LEILA Posted December 18, 2013 Report Share Posted December 18, 2013 poÅ¡tovani,molim za informaciju gde mogu kupiti ploÄe ili prodati dali znate neko mesto...sajt ili....sliÄno hvala http://yugovinyl.blogspot.com/ Quote Link to comment Share on other sites More sharing options...
VU metar Posted December 19, 2013 Report Share Posted December 19, 2013 Prodati ih možeš i ovde u rubrici oglasi. Quote Link to comment Share on other sites More sharing options...
revox Posted January 20, 2014 Report Share Posted January 20, 2014 vrlo loÅ¡ otisak, neÅ¡to sliÄno PGPRTS u svoje pero Columbia 88697986711 Quote Link to comment Share on other sites More sharing options...
Sonichammer Posted January 21, 2014 Report Share Posted January 21, 2014 vrlo loÅ¡ otisak, neÅ¡to sliÄno PGPRTS u svoje pero Columbia 88697986711.jpeg Columbia 88697986711 Ja sam kod drugara cuo ovu plocu, istina na jako ozbiljnom gramofonu. Zvuk je bio sasvim dobar. Quote Link to comment Share on other sites More sharing options...
revox Posted January 21, 2014 Report Share Posted January 21, 2014 Ja sam kod drugara cuo ovu plocu, istina na jako ozbiljnom gramofonu. Zvuk je bio sasvim dobar. ne znam koju kopiju si slusao i na kom gramofonu ove kopije dobavljene od distributera Bertus Barcode: 8 8697-98671-1 6 Label Code: LC 00162 A Matrix : BB61915-01 A2 MK B Matrix: BB61915-01 B1 MK Made in EU sluÅ¡a se na thorens 147 sa thorens ruÄkom i par glava AT120, Grado green 1, sumico pearl, nije neÅ¡to a nije ni loÅ¡e sluÅ¡ane dvije kopije obje imaju pucktanje i blago krckanje u toku trajanja pjesama, izmeÄ‘u stvari ne, ne na svim pjesmama ali na obje kopije na A i B strani na A/B2 i A/B3 nije neÅ¡to al se Äuje - Å¡to nervira naroÄito na ovoj ploÄi od istog dobavljaÄa uzete i ploÄe MOVLP 033, MOVLP 502 i MOVLP 503 sve tri bez greÅ¡ke gdje su presane Music on vinyl ne znam, u EU sigurno, al ove kopije Old ideas gdje god da su presane ne valjaju Quote Link to comment Share on other sites More sharing options...
Scorpio(DDMF)! Posted January 22, 2014 Report Share Posted January 22, 2014 Po svoj prilici, to je sve cesca (ili cesta) situacija sa novim plocama.Koliko sam mogao procitati, veliki pritisak potrosaca je u SAD smanjio broj ovakvih defekata kod vecine proizvodjaca, dok je u EU situacija (na istim albumima/izdavacima) i dalje poprilicno problematicna. RTB/PGP iz losijih dana je poprilicno dobar opis.Prestao sam da od novokupljenog albuma ocekujem plocu bez fleka, no-fill-ova, raznih ogrebotina nastalih u transportu/proizvodnji cak i fleka/ostataka print unutrasnjih omota na ploci/u brazdi...Nacentriranost rupe, kao i talasastost (cak i kod 180g ploca), da ne pominjem.Ocekujem jedino da tick-ovi koji nastaju kao posledica ovoga ne budu previse brojni i/ili glasniji od snimka. Nadam se da su to samo pocetni problemi ponovne proizvodnje ploca, koji ce vremenom biti savladani (narocito sto sama tehnologija postoji vec "neko" vreme )...Posebno mesto cuvam i za onoga ko je izmislio i uspesno primenio devizu da "mozemo na nove ploce narezati veci dinamicki raspon" - sto u vecini slucajeva rezultuje loudness war-om za LP, gde igla vec na polovini strane pokusava da iskoci iz brazde.Postoje i "svetli primeri", naravno, ali nisu bas u vecini, barem u mom slucaju.Pozdrav! Quote Link to comment Share on other sites More sharing options...
Infidel Posted January 29, 2014 Report Share Posted January 29, 2014 Postovi 128-131 prebaÄeni iz teme "Upravo kupljeno/naruÄeno..." Quote Link to comment Share on other sites More sharing options...
Maks Posted January 29, 2014 Report Share Posted January 29, 2014 Scorpio, veći dinamiÄki raspon je dobra stvar. Ono na Å¡ta ti verovatno hoćeÅ¡ skrenuti pažnju je kompresija (koja rezultuje manjim dinamiÄkim rasponom) i pojaÄavanje signala dovedenog na glavu rezaÄa, a bez obzira na mogućnosti praćenja brazde od strane potroÅ¡aÄeve igle. Dobra izdanja klasiÄne muzike imaju ogroman dinamiÄki raspon (do oko -30dB gde je 0 dB najglasniji deo pesme) i zvuÄe fenomenalno. Quote Link to comment Share on other sites More sharing options...
