је на плочици уместо Јунг-Диден регулатора које тренутно користим. Остало је само стриктно упаривање улазних транзистора. Quote
sondek Posted December 12, 2019 Report Posted December 12, 2019 (edited) https://pinkfishmedia.net/forum/threads/paradise-phono-stage-fully-built-or-boards.234960/ Edited December 12, 2019 by sondek Quote
Krca44 Posted December 12, 2019 Report Posted December 12, 2019 Bilo je samo pitanje vremena i zainteresovanosti konzumenata da se pojave pcb na trzistu. Uostalom evo sta kaze prodavac : " Hi. For Sale a complete kit of PCB to build the Paradise Phono. Kit includes 2 paradise phone pcb (one per channel), the pre-reg power supply with CLC pre-filter and the CRC capacitor filter banks. This is my own pcb design based on the official Paradise design. I know it works because I built it! The Pre-reg pcb contains the dual transformers, dual discrete rectifiers and clc filter (one for both channel), then this raw +/- voltage goes to the CRC filter pcb, and then to each Paradise pcb. The Paradise pcb has built-in fancy discrete shunt regulator. Check my own phono preamp built. Kit will comes with schematics and detailled BOM. Take note that you need to match a lot of transistors for the Paradise and this kit is not for beginners. Total 85U$, set of 4 pcb with complete schematics and BOM... Send me an email if interested... " "akcija" traje do Petka... nije covek nastancovao dovoljno https://www.diyaudio.com/forums/swap-meet/346153-fs-paradise-phono-pcb-set.html Quote
Majda Posted December 13, 2019 Report Posted December 13, 2019 On 12/12/2019 at 1:31 PM, Solderer said: Овог пута ћу направити и шант регулатор који је на плочици уместо Јунг-Диден регулатора које тренутно користим. Nema potrebe da izbacujes JungDiden regulator koji je vec napravljen i radi Upotrebi ga pre Shunt napajanja kao pre-regulator ali podesi malo vece napone (za pad napona do shunt kola oko 4-5V vise) i ako ima ograncavac sturje podesi na +120% ukupne potrosnje. Nista nece da smeta prereguator ispred shunta - tacnije i neophodan je... A ako se na preregulatoru doda postepeni rast napona recimo oko 1sec onda nece biti ni klikova pri ukljucenju i iskljucenju. Sve ovo sto pisem - provereno u praksi. happy building Quote
Solderer Posted December 13, 2019 Author Report Posted December 13, 2019 Хвала на савету. Ја имам у употреби ово предпојачало са плочицама које сам ја направио, али сам ту изоставио шант регулатор који је у оргиналу, и користим га са Јунг-Диден регулатором, и то бих оставио тако.. Није ми се тај шант концепцијски допао.Ову нову верзију ћу испробати онако како је предвиђено, са шантом, а касније могу да пробам и пре-регулатор. Имам и неколико урађених Борбели Супер Шант регулатора са оргиналним фетовима. Можда ћу касније направити и ту верзију, али тада морам да одсецам са ПЦБ-а шант део јер је Борбели мало већих димензија. На Мацурином фоно пред. Борбели се је одлично показао. И Јунгов регулатор и Борбели имају РЦ филтер на референтној диоди ( ЛМ329) тако да то спречава било какве кликове при укључењу. И ово је проверено у пракси. Quote
Solderer Posted December 13, 2019 Author Report Posted December 13, 2019 1 sat ranije, Majda said: Nema potrebe da izbacujes JungDiden regulator koji je vec napravljen i radi Upotrebi ga pre Shunt napajanja kao pre-regulator ali podesi malo vece napone (za pad napona do shunt kola oko 4-5V vise) i ako ima ograncavac sturje podesi na +120% ukupne potrosnje. Nista nece da smeta prereguator ispred shunta - tacnije i neophodan je... A ako se na preregulatoru doda postepeni rast napona recimo oko 1sec onda nece biti ni klikova pri ukljucenju i iskljucenju. Sve ovo sto pisem - provereno u praksi. happy building Заборавио сам да цитирам у вези задњег поста. Quote
Solderer Posted December 18, 2019 Author Report Posted December 18, 2019 Ово је Парадајз фоно са шант регулаторима. Ја сам у мојој првој верзији уградио Јунг-Диден регулаторе који су веома цењени. Након првих тестова могу рећи да неке разлике и нема, оба раде изванредно. Quote
giZ_Mo Posted December 18, 2019 Report Posted December 18, 2019 Oд кога су плочице набављене, јел од ових? https://forum.polkaudio.com/discussion/149397/paradise-phono-pre https://www.rstaudio.de/en/paradise-r3-2/ Quote
