Nomimasen Posted April 21, 2015 Report Share Posted April 21, 2015 Ne priznajem zvucnike lakse od 30 kg Sa stalkom ili bez? Quote Link to comment Share on other sites More sharing options...
den!s Posted April 21, 2015 Report Share Posted April 21, 2015 Ne priznaje zvuÄnike koji se stavljaju na stalak, tj. kojima je stalak odvojen od kutije, tj. gde nije to sve vezano u jednu celinu, tj. zvuÄnike koji su manji pa moraju da se neÄim odignu od zemlje… TaÄnije, ne priznaje zvuÄnike koji nisu podnostojeći Quote Link to comment Share on other sites More sharing options...
Nomimasen Posted April 21, 2015 Report Share Posted April 21, 2015 Tako dakle. MalÄice sam radoznao, te bih priupitao uvaženog Älana koji je razlog tog nepriznavanja. Quote Link to comment Share on other sites More sharing options...
Delija Posted April 21, 2015 Report Share Posted April 21, 2015 Jer sam tako u mogucnosti Quote Link to comment Share on other sites More sharing options...
Nomimasen Posted April 21, 2015 Report Share Posted April 21, 2015 Vrlo dobro. Quote Link to comment Share on other sites More sharing options...
pantaNS Posted April 21, 2015 Report Share Posted April 21, 2015 Ja ne priznajem zvucnike koji su laksi i manji od mene Quote Link to comment Share on other sites More sharing options...
mac_edon4 Posted April 22, 2015 Report Share Posted April 22, 2015 Ja ne priznajem zvucnike koji su laksi i manji od mene Pricas za par ili po komadu? Quote Link to comment Share on other sites More sharing options...
sondek Posted April 22, 2015 Report Share Posted April 22, 2015 a sto bi kod nas u banatu rekli izes coveka bez metera Quote Link to comment Share on other sites More sharing options...
pantaNS Posted April 22, 2015 Report Share Posted April 22, 2015 Po komadu naravno, kakav je to zvucnik od 60 kila? Quote Link to comment Share on other sites More sharing options...
ab Posted April 22, 2015 Report Share Posted April 22, 2015 Sta znaju deca sta je 120kg? Jesi li se ti to malo dampirao? Quote Link to comment Share on other sites More sharing options...
Delija Posted April 22, 2015 Report Share Posted April 22, 2015 Polako ali sigurno propada... Quote Link to comment Share on other sites More sharing options...
ab Posted April 23, 2015 Report Share Posted April 23, 2015 ...dobro je dok je stereo, samo ne daj Boze da spadne na mono preko jednog zvucnika. Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted May 11, 2015 Report Share Posted May 11, 2015 Podigoh danas zvucnike nesto manje od 2 cm. kako bi linija izmedju visokog i basa bila sto pribliznija uhu na zamisljenoj horizontalnoj ravni. Treba jos cm. i kusur da bi bilo idealno ali i ovako je nevidjeno poboljsanje. Izuzetno je bitno pozicioniranje kutija po visini isto kao sto je to slucaj i po sirini i zakrivljenju kutija na unutra ili spolja. Neverovatno je kako ovakvi sitni potezi gotovo po pravilu dovode do poboljsanja u konacnom zvuku. Quote Link to comment Share on other sites More sharing options...
Delija Posted May 11, 2015 Report Share Posted May 11, 2015 To zavisi i od konkretnih zvucnika / driver-a. Kod nekih su benefiti lako cujni, kod drugih nisu. Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted May 11, 2015 Report Share Posted May 11, 2015 Tacno. Quote Link to comment Share on other sites More sharing options...
