sondek Posted March 5, 2013 Report Share Posted March 5, 2013 Najbolje da moderacija obriše i "oglas" i sve posle toga.unapred zahvaljujem. Quote Link to comment Share on other sites More sharing options...
Iggy Posted March 7, 2013 Report Share Posted March 7, 2013 Da, to su ti oglasi jer gari nije mogao da proda, pa mi ih daje. Ok, shvatio sam da ne vrede niÅ¡ta, bez obzira da li zezate ili ne. Zadržaću ih, pa nek sviraju. Hvala na trudu. Nisam ironiÄan. Quote Link to comment Share on other sites More sharing options...
anubisgrau Posted March 7, 2013 Report Share Posted March 7, 2013 e odlicna tema, znaci za lepakgram treba direct drive? dobro ste mi rekli, umalo sto onomad ne kupih kod ciganke neki dual za 200 dinara mislim ako je zbog obrtnog momenta, zar nije resenje da se stavi kraca gumica pa da jace vuce i na belt drajvu? Quote Link to comment Share on other sites More sharing options...
NShappy Posted March 7, 2013 Report Share Posted March 7, 2013 Nije kod belt-a problem proklizavanja gumice, već snaga motora. Džaba kraća gumica Quote Link to comment Share on other sites More sharing options...
Maks Posted March 10, 2013 Report Share Posted March 10, 2013 @anubisgrau Zavisi koji Dual... Quote Link to comment Share on other sites More sharing options...
revox Posted March 10, 2013 Report Share Posted March 10, 2013 e odlicna tema, znaci za lepakgram treba direct drive? dobro ste mi rekli, umalo sto onomad ne kupih kod ciganke neki dual za 200 dinara mislim ako je zbog obrtnog momenta, zar nije resenje da se stavi kraca gumica pa da jace vuce i na belt drajvu? za te pare se kupuje dual Nije kod belt-a problem proklizavanja gumice, već snaga motora. Džaba kraća gumica teÅ¡ko da kod strijih modela duala može bit u pitanju snaga motora jer su im motori bar od 500-700 grama Äetvoropolni ili osmopolni @anubisgrau Zavisi koji Dual... i to je taÄno Quote Link to comment Share on other sites More sharing options...
sondek Posted August 23, 2013 Report Share Posted August 23, 2013 da malo razbudim ploÄoljube jedan proizvod koji za mene postaje deo redovnne higijene igle.Preporucujem da ocistite iglu pre koriscenja,i onda ce se cuti razlika verovatno.Kupih to na Pajinu preporuku nakon par odustajanja-odem po to pa kupim plocu svaki put.Dobra stvar i samo naizgled skupa,jer verujem da je kolicina dovoljna i za par godina ciste igle-a to je jedna nova ploca i to ne od skupljih.Cena kod nas u radnji je ista,za novosadiste ima je u mungosu.Iznenadjuje ovo sto pise za nove ploce,ispadose i po ovom pitanju...ajd da ne pricam. http://www.needledoctor.com/clearaudio-Diamond-Elixir-Stylus-Cleaner Quote Link to comment Share on other sites More sharing options...
zbrujic Posted October 17, 2013 Report Share Posted October 17, 2013 "Reproduction from Records†(Chapter 17) in Radiotron Designer’s Handbook by Fritz Langford-Smith http://www.ax84.com/static/rdh4/chapte17.pdf Možda je malo "outdated" (1960. godina), ali svaÅ¡ta se odavde može nauÄiti. Meni posebno interesantan beÅ¡e ovaj, rekao bih hrabar, metod: Quote Link to comment Share on other sites More sharing options...
musicar Posted January 9, 2014 Report Share Posted January 9, 2014 NeÅ¡to o težini naleganja zvuÄnice? Kako merite težinu kojom zvuÄnica naleže na ploÄu? Da li koristite neku od onih vagica koje mere do stotog dela grama, ili se oslanjate samo na uputstva proizvoÄ‘aÄa i ruÄno (odokativno) podeÅ¡avanje? Quote Link to comment Share on other sites More sharing options...