Solderer Posted December 18, 2019 Author Report Posted December 18, 2019 Хвала колегама који су похвалили овај мој рад. 59 minuta ranije, giZ_Mo said: Oд кога су плочице набављене, јел од ових? https://forum.polkaudio.com/discussion/149397/paradise-phono-pre https://www.rstaudio.de/en/paradise-r3-2/ Већ сам раније у овој теми приказао плочице које су на основу моје документације израђене код кинеске фирме. Њихов аутор је један мој руски колега који је на њима унео и пар побољшања у односу на првобитне, пре свега у бољем вођењу масе. Quote
Krca44 Posted February 9, 2020 Report Posted February 9, 2020 Trenutno stanje... elektronika gotova, donja pcb ce se mozda rotirati posto je knap, ostalo kutijanje. Quote
Majda Posted February 9, 2020 Report Posted February 9, 2020 Hajde @Krca44 pakuj to pa da slusamo Quote
Krca44 Posted February 9, 2020 Report Posted February 9, 2020 3 hours ago, Majda said: pakuj to pa da slusamo Moram da nacrtam tehnicki crtez otvora na zadnjoj strani u Corel-u a nisam radio u njemu 15 godina. Da je papir u pitanju uradio bih za 15 min i poslao majstoru. Racunam da ce to i ostalo da mi uzme naredni mesec pa da ce moci da se slusa. Quote
Ajduk Posted February 9, 2020 Report Posted February 9, 2020 Koliko su kompleksni ti otvori kad treba tehnicki crtez? I ako nije tajna koji je majstor u pitanju? Ja cak i kada sam nosio na cnc obradu bilo je dovoljno nacrtati osnovne mere, cisto da covek razume sta treba da se odradi (ja sam radio u ilustratoru). Quote
ab Posted February 9, 2020 Report Posted February 9, 2020 Ако си носио за ЦНЦ сечење онда знаш да је потребан векторски цртеж. Где си ти носио? Ако ти је он и радио припрему за сечење онда је то друга ствар. Quote
ab Posted February 9, 2020 Report Posted February 9, 2020 16 sati ranije, Krca44 said: Trenutno stanje... elektronika gotova, donja pcb ce se mozda rotirati posto je knap, ostalo kutijanje. Можеш и једну поред друге (ПЦБ) у том случају доњу хоризонтално или вертикално како се боље уклопи, ако трафо иде скроз у ћошак. Одакле је кућиште? Quote
Krca44 Posted February 9, 2020 Report Posted February 9, 2020 50 minutes ago, ab said: Одакле је кућиште? Italijansko Hifi2000 Galaxy, kupljeno od kolege. Razmatrao sam da stavim pcb jednu pored druge, onda mi dolazna AC i odlazna AC na pcb idu blizu jedna druge ( do trafoa od trafoa ako je on u cosku ovom )... verovatno cu donju stabilizatorsku pcb samo rotirati na levo za 90 stepeni. Nekako mi se cini da je to optimalno resenje, trafo je udaljen od phono pcb ( gore na slici ), sekundari do stabilizacije su kratki, potom DC napon sa stabilizacije do phono je kratak. Na phono pcb pored DC ulaza su levo signal out, mislim da je ovaj polozaj prihvatljiv. Svakako cu pre busenja rupa na donjoj ploci jos jednom probati raspored. Quote
Krca44 Posted February 9, 2020 Report Posted February 9, 2020 (edited) 1 hour ago, Ajduk said: Koliko su kompleksni ti otvori kad treba tehnicki crtez? I ako nije tajna koji je majstor u pitanju? Izvinjavam se nisam odmah video, nije tajna. Milan http://www.petmk.co.rs/proizvodi.php Ja sam pitao da li moze, covek kaze moze, crtez u Corel-u. Eto to je, meni je najlakse da nacrtam na papiru i dam majstoru koji hoce da uradi, samo treba da ga nadjem... mozda i potrazim jos, koliko znam mashinama sada upravljaju racunari pa zato se traze crtezi u Corelu i xxxCAD-u... ako ne uradim ja onda mora majstor da radi na racunaru ( mislim moze i bez racunara ko ima stare makine ). Ovo je lagana opcija da tako kazem, posaljem svoju zadnju plocu i crteze i dobijem nazad uradjeno profi. P.S. Ako znas nekog kome mogu odneti crtez molim te javi. Hvala Edited February 9, 2020 by Krca44 Quote
zflazar Posted February 9, 2020 Report Posted February 9, 2020 Off topic ali da pitam ovde: da li imate preporuku za strugara koji bi na kvalitetnom duraluminijumu mogao da napravi dugmiće za potenciometre i nogice za pojačalo a da ne košta bubreg? crtež u Corelu se podrazumeva Quote
zek Posted February 9, 2020 Report Posted February 9, 2020 39 minuta ranije, zflazar said: Off topic ali da pitam ovde: da li imate preporuku za strugara koji bi na kvalitetnom duraluminijumu mogao da napravi dugmiće za potenciometre i nogice za pojačalo a da ne košta bubreg? Bio svojevremeno neki momak iz SU na KP sa gomilom lepih srebrnih i crnih dugmića i nogica, ali sada ne mogu da nađem link. Quote
