somilenko Posted April 10, 2021 Report Posted April 10, 2021 Kad pre ode na 750E bio 500 do skoro Bluesound node 2i je 500 i to je strimer sa DAC-om, Bluesound powernode 2i je allin one, ima i pojačalo snage, on je 750 e.@microfarad Sa 2 x 60 W u D klasi, nebi trebalo da je mnogo probirljiv sa zvučnicima...Sent from my ONEPLUS A6003 using Tapatalk Quote
Thecoki Posted April 10, 2021 Report Posted April 10, 2021 16 minutes ago, SUROKVL said: Kad pre ode na 750E bio 500 do skoro 500 je samo Node(stimer-dac) Pover Node ima ima pojacalo u sebi 60w Quote
Dragan Penev Posted April 10, 2021 Author Report Posted April 10, 2021 @Zvukoljubne treba pojačalo. U stvari, sve imam sada. Samo gledam eventualno u nekoj budućnosti da malo uprostim sistem. Ako bih išao na tu varijantu, onda DAC/streamer uređaj dolazi u obzir. Quote
SUROKVL Posted April 10, 2021 Report Posted April 10, 2021 2 sati ranije, somilenko said: Bluesound node 2i je 500 i to je strimer sa DAC-om, Bluesound powernode 2i je allin one, ima i pojačalo snage, on je 750 e.@microfarad Sa 2 x 60 W u D klasi, nebi trebalo da je mnogo probirljiv sa zvučnicima... Sent from my ONEPLUS A6003 using Tapatalk Nisam obratio pažnju sobzirom da pokretač teme traži strimer, bez pojačala, pretpostavljam Quote
Thecoki Posted April 10, 2021 Report Posted April 10, 2021 https://www.cambridgeaudio.com/row/en/products/hi-fi/cx-series-2/cxn Quote
somilenko Posted April 10, 2021 Report Posted April 10, 2021 Nisam obratio pažnju sobzirom da pokretač teme traži strimer, bez pojačala, pretpostavljam Reče na početku All in one, ali si u pravu, posle u istom postu je naveo DAC sa strimerom (što nije all in one)...Sent from my ONEPLUS A6003 using Tapatalk Quote
Thecoki Posted April 10, 2021 Report Posted April 10, 2021 32 minutes ago, somilenko said: Reče na početku All in one, ali si u pravu, posle u istom postu je naveo DAC sa strimerom (što nije all in one)... Sent from my ONEPLUS A6003 using Tapatalk Ko zna sta de biti na kraju?(Ford) Quote
somilenko Posted April 10, 2021 Report Posted April 10, 2021 Evo ovo, ima i navigaciju, da znaš gde živiš... A imaš i backup ako otkaže u kolima. Dobija se i jelkica uz svaki primerak...Sent from my ONEPLUS A6003 using Tapatalk Quote
SUROKVL Posted April 10, 2021 Report Posted April 10, 2021 10 minuta ranije, Thecoki said: Ko zna sta de biti na kraju?(Ford) Na kraju će da bude THE END Quote
Ljuba Posted April 10, 2021 Report Posted April 10, 2021 4 minuta ranije, somilenko said: Evo ovo, ima i navigaciju, da znaš gde živiš... A imaš i backup ako otkaže u kolima. Dobija se i jelkica uz svaki primerak... Sent from my ONEPLUS A6003 using Tapatalk To već ima. Quote
somilenko Posted April 10, 2021 Report Posted April 10, 2021 Kod Forda nikada nije loše imati još jedan.Sent from my ONEPLUS A6003 using Tapatalk Quote
Zvukoljub Posted April 10, 2021 Report Posted April 10, 2021 3 hours ago, Dragan Penev said: @Zvukoljubne treba pojačalo. U stvari, sve imam sada. Samo gledam eventualno u nekoj budućnosti da malo uprostim sistem. Ako bih išao na tu varijantu, onda DAC/streamer uređaj dolazi u obzir. Do te eventualne budućnosti modeli će se verovatno promeniti, pa onda nema mnogo smisla pričati o tome sada. Ali ako bi uzimao sada, preporučio bih Bluesound Node ili EC Rena, ako je budžet još tanji onda Yamahu WXC. Denon i Pioneer su ranije imali solidne sprave u toj pristupačnoj cenovnoj klasi, ali ne znam šta se u međuvremenu dešavalo. 1 hour ago, somilenko said: Kod Forda nikada nije loše imati još jedan. Sent from my ONEPLUS A6003 using Tapatalk Aj nek neko drugi banuje somilenka, da ne ispadne ja pristrasan... kao što nisam... uopšte Quote
