Nixie Posted November 9, 2021 Report Posted November 9, 2021 Isto izgleda biflex driver, u čemu je razlika? Quote
Majda Posted November 9, 2021 Report Posted November 9, 2021 13 hours ago, prophet said: GPA uskoro pocinje proizvodnju BiFlex 15-inch drajvera. Doduse 415C. Za sada ih mozemo videti u ovim zvucnicima:http://www.troyaudio.com/ Doduse ne dopada mi se kako su ga uposlili ali raduje da ce ih biti u prodaji. Auhh kako im je dobra ova "Hellena" (Troy audio) Quote
hifista Posted November 9, 2021 Report Posted November 9, 2021 Hellena je stvarno mnogo dobra, bas i koncentrik alnico Alteci, sve Duelund u skretnici, 100db osetljivost. Quote
Zexx Posted November 9, 2021 Report Posted November 9, 2021 Za 120 hiljada zelenih novčanica koliko se traži za Hellenu, bilo bi sramota da ne valja... Quote
prophet Posted November 14, 2021 Report Posted November 14, 2021 Da se nadovezem na [mention=9968]zflazar[/mention] ovu opsku o solid stejt urdjajima ima prijava (visedecenijski slusaoci su u pitanju sa morem iskustva i opreme), da Bakoon Project radi neverovatno dobrohttp://www.bakoon.com/ stara firma poznata po Satri kolu izmedju ostalog. Da li ovo moze negde da se poslusa? Quote
Majda Posted November 17, 2021 Report Posted November 17, 2021 On 11/14/2021 at 7:14 PM, prophet said: Da li ovo moze negde da se poslusa? Nije odavno kod mene . Ali ti njihovi moduli su dostupni da se poruce. Mislim da nisu nesto ni skupi? Quote
prophet Posted November 17, 2021 Report Posted November 17, 2021 Nije odavno kod mene . Ali ti njihovi moduli su dostupni da se poruce. Mislim da nisu nesto ni skupi?To nisam znao. Hvala za info. Quote
Majda Posted December 26, 2021 Report Posted December 26, 2021 Zanimljiv koncept opticke gramogonske glave Toshiba C-100P (i novijeg modela na osnovu ove glave) fotogtafije, clanci i ostalo na linku: https://www.audiovintage.fr/leforum/viewtopic.php?t=8725 Quote
somilenko Posted December 26, 2021 Report Posted December 26, 2021 Ovo bi bilo zanimljivo čuti... https://www.sound-smith.com/cartridges/strain-gauge-systems/strain-gauge-systems Quote
Majda Posted December 26, 2021 Report Posted December 26, 2021 Da sigurno. Najverovatnije po istom principu i DS-audio DS-W1 (ne proizvodi se vise) https://www.ds-audio-w.biz/ds-w1/ ovde je toshibin RIAA preamp za ove opticke zvucnice. Veoma jednostavan i sa vrlo jednostavnm napajanjem. Mozda i "previse jednostavno" je sve ovo? Sa druge strane neverovatno je koliko se danas komplikuje... Quote
Zexx Posted December 26, 2021 Report Posted December 26, 2021 Jednostavan je iz prostog razloga što je za "optičke" zvučnice potrebna vrlo mala RIAA ekvalizacija. Quote
Majda Posted December 26, 2021 Report Posted December 26, 2021 2 hours ago, Zexx said: Jednostavan je iz prostog razloga što je za "optičke" zvučnice potrebna vrlo mala RIAA ekvalizacija. Ne u tom smislu? Vec kako je izveden pojacavac i napajanje. 2 stepena pojacanja, napajanje je izuzetno jednostavno. Network za ekvilizaciju je istog koncepta i ima isti broj elemenata kao i bilo koji drugi ALL-in-one. Medjutim nisam siguran da je ovo preamp za riaa ekvilizaciju? vec samo neku ulazni modul koji pojacava i dodtno linearizuje izvor pre riaa preampa. Zvucnica ima oko 0.1mV. Ovaj sklop pojcava signal do 3mV i ulaza za MM. Cini se da ovi preklopnici to regulisu? To su jos manji signali od MC zvucnica i velika pojacanja koja se desavaju pre MM preampa i riaa korekcije. Napajanje sklopa skoro da nema regulaciju (samo zener diode) i RC filter. Napajanje fotoelemenata regulisano. Quote
