sondek Posted September 11, 2016 Report Share Posted September 11, 2016 ako je referendum,ja sam ZA .Kog ne zanima nek preskoči Quote Link to comment Share on other sites More sharing options...
Hefest Posted September 12, 2016 Report Share Posted September 12, 2016 I mene zanima! Quote Link to comment Share on other sites More sharing options...
steve_pan Posted September 12, 2016 Report Share Posted September 12, 2016 On 9/10/2016 at 5:06 PM, damic said: Preko imgura, trebalo bi da se vidi Cestitke! Pretpostavljam da su Stage otisli kao zamena? Quote Link to comment Share on other sites More sharing options...
damic Posted September 12, 2016 Report Share Posted September 12, 2016 Zahvaljuljem. Heh, dva para Stages sklonjeni u drugu sobu kao rezerva, cisto da se nadje u kuci . Kad se sloze uspravno bez nogica, ne zauzimaju puno mesta. Duette sada "usviravam" sa sobom i subovima. Sve ono sto je bilo mukotrpno namesteno za Stages (ispod svakog zvucnika je bio sub, ala Mini Grand konfiguracija + 3 komada u sobi) sad ne vazi. Duette imaju mnogo izrazeniji bas, te sam ovih nedelju dana uspeo da usaglasim sa njima samo dva subvufera. Secem ih na 50Hz 24LR. Danas izbacio neku komodu iz sobe i malo promenio raspored namestaja, nebili promenio akustiku prostora i eventualno na mesto komode uspeo da uklopim treci sub. Videcemo... Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted September 12, 2016 Report Share Posted September 12, 2016 24 minuta ranije, damic said: Secem ih na 50Hz 24LR. Sada će multisub sistem imati znatno manje efekta, jedva do 100Hz. Quote Link to comment Share on other sites More sharing options...
ab Posted September 12, 2016 Report Share Posted September 12, 2016 Koliko su ovi elektrostaticki zvucnici zahtevni po pitanju pojacala, sta kod tebe tera iste - da li su to neki monoblokovi? Moze li se sa dovoljno rezerve struje dobiti odlican bass bez subwoofera? Quote Link to comment Share on other sites More sharing options...
damic Posted September 12, 2016 Report Share Posted September 12, 2016 Pozdrav Beat, Prvo malo objasnjenje za slabije upucene, ako se subovi seku na 50Hz sa rezom od 24LR, cuju se manjim intezitetom jos i narednu oktavu koja pada na 100Hz. Znas kako, Duetta Signature su poznate po izuzetnom basu. Sama trapezoidna bas membrana je povrsine 4000cm2 sto je povrsina skoro 5 klasicnih petnaestica, pritom izuzetno male mase (alu folija) i fantasticne brzine, tako da je steta ne iskoristiti je sto je moguce vise. Naravno, ovo je OB a ne klasicna kutija pa je efikasnost manja. Uglavnom ako treba da se bira kvalitet basa: planarna ribon membrana vs klasican sub ja sam za prvu varijantu. Ogranicenje je naravno, raspoloziva snaga pojacala koja ide na bas membranu, Ja mogu da joj dam oko 350W d klase na njenih 3,2 oma sto je taman, ako se reze na 50Hz 24LR dole i 350Hz 24LR gore. Inace, prethodni vlasnik Duette je imao na bas membrani vise nego dovoljnih 800W/4Ohms sto je radilo neverovatno dobro u prostoriji dva puta vece od moje, mada je i on je koristio rez za subove na 50Hz. Uobicajeno je da se subovi za velike Apogee's seku na 50-60Hz. He, he, ovo tvoje na kraju "jedva do 100Hz" je inace vise od prve dve cele oktave, koje se na malim kutijama i ne cuju Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted September 12, 2016 Report Share Posted September 12, 2016 24 minuta ranije, damic said: He, he, ovo tvoje na kraju "jedva do 100Hz" je inace vise od prve dve cele oktave, koje se na malim kutijama i ne cuju Samo da pojasnim zašto sam rekao "jedva". A možda i nisam u pravu... u svakom slučaju, nisam pomislio da će ti faliti basova. Uzmimo, recimo, 90Hz. Na toj frekvenciji je još dominantan bas iz glavne "kutije". Recimo da tu imamo veliki pik. Ostali sub-ovi su tu već veoma utišani, pa će i njihova moć ublažavanja anomalije biti adekvatno umanjena. Quote Link to comment Share on other sites More sharing options...
Chieftec Posted September 12, 2016 Report Share Posted September 12, 2016 Eto vidiš da je potrebna tema gde bi se pričalo o tome, ovde ne ide sada ta tehnička diskusija Meni je recimo na ovoj vrsti foruma rasprava oko konkretnih tehničkih stvari jedino što ima smisla, kako šta povezati, podesiti, a 99% priče su neki subjektivni utisci doživljaja zvuka koji veze nemaju ni sa čim. Ono, promenio sam osigurač u hodniku na prvom spratu i sada je bass mnogo bolji i tako to Šta znači 24LR, to je isto što i 24dB po oktavi? Quote Link to comment Share on other sites More sharing options...