Scorpio(DDMF)! Posted January 29, 2014 Report Share Posted January 29, 2014 Opaska se odnosi na nasilno povecavanje dinamickog raspona koji je moguce urezati na plocu, bez osvrtanja na same snimke. Problem je sto je na pojedinim izdanjima narezan signal ciji nivo skoro izbacuje iglu iz brazde, narocito na drugoj polovini strane. Poredjenje sa loudness war-om se odnosi na onaj deo "koliko glasno mozemo nesto narezati", gde mi se cini, da se otislo u skoro preveliki plus, pa vec same specifikacije medija prete da to na krajnjoj granici. Naravno, to se da koristiti za narezivanje snimaka koji su dodatno dinamicki komprimovani, ali to je samo deo problema. Pretpostavka od koje polazim u ovom slucaju je da je dinamicki raspon koji je moguce narezati na plocu konacan i vec veoma dobro savladan/obradjen do npr. 70tih godina (ako se uzme pretpostavka da se npr. 60tih u nekim slucajevima obracala paznja i na to da se ploce rezu tako da ih mogu "pratiti" jeftini kertridzi/glave, sto bi do 70tih trebalo biti reseno) i da bi ovo danas bilo cisto "izmisljanje tople vode", koje pritom daje veoma lose rezultate... Pozdrav! Quote Link to comment Share on other sites More sharing options...
Maks Posted January 30, 2014 Report Share Posted January 30, 2014 Onda smo se skapirali, prevelik nivo signala je problem. ÄŒini mi se da si to pomeÅ¡ao sa dinamiÄkim rasponom, al nema veze Ne vidim u Äemu je problem, zna se kako radi cela maÅ¡inerija, svako može da ode na ortofonov sajt i vidi koje je ograniÄenje najjeftinije igle, 65 mikrometara pri 315 Hz, par jednaÄina može da se reÅ¡i da se lako ustanovi dokle smeÅ¡ da teraÅ¡ signal, to je poso od pola sata i gotovo svo raÄunanje! Kod mene je dotiÄna igla opuÅ¡teno ispratila maksi singl britanskog rejva iz devedestih. Problem je Å¡to ljudi rade poso o kojem nemaju POJMA -.- Dosta s mojim hejtom, sad ću sluÅ¡am neki pank da to izbacim iz sebe Quote Link to comment Share on other sites More sharing options...
Scorpio(DDMF)! Posted January 30, 2014 Report Share Posted January 30, 2014 Lepo sam napisao na sta sam mislio, tako da, ako ne citas povrsno, verujem da nije tesko da zakljucis. Narezivanje peak-ova na npr. +3dB glasnije od standardne/dobre prakse, daje mogucnost za povecavanje dinamickog raspona snimka na medijumu. Problem je sto se to koristi i tamo gde treba i gde ne. Posledica je problem sa trackingom. Pod "novim" se nije racunalo na ploce iz 90tih, vec na one koje se izdaju danas. Quote Link to comment Share on other sites More sharing options...
Maks Posted January 30, 2014 Report Share Posted January 30, 2014 Znam, ali dotiÄni maksi singlovi su izuzetno glasni. Hoću reći da je dotiÄni pokuÅ¡aj povećavanja dinamiÄkog raspona apsolutno beskorisan. Å um nove ploÄe je u najgorem sluÄaju -45dB u odnosu na rez od 0dB (postoji standard koliko je zapravo tih 0dB u cm/sek al sam ja zaboravio, to je RIAA uradila pored frekvencijske krive). Na stranim ploÄama, ovaj Å¡um retko ide iznad -60dB. Ne postoji muzika (ukljuÄujući klasiku) koja može da iskoristi ovaj dinamiÄki opseg. Jedan sluÄaj je izuzetak, to je rezanje jako dugog LP-ja (preko pola Äuke po strani) gde je rez na ploÄi ispod -6dB u odnosu na ovaj standard. Tada se dobije da je odnos signal/ Å¡um -39dB, Å¡to je malo i Å¡um će biti primetan na nekim delovima mjuze. Ali danas ovo niko ne radi, već se izda dupli LP. Tako da, dotiÄna upotreba prekomernih nivoa je apsolutno beskorisna. Quote Link to comment Share on other sites More sharing options...
NShappy Posted January 31, 2014 Report Share Posted January 31, 2014 Pa jeste beskorisna. Ali se radi, danas... Quote Link to comment Share on other sites More sharing options...
Maks Posted February 1, 2014 Report Share Posted February 1, 2014 Ma bre: Quote Link to comment Share on other sites More sharing options...
VU metar Posted February 1, 2014 Report Share Posted February 1, 2014 Tema Vic, post # 2021 . Quote Link to comment Share on other sites More sharing options...
Mingus,Mingus Posted February 6, 2014 Report Share Posted February 6, 2014 ............... Quote Link to comment Share on other sites More sharing options...