somilenko Posted December 26, 2021 Report Posted December 26, 2021 @Zexx je u pravu, Soundsmith deklariše da RIAA uopšte nije ni potrebna, njihovo objašnjenje je na linku https://www.analogueseduction.net/cartridges2/soundsmith-sg-230-strain-gauge-cartridge-system.html Quote
giZ_Mo Posted December 26, 2021 Report Posted December 26, 2021 Ма све је лепо и красно, а чему све то служи, мислим та оптика? Quote
somilenko Posted December 26, 2021 Report Posted December 26, 2021 Pa za slušanje muzike Zamena za magnetni kertridž za gramofon. Prema teoriji, mnogo manja masa na unutrašnjoj strani canteliever-a, pa samim tim i veća brzina. Nelson Pass u svom sistemu ima takav kertridž... Quote
giZ_Mo Posted December 26, 2021 Report Posted December 26, 2021 Интересантно, мада да је то ваљало остало би и до данас у употерби. Quote
somilenko Posted December 26, 2021 Report Posted December 26, 2021 To što si zaokružio je sistem za automatsko vraćanje ručice, ovde je tema "strain gauge" zvučnica. Ovo je poprilično zanimljivo, nema mnogo proizvođača koji se time bave a navodno je daleko ispred MC, MM i MI zvučnica. Baci pogled na link iz ovog posta. 3 sati ranije, somilenko said: @Zexx je u pravu, Soundsmith deklariše da RIAA uopšte nije ni potrebna, njihovo objašnjenje je na linku https://www.analogueseduction.net/cartridges2/soundsmith-sg-230-strain-gauge-cartridge-system.html Evo ga i link sa Soundsmith sajta https://www.sound-smith.com/cartridges/strain-gauge-systems/strain-gauge-systems Quote
Majda Posted December 27, 2021 Report Posted December 27, 2021 On 12/26/2021 at 8:33 PM, somilenko said: @Zexx je u pravu, Soundsmith deklariše da RIAA uopšte nije ni potrebna, njihovo objašnjenje je na linku https://www.analogueseduction.net/cartridges2/soundsmith-sg-230-strain-gauge-cartridge-system.html Pa mislim da ne? Pogledati grafikone na linku https://www.hifinews.com/content/soundsmith-sgsg-230-cartridge-lab-report "The SGS-5/SG-230's frequency response, and its equalisation of the RIAA encode characteristic, is achieved partly by an active LF boost while relying on the natural mechanical roll-off of the pick-up to counter the ~1st-order emphasis applied to records above 2.1kHz (75µsec). Nevertheless the reinforced upper bass/lower mid, depressed presence and peaked high treble [Graph 1, below] suggests this is only partially successful. Once again, lateral (L+R) cuts [black trace] are captured more convincingly than vertical (L-R) modulations but – crucially – note the inherent 'smoothness' of the responses and freedom from HF resonances seen in all my measurements of traditional MM/MC pick-ups." Najverovatnije da je potrebna riaa ekvilizacija za delove iznad 2K. Na nihovom prijemnom uredjdaju postoji i "obican" ulaz isto kao i kod toshibonog modula. Medjutim ogromne su razlike u nivoima toshiba oko 0.1mV dok za SS navode cak oko 500mV? Mislim da je to nivo sa tim njihovim modulom. Jednostavno nsam uspeo da nadjem jasne specifikacije. Kao sto je to slucaj kod Toshiba zvucnice... Kmentarisao sam samo Toshiba preamp za njihovu specificnu glavu. I tamo postoji pasivni net koji sigurno vrsi neke korekcije ali to nisu riaa korekcije. Tako da je za toshiba model potrebna riaa korekcija a najverovatnije i za ove druge modele? Quote