NShappy Posted January 9, 2014 Report Share Posted January 9, 2014 To se zove gazna sila. Za podeÅ¡avanje, ima onaj teg na suprotnom kraju ruÄke. Na 1210 sam podesio tim tegom, a onda kasnije nabavio vagicu, i samo tegom podeÅ¡ena gazna sila je bila veoma taÄna. Quote Link to comment Share on other sites More sharing options...
musicar Posted January 9, 2014 Report Share Posted January 9, 2014 I ja sam podesio tegom, ali nemam vagicu da to proverim. Obzirom da se radi o stotim delovima grama, verovatno nije baÅ¡ 100% taÄno. InaÄe zvuÄnica mi je Rega Exact Äija gazna sila je 1,75g. Quote Link to comment Share on other sites More sharing options...
NShappy Posted January 9, 2014 Report Share Posted January 9, 2014 Ma, dal' je 1.72 ili 1,78 ti nije mnogo bitno. BTW, dal' si prvo baždario teg (podesio da ruÄka "lebdi horiznotalno" kada je teg na nuli)? Quote Link to comment Share on other sites More sharing options...
musicar Posted January 9, 2014 Report Share Posted January 9, 2014 Da, da, baš tako je urađeno. Quote Link to comment Share on other sites More sharing options...
sondek Posted January 9, 2014 Report Share Posted January 9, 2014 Za vecinu glava se daje opseg koji uopÅ¡te nije mali obiÄno ide i do pola grama.Btw.kupio si nov gramofon od zastupnika,Å¡to ne tražiÅ¡ da ti ga oni idealno podese i obuÄe te za ubuduće.Nisi im male pare ostavio da bi trebao da se ustruÄavas,a i njima treba da je interes da budes zadovoljan uslugom. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted January 9, 2014 Report Share Posted January 9, 2014 Verujete li u taÄnost digitalnih vagica ili smatrate da su taÄnije precizno napravljene metalne ili plastiÄne klackalice? Quote Link to comment Share on other sites More sharing options...
musicar Posted January 9, 2014 Report Share Posted January 9, 2014 Btw.kupio si nov gramofon od zastupnika,Å¡to ne tražiÅ¡ da ti ga oni idealno podese i obuÄe te za ubuduće.Nisi im male pare ostavio da bi trebao da se ustruÄavas,a i njima treba da je interes da budes zadovoljan uslugom. Apsolutno se slažem. InaÄe, sve pohvale zastupniku, zvali su odmah sutradan telefonom da posavetuju oko podeÅ¡avanja i najavili da će opet pozvati za 15-tak dana kad to "legne" kako treba. Podesio sam baÅ¡ kako su mi objasnili i kako piÅ¡e u uputstvu i to meni zvuÄi sasvim korektno. Samo sam se pitao da li treba proveriti gaznu silu nekom vagicom ili klackalicom. ViÅ¡e muke sam imao sa anti skating-om, ali je i to sreÄ‘eno. Mislio sam da negde naÄ‘em test ploÄu, ali je uopÅ¡te nema. Quote Link to comment Share on other sites More sharing options...
Maks Posted January 9, 2014 Report Share Posted January 9, 2014 ImaÅ¡ RTB test ploÄe u radnjama koje prodaju polovne LP. NaÄ‘e se posle nekog vremena. Quote Link to comment Share on other sites More sharing options...
sondek Posted January 9, 2014 Report Share Posted January 9, 2014 Kako je sa VTA?Od toga mnogo vise zavisi zvuk nego od gazne sile,bilo bi dobro da je na pravom mestu pa da ne moras da se bakces sa podmetacima,vrlo moguce da je tako jer si uzeo i njihovu glavu.Po mom misljenju nepotrebno komplikovan sistem podesavanja.Podesavanje visine rucke uz inbus sa strane kako je kod mene(i na mnogim drugim ruckama) omogucava da to brzo i precizno podesis u par minuta,a onda finim promenama promenama u narednih par dana(ili nedelja) sve mozes lako da dostelujes "prema uhu",to su btw jedine tonske kontrole koje imam.Jedna brzina i ton kontrole sa inbus kljucem...bas sam neki tehnoman Mislim da bih sa tim sistemom podloski pojeo po kile zivaca,polako vec gubim strpljenje i ja pozelim da mi to neko strucan odradi umesto mene.Zovem sledecom prilikom kad dodje vreme za servis Mr.Groovija koji radi strucan servis u Novom Sadu ili Onehifi.Od one hifi sam dobio svu podrsku uvek kad mi je zatrebalo, cak i alat za podesavanje sondeka na zajam(set up Jig).Rade servis i strucno podesavanje lp12,to je uslov da bi bio diler.Nisam znao kakav je slucaj sa Regom ali diler mora da bude na usluzi i ima kvalitetnu tehnicku podrsku. Probaj ovde da ukebas RTB plocu. http://www.limundo.com/kupovina/Muzika-i-filmovi/Muzika/Gramofonske-ploce/TEST-PLOCA-LP-/16859189 Quote Link to comment Share on other sites More sharing options...