Delija Posted September 12, 2016 Report Share Posted September 12, 2016 LR = Linkwitz–Riley @damic Zivis u kuci? Quote Link to comment Share on other sites More sharing options...
prophet Posted September 12, 2016 Report Share Posted September 12, 2016 Da. Linkwitz-Riley. Quote Link to comment Share on other sites More sharing options...
lalelala Posted September 12, 2016 Report Share Posted September 12, 2016 @damic i ja bih da se pridružim ekipici koja moli da se otvori nova tema sa malo slika koje će to da podrže i sa malo iskustava iz prve ruke itd ako imate volje ... deluje krajnje zanimljivo ! Quote Link to comment Share on other sites More sharing options...
damic Posted September 13, 2016 Report Share Posted September 13, 2016 12 sati ranije, Delija said: ...... @damic Zivis u kuci? Ne, stambena zgrada na Vracaru, potkrovlje. Quote Link to comment Share on other sites More sharing options...
Delija Posted September 13, 2016 Report Share Posted September 13, 2016 Huh... Pa kako se komsije slazu sa tvoim sub-ovima? Quote Link to comment Share on other sites More sharing options...
damic Posted September 13, 2016 Report Share Posted September 13, 2016 Stan je na dva nivoa, a okolo nema komsija sa zajednickim zidovima, nema problema Quote Link to comment Share on other sites More sharing options...
Delija Posted September 13, 2016 Report Share Posted September 13, 2016 Infrazvuk i ono blisko njemu prolazi kroz zidove kao kroz sir. Sa 5. sprata lagano drma prizemlje Quote Link to comment Share on other sites More sharing options...
Aurelijano Buendija Posted September 13, 2016 Report Share Posted September 13, 2016 Ušte jedna vrteška Quote Link to comment Share on other sites More sharing options...
trotter Posted September 13, 2016 Report Share Posted September 13, 2016 Cccc... cunami 😅 Nego, ono cemu treba izraziti divljenje posmatrajuci ovaj W sistem kroz internet prozor je vrhunska organizacija kablova. Toliko komponenti (pogledajte policu i sta je na/u njoj!) a kablovi stopljeni u sistem bez da ih primetis odmah obzirom koliko ih ima. Quote Link to comment Share on other sites More sharing options...
Aurelijano Buendija Posted September 13, 2016 Report Share Posted September 13, 2016 Tss.. srećom pa nisam slikao iza police - tamo je haos kablove tek treba organizovati.. ali - još sam par spravica u manjku, kad se načine tada će (valjda) biti kraj Quote Link to comment Share on other sites More sharing options...
trotter Posted September 13, 2016 Report Share Posted September 13, 2016 Pa dobro, haos je ocekivan iza ali pohvale za to sto se isti ne vidi u sobi. To za kraj ne da ti ne verujem nego svasta pricas i obmanjujes javnost 😁 Quote Link to comment Share on other sites More sharing options...
laky Posted September 13, 2016 Report Share Posted September 13, 2016 Cestitke za kuzmu jel moze neko kratko poredjenje. Quote Link to comment Share on other sites More sharing options...
Aurelijano Buendija Posted September 13, 2016 Report Share Posted September 13, 2016 41 minuta ranije, trotter said: Pa dobro, haos je ocekivan iza ali pohvale za to sto se isti ne vidi u sobi. To za kraj ne da ti ne verujem nego svasta pricas i obmanjujes javnost tri preampa (2xphono + line), jedna elektronska regulacija, par stepupa, možda još po neka zvučnica i biće kraj 34 minuta ranije, laky said: Cestitke za kuzmu jel moze neko kratko poredjenje. rano je za poređenje, gramofon svira tek sat vremena i to sa nerazrađenom BM Wood SL zvučnicom i Srogi Ref a na BM PP1 koja ide u line.. poređenje će biti teško izvodljivo a da bude i pošteno, obzirom da je sa desne strane situacija kompleksnija, da ne kažem složenija - tamo ima svašta nešto: 4Point + BM LPS + Tango stepup i Stogi 313 Ref VTA + Koetsu Black + Cotter stepup.. doduše sasvim je moguće - potrebne su samo dve iste ploče a selektorom se lako prebacuje.. preliminarno - sasvim lepo odoleva Quote Link to comment Share on other sites More sharing options...
aaa zmaju! Posted September 13, 2016 Report Share Posted September 13, 2016 Konacno, stereo Kuzma. Quote Link to comment Share on other sites More sharing options...
Aurelijano Buendija Posted September 13, 2016 Report Share Posted September 13, 2016 15 minuta ranije, aaa zmaju! said: Konacno, stereo Kuzma. jok: 2+1 Quote Link to comment Share on other sites More sharing options...
aaa zmaju! Posted September 13, 2016 Report Share Posted September 13, 2016 Auuuu! Quote Link to comment Share on other sites More sharing options...