Majda Posted December 27, 2021 Report Posted December 27, 2021 Toshibin network moze da se "proveri" ako nadjem vremena saljem rezultate ekvilizacije Quote
paja959 Posted December 28, 2021 Report Posted December 28, 2021 On 26.12.2021. at 16:05, Majda said: Da sigurno. Najverovatnije po istom principu i DS-audio DS-W1 (ne proizvodi se vise) https://www.ds-audio-w.biz/ds-w1/ DS W2 radi kod jednog mog poznanika,sa pripadajucom phono sekcijom...s obzirom da se skoro deceniju palio iskljucivo na Shure 44-7 i njihovu phono sekciju Shure SE20,pa nesto jako kratko na MoFi phono+zvucnice,sa kratkom stankom prije DSW2 sa ASR Basis Exclusive phono sekcijom i Dynavector DRT XV1S,intersantan iskorak...i vozi covek interesantan sistem,moguce out of ordinary/highend,zovi kako hoces: Bodor Dual Pc,Bricasti M1 dac,Core Audio Karuna Ref,BricastiM20preamp,ATC SCM150asl LSTechnics 1200G ,DS audio pickupDSW-2 phono,WW Gold Eclipse 8 XLR ,Valhalla Draco Ref aes/ebu, Stealth T-selected v2 usb, Vertere LAN, WW Platinum tStax SR007-SRM700S Quote
Majda Posted December 31, 2021 Report Posted December 31, 2021 Pa eto bas lepo da neko ima islustva sa ovim neobicnim zvucnicama. Kako zvuci u odnosu na klasicne? Quote
DejanM Posted December 31, 2021 Report Posted December 31, 2021 Ja nisam slusao ove zvucnice ali sam slusao tzv. laserske gramofone. Ima tome sada vec dosta godina ... Zvuk je bio dobar ali malo drugaciji nego kod ovih standardnih gramofona. Ali ono sto je bilo jako zanimljivo jeste da su bili jako osetljivi na prasinu koja se nalazila u brazdama. Zbog toga je bio gotovo preduslov za koriscenje, masina za pranje ploca. Tek dobro oprana ploca je prakticno mogla da se koristi. Quote
RADE Posted December 31, 2021 Report Posted December 31, 2021 On 26.12.2021. at 16:05, Majda said: Da sigurno. Najverovatnije po istom principu i DS-audio DS-W1 (ne proizvodi se vise) https://www.ds-audio-w.biz/ds-w1/ ovde je toshibin RIAA preamp za ove opticke zvucnice. Veoma jednostavan i sa vrlo jednostavnm napajanjem. Mozda i "previse jednostavno" je sve ovo? Sa druge strane neverovatno je koliko se danas komplikuje... Сасма је разумљиво зашто се данас компликује. Како мислиш да продаш нешто што ради добро а има 5 делова. Quote
paja959 Posted December 31, 2021 Report Posted December 31, 2021 8 sati ranije, Majda said: Pa eto bas lepo da neko ima islustva sa ovim neobicnim zvucnicama. Kako zvuci u odnosu na klasicne? Nick Bartsch "Continuum",Steve Reich "Music for 18 musicians",bejase jako dobro na kratko,kao ceo sistem,pitanje kolko vuce zvucnica+phono u tom sistemu...aktivna ATC 150-ka sama po sebi vec nije macji kasalj,to je postavljeno u nearfield monitoring u nekoj sobi od cca 25m2 akusticki tretiranoj...ali crv sumnje kod mene postoji,masa Entreq pacova u sistemu,dedicirana polica za hifu izradjena od bambusovine+ podmetaci od bambus daske pod svaku komponentu sa nekim specijalnim siljcima ? Quote