Maks Posted April 8, 2014 Report Share Posted April 8, 2014 Ljudi, ima li neko singlicu Smaka Epitaf/ Ulazak u harem? Ja sam nabavio jednu koja izgleda super, ali ima katastrofa distorziju na sebi koja mi ne zvuÄi kao da je poreklom sa gramofona, već greÅ¡ka u masteringu. Može li mi neko potvrditi? Quote Link to comment Share on other sites More sharing options...
HMrules Posted April 8, 2014 Report Share Posted April 8, 2014 Ja takoÄ‘e imam distorziju na albumu Master of puppets, englesko izdanje, naroÄito se primećuje u pesmi Battery.http://www.discogs.com/Metallica-Master-Of-Puppets/release/2694060 Quote Link to comment Share on other sites More sharing options...
violent femmes Posted April 8, 2014 Report Share Posted April 8, 2014 Sta ti mislis da zapadnjaci ne znaju da zaseru plocu.Znaju ne boj se. Quote Link to comment Share on other sites More sharing options...
VU metar Posted April 8, 2014 Report Share Posted April 8, 2014 Ljudi, ima li neko singlicu Smaka Epitaf/ Ulazak u harem? Ja sam nabavio jednu koja izgleda super, ali ima katastrofa distorziju na sebi koja mi ne zvuÄi kao da je poreklom sa gramofona, već greÅ¡ka u masteringu. Može li mi neko potvrditi? Kao da se sećam takvog utiska i kod mene, ne mogu da proverim. Quote Link to comment Share on other sites More sharing options...
violent femmes Posted April 8, 2014 Report Share Posted April 8, 2014 Tako vam i treba kad' skupljate singlice. Quote Link to comment Share on other sites More sharing options...
Mostly Harmless Posted April 8, 2014 Report Share Posted April 8, 2014 Realno. Ni ja ih ne volim, iÄ. @kvalitet izdanja> kupio sam nedavno Echo and the bunnymen, nemaÄko izdanje, kompilaciju prva Äetiri albuma. Neke pesme su nesluÅ¡ljive, Å¡iÅ¡te kao da je tonac bio pijan (a ko kaže da nije?) Nijedna "domaća" ploÄa ne zvuÄi tako loÅ¡e, bar je ja nisam Äuo... Quote Link to comment Share on other sites More sharing options...
violent femmes Posted April 8, 2014 Report Share Posted April 8, 2014 Pazi,ma koliko da sam opusten lik,ne mogu da se akam sa singlicama. Jedan od mojih slucajeva @kvalitet izdanja> svojevremeno sam ludeo da nabavim album "Swordfishtrombones" od najdrazeg mi izvodjaca uncle Tom Waits-a.Prvo nadjeni primerak,nemacki otisak,ganc nov primerak,jedna strana ploce je bila zvucna fantazija,dok je druga bila kompletno sa nekim cudnim rekao bih fantomskim sumom,pre bih to nazvao huk,ili tako nesto je..no slicno.Drugi italijanski otisak,takodje u mint stanju je bio gotovo neslusljiv od suskanja,krckanja,kao da ste slusali recimo ne totalno mint vinyl vec neki vg pa i losiji. Veliko iskustvo u skupljanju vinyla me naucilo da zaobilazim (izuzev ako je nesto jako retko) italijanske,kanadske,grcke..i slicne otiske.Da napomenem da i u tu ima sjajnih otisaka ali ih treba naci. Quote Link to comment Share on other sites More sharing options...
Froggy Posted April 9, 2014 Report Share Posted April 9, 2014 @kvalitet izdanja> kupio sam nedavno Echo and the bunnymen, nemaÄko izdanje, kompilaciju prva Äetiri albuma. Neke pesme su nesluÅ¡ljive, Å¡iÅ¡te kao da je tonac bio pijan (a ko kaže da nije?) Nijedna "domaća" ploÄa ne zvuÄi tako loÅ¡e, bar je ja nisam Äuo... E, da, ja zaboravio da ti javim - moja "Songs to Learn and Sing" kompilacija je grÄko izdanje, i ne pati od sibilance ni u jednoj pesmi (a pogotovo ne u "The Killing Moon"). Izgleda da je tzv. cutting-engineer kod nemaÄkog izdanja zabrljao, ali ne mora da znaÄi, jer ako je korišćena loÅ¡a (izraubovana) matrica, mogu se oÄekivati iste zvuÄne anomalije... Quote Link to comment Share on other sites More sharing options...
HMrules Posted April 9, 2014 Report Share Posted April 9, 2014 Sta ti mislis da zapadnjaci ne znaju da zaseru plocu.Znaju ne boj se. Umeju, imao sam problem sa albumom Ride the lightning, Universal izdanje iz 2006, zvuk je tanak, visoki tonovi kao da ne postoje, posle sam nabavio ameriÄko izdanje, zvuÄi neuporedivo bolje. Quote Link to comment Share on other sites More sharing options...
