It occurs most often on a 180g record's outer edge and is caused by the vinyl's beginning to harden prematurely. The sound produced is noise—a "shsssshing" sound that we've all heard too often.
Nemam pojma Å¡ta je taj perla-efekat, ali zaista većina novih ploÄa od 180 grama Å¡uÅ¡ka prvih par minuta. Mislio sam da je treking, podesio ga pažljivo, ali sve ostade isto.
Ima toga dosta i na starim ploÄama, nisu morale biti ni posebno debele (PGP).
Nego, ovde MF napisa da se to vidi (uz napor) na slici.
A, ja ne znam šta valja gledati.
Ja imam non-fill na par albuma, od toga jedna Patricia Barber 200gr i dve stare ploÄe, niÅ¡ta spec debele (mislim regularnih 140gr). InaÄe, na mojim primercima ti defekti nisu okom vidljivi.
Taj "shsssshing" saund je moguće Äuti na mnogim SUZY ploÄama (licence i domaćice) iz perioda 1979-1980, pogotovu u momentu kada igla krene s kraja jedne pesme na poÄetak druge.
N.pr. ako neko joÅ¡ ima "Gradske priÄe" ili "Vruće igre" od Parnog valjka, izmeÄ‘u skoro svih pesama se Äuje taj ššššššum.
I, da, golim okom se ne može uoÄiti nikakva anomalija koja bi naznaÄila da je otisak loÅ¡...
  • 2 months later...
Evo i mesta odakle možete da preuzmete još raznih BG-ova...
http://www.theabsolu.../buyers_guides/
http://www.avguide.com/buyers-guides
I jedan citat:
Beyond the LP what do you see?
The other thing I hope takes off is high-resolution
music on Blu-ray. You can put non-compressed
24-bit/192kHz audio surround or two channel
on it, and I’m hoping that’s where it goes. Even
though the LP is a technology I’m conversant
and feel totally comfortable with, it’s pathetic
that the best thing you can buy in 2010 is an
LP—an artifact from the 1960s. For me, if I could
go home and listen to a disc in 192kHz the way
I hear it in the studio, you could keep your LPs.
Parenthetically, now that we’re up and running
and I’m working with Josh Florian who makes the
best 192kHz converters that I think exists, we’re
going to do some live classical guitar recording
right to the disc and we’re going to go play it.
Može biti zanimljivo za vinyl-džije:
http://www.avguide.c...l-playback-2012
Žiko, hvala što si podelio ovaj link sa nama!
Ipak, prelistao sam ovaj BG, i moram da izrazim svoje (biću blag) ÄuÄ‘enje tekstom "10 most important turntables of all time", gde se Technics pominje samo jedanput (i brojevima: 1x), i to pežorativno:
"The Innovation Wood, ostensibly a replacement for the Anniversary, raises the bar still higher on what a $10,000 ’table can do, outdistancing the fine Anniversary in several areas, most notably in pitch stability. Its speed accuracy reminds me of my dearly departed classic Technics SP-10 MkII direct-drive ’table, but without the motor noise"
Može neko da voli ili ne voli Technics, ali izjaviti da SP-10 ima "motor noise" je sa one strane zdravog razuma. Dalje, spisak najznaÄajnijih gramofona bez 1210 i SL-10 je... aj' neću da lajem :)
Ovaj Buyers Guide je pamflet, pure advertising, svaka reÄ je plaćena, i u njega treba verovati koliko u Tele-shop. Ali, slike su lepe, zaista :thumbsup2
TaÄno tako!
Ркоји није?
:wave2
I jedan citat:
it’s pathetic
Da li se ti slažeš sa ovim citatom?
Ja baš mislim da je super da nešto što je OK bude dostupno i posle toliko godina... Za mene LP i jeste "the best thing you can buy in 2012/13" :)
Pozdrav!
Ipak, prelistao sam ovaj BG, i moram da izrazim svoje (biću blag) ÄuÄ‘enje tekstom "10 most important turntables of all time", gde se Technics pominje samo jedanput (i brojevima: 1x), i to pežorativno...
Ja ne znam da li gledamo isti broj, ali eto ga SP-10 na mestu broj 07 najznaÄajnijih gramofona u istoriji. Po meni zasluženo... TakoÄ‘e, nisam siguran da LP12 treba baÅ¡ da bude drugi, nekoliko mesta ispred Thorensa, kad se zna da ne bi bilo prvog da nije bilo ovog drugog, ali dobro. Uglavnom, meni se Äini korektna lista.
Aha, u pravu si :thumbsup2 , eno ga ali se zove Panosonic :blink: SP-10! Ja sam prelistao pdf, ukucao Technics u search i dobio šipak.
Ipak, meni je lista sumnjiva jer su propozicije ovakve: "(Ten gramphones) that introduced new techniques, influenced other designs, achieved wide commercial success, or represented a performance breakthrough at the time". Nekoliko gramofona sa liste su varijacija na temu AR-XA, nekoliko su snobovski tripovi, a gramofona koji je zaista doneo tehnološki napredak, koji je zaista za trideset godina prodat u tri miliona primeraka, koji je zaista promenio popularnu muziku - nema na listi...
p.s. evo da ljudi znaju o Äemu priÄamo:
The Absloute Sound
Guide to Vinyl Playback
The 10 Most Significant Turntables of All Time
10. Walker Black Diamond
09. Well Tempered Turntable
08. Oracle Delphi
07. Panasonic SP-10
06. Garrad 301
05. Thorens TD-124 / TD-160
04. Goldmund Studio
03. Sota Star Sapphire
02. Linn Sondek LP12
01. Acoustic Research XA
Ma, neka misle da je najgori, ali, Technics SL1200 je najprodavaniji gramofon svih vremena (hm, k'o da postoje neka druga vremena). To je kao istorija Pop muzike dvadesetog veka koja ne spominje Beatles-e.
The Absloute Sound
06. Garrad 301
Ðарочито :ruganje овај шпорет.
:wave2