microfarad Posted April 10, 2021 Report Posted April 10, 2021 4 sati ranije, somilenko said: Sa 2 x 60 W u D klasi, nebi trebalo da je mnogo probirljiv sa zvučnicima... Sent from my ONEPLUS A6003 using Tapatalk Da powernode2i je u pitanju. Tih 60w racunaj kao 20 u ab klasi. Uredjaj bio kod mene, jedino dobro radio sa mojim Tannoy koje moze SET trioda od 5w da tera. Sa kef LS50 se posteno obrukao. Ne mojte da verujete proizvodjacima ocigledno nisu bas iskreni. Evo samo jedan primer, moj bivsi pojacavac McIntosh MA 8000 po specifikaciji 300w, realno ni 100w!!!! Quote
somilenko Posted April 10, 2021 Report Posted April 10, 2021 Koliko JD ga testira upravo sa LS50, njega nebi nazvao baš šalabajzerom i btw, D klasa ne znači nekvalitetnija snaga, čak šta više...U svakom slučaju ga ne treba kupovati bez probe, pogotovo ako se kupuje novo...Sent from my ONEPLUS A6003 using Tapatalk Quote
robespierre Posted April 10, 2021 Report Posted April 10, 2021 @zflazar @Delija u pravu ste - 120 ima Air, ali to bi Draganu zavrsavalo posao obzirom da muziku pusta sa racunara (koliko skapirah iz teme o sistemu), a ima i gramofon, te zbog toga predlozih Devialet. No, obzirom na ogranicen budzet, ovo onda svakako nije opcija.. Quote
Dragan Penev Posted April 11, 2021 Author Report Posted April 11, 2021 Čuvajte se Ljube, čim on nešto napiše, pazite se dobro. Quote
Dragan Penev Posted April 12, 2021 Author Report Posted April 12, 2021 Stigla nova spravica za igru. Aiyima Tube T3 preamp. Naručen direktno na sajtu, stiglo iz Holandije za meseca dana. Free delivery, carina ništa. 52 dolara. Povezao kao preamp za gramofon. Sasvim lepo i korektno. Inače, kupljeno po no preporuci gospodina koji radi RAAL ribone. Čovek koristi to već neko vreme u svom veoma ozbiljnom sistemu. Quote
patason Posted April 12, 2021 Report Posted April 12, 2021 Aca ribon koristi phono kome su lampe osvetljene plavom led diodom? Quote
Golum Posted April 12, 2021 Report Posted April 12, 2021 1 sat ranije, patason said: Aca ribon koristi phono kome su lampe osvetljene plavom led diodom? Ma cini ti se da su diode nego su neke lampe sa zivom Quote
Dragan Penev Posted April 13, 2021 Author Report Posted April 13, 2021 12 hours ago, patason said: Aca ribon koristi phono kome su lampe osvetljene plavom led diodom? Ne radi se o Aci uopšte... nije ni bitno. Spravica vrlo korektna, samo ću joj dodati jače napajanje, nisam imao trenutno kvalitetnije. Quote
somilenko Posted April 13, 2021 Report Posted April 13, 2021 16 sati ranije, Dragan Penev said: Stigla nova spravica za igru. Aiyima Tube T3 preamp. Naručen direktno na sajtu, stiglo iz Holandije za meseca dana. Free delivery, carina ništa. 52 dolara. Povezao kao preamp za gramofon. Sasvim lepo i korektno. Inače, kupljeno po no preporuci gospodina koji radi RAAL ribone. Čovek koristi to već neko vreme u svom veoma ozbiljnom sistemu. To ti uopšte nije all in one... Quote