musicar Posted January 9, 2014 Report Share Posted January 9, 2014 Probaj ovde da ukebas RTB plocu. http://www.limundo.com/kupovina/Muzika-i-filmovi/Muzika/Gramofonske-ploce/TEST-PLOCA-LP-/16859189 Nažalost ta licitacija je odavno završena. Quote Link to comment Share on other sites More sharing options...
Maks Posted January 10, 2014 Report Share Posted January 10, 2014 Kako se Å¡teluje VTA na Dualu 502? Ako je uopÅ¡te i moguće. Ja sam samo nakaÄio Ortofonovu glavu i ruÄka mi izgleda popriliÄno paralelno s ploÄom. Quote Link to comment Share on other sites More sharing options...
kolja.t Posted January 10, 2014 Report Share Posted January 10, 2014 Kako se Å¡teluje VTA na Dualu 502? Ako je uopÅ¡te i moguće. Ja sam samo nakaÄio Ortofonovu glavu i ruÄka mi izgleda popriliÄno paralelno s ploÄom. Da li si koristio neki protraktor za položaj glave? Ja imam Dual 604 i mislim da je to (VTA) nemac napravio kako treba, uz originalni mat, naravno... Quote Link to comment Share on other sites More sharing options...
musicar Posted January 10, 2014 Report Share Posted January 10, 2014 Kad smo kod digitalnih vagica. Gledam nešto, velike su razlike u cenama. Ove kao markirane ujedaju, ClearAudio 180 evra, Pro-Ject 100 evra , a opet vidim na Amazon-u, ima i za 20-30 dolara. Izgledaju identicno, kinezi, a da li funkcionišu kako treba, Bog će ga znati. Quote Link to comment Share on other sites More sharing options...
sondek Posted January 10, 2014 Report Share Posted January 10, 2014 ...a kako je "nemac" mogao da zna koju ce ko glavu da stavi u rucku?Razlicite dimenzije(visina) glava i jesu razlog potrebe za podesavanjem VTA za svaku glavu.Negde je to reseno kvalitetnije,negde jednostavnije negde komplikovanije,negde nikako,a nekad su se uz glavu isporucivali podmetaci sto i nije bas neko resenje al kad nema drugog moze i tako. Quote Link to comment Share on other sites More sharing options...
musicar Posted January 10, 2014 Report Share Posted January 10, 2014 Kako je sa VTA?Od toga mnogo vise zavisi zvuk nego od gazne sile,bilo bi dobro da je na pravom mestu pa da ne moras da se bakces sa podmetacima,vrlo moguce da je tako jer si uzeo i njihovu glavu. To sam pitao odmah i rekoÅ¡e da je podeÅ¡eno idealno, obzirom da je i glava Rega, tako da se tu nisam niÅ¡ta ÄaÄkao. Verovatno kad bi stavljao glavu drugog proizvoÄ‘aÄa da bi moralo da se podeÅ¡ava. Quote Link to comment Share on other sites More sharing options...
kolja.t Posted January 10, 2014 Report Share Posted January 10, 2014 ...a kako je "nemac" mogao da zna koju ce ko glavu da stavi u rucku?Razlicite dimenzije(visina) glava i jesu razlog potrebe za podesavanjem VTA za svaku glavu.Negde je to reseno kvalitetnije,negde jednostavnije negde komplikovanije,negde nikako,a nekad su se uz glavu isporucivali podmetaci sto i nije bas neko resenje al kad nema drugog moze i tako. Možda greÅ¡im ali mislim da postoji standard za visinu MM zvuÄnica... Ovo je obiÄan gramofon, skuplji Duali iz vrha (ondaÅ¡nje) ponude su imali Å¡telovanje visine ruÄke... Ako bi mi to smetalo onda bih dao viÅ¡e za gramofon, od onoga Å¡to sam dao... Za sada sam vrlo zadovoljan, joÅ¡ jurim neke Eno/Budd ploÄe... Quote Link to comment Share on other sites More sharing options...