Father Posted May 13, 2015 Report Share Posted May 13, 2015 NeÅ¡to sam se zanimao, inspirisan idejom sa ogledalom u pozicioniranju prvih refleksija od prednje ploÄe do uÅ¡iju, pa neÅ¡to naÅ¡krabah ...? Na crtežu su dimenzije prostorije, iskotirane pozicije police i zvuÄnika. Polica je visine 60cm, nameÅ¡taj klasika visina 85cm, tepih vuneni debeo oko 2.5cm 300x200cm ... Visina plafona je 265cm stim Å¡to je plafon razbijen simetriÄnim spuÅ¡tenim plafonom za 12cm, pa ih nisam ovom analizom uzimao u obzir. Prvenstveno sam prouÄavao refleksije zidova. Zahvaljujem svima koji daju kreativne savete kako da bolje ili pravilnije pristupim oznaÄavanju mesta odbitaka. Ja sam ih za sada oznaÄio crvenim taÄkama, a žute linije pretstavljaju prve refleksije, plave njihove simetriÄne pravce, a ljubiÄaste zvuk koji ide iza zvuÄnika i odbija se od zida iza njih, dok su narandžaste simetrija primarne refleksije u nazad. OznaÄio sam L i R pravce koji do uva dolaze od izvora pomenute strane ... Napomena bi bila da zvuÄnici nemaju kutiju tj. "open baffle" su koncepcije. Pa zato i pravac suprotan od sluÅ¡anja. Simptomi! Kada postavim zvuÄnike idealno simetriÄne, pozicija sredine mi se pomeri neÅ¡to malo u desno, tako da Äim povuÄem levi zvuÄnik nekih 3 cm u nazad dobijam izrazito jasan fokus u sredini. TakoÄ‘e imam mali problem sa prizvukom betonske jeke u nekim momentima uglavnom sa desne strane, pa sam se odluÄio da poÄnem sa analizom difuzera i luÄnih ploÄa ... Crtež mi je donekle potvrdio da na desno uvo dolazi viÅ¡e refleksija, ali je baziran na pretpostavci "ogledala" kako se ti pravci traže i sigurno nisu pravi. Pa rekoh da podelim razmiÅ¡ljanje i problem sa forumom u nadi da ću pronaći pravi naÄin da reÅ¡im pomenute defekte. Pozdrav! Quote Link to comment Share on other sites More sharing options...
den!s Posted May 13, 2015 Report Share Posted May 13, 2015 OdliÄna pitanja, i mene zanima sliÄna tematika. A ono Å¡to mogu da uoÄim je da bi sluÅ¡aoc mogao malo napred. Možda je pola metra od zida malo? Quote Link to comment Share on other sites More sharing options...
Father Posted May 13, 2015 Report Share Posted May 13, 2015 Kompromis sa ukućanima. To je primarno dnevna soba pa je onda posvećena soba za sluÅ¡anje muzike, nažalost. Ipak sa pozicijom sam priliÄno zadovoljan, jer sam probao, doduÅ¡e ranijih godina i sa sedenjem bliže, ali nisam neÅ¡to zinuo, gubio mi se stage ambijent i neposrednost izvoÄ‘aÄa (ja ovde oni tamo).... Nemam pojma, možda probam ponovo bez stoÄića 80x80x28cm ispred troseda i dvoseda, koga btw zaboravih da ubacim u raÄunicu .... pa vidim Å¡ta biva? Quote Link to comment Share on other sites More sharing options...
TurboMaximus Posted May 13, 2015 Author Report Share Posted May 13, 2015 TepihÄina, za poÄetak. Quote Link to comment Share on other sites More sharing options...
trotter Posted May 13, 2015 Report Share Posted May 13, 2015 Ćale, pokuÅ¡aj da konkretno pitanje postaviÅ¡ ponovo. Nisam shvatio Å¡ta je glavni problem, beži zvuk na neku stranu, ili pitaÅ¡ uopÅ¡teno Å¡ta se preporuÄuje za datu prostoriju? Ako je ovo drugo, već si sam sebi odgovorio da postoje kompromisi sa ukućanima, pa, slaba vajda da doÄ‘eÅ¡ do idealnog reÅ¡enja pod takvim uslovima. Ako je ovo prvo, pojasni Å¡ta ti smeta. Quote Link to comment Share on other sites More sharing options...
Father Posted May 13, 2015 Report Share Posted May 13, 2015 Resen sam da koliko je moguce vise odstranim uticaj refleksija zidova na zadatu poziciju slusaoca. Planiram da sto je bolje izdizajniram preporucene difuzere/apsorbere tako da kompromis ne mora da se trazi, a problem je uglavnom sa jekom betonskih zidova, pa zelim to donekle da saniram. Pomeranje kanala sam resio danas, kada sam uvideo da mi polica nije paralelna sa fasadnim zidom, pa je shodno tome da sam ravnao zvucnike sa policom i doslo do bezanja ose osnovnih pravaca. Jedan kraj je bio blizi za 2.5cm. 100 mu muka! .... Dakle samo refleksije od zidova zelim da izdifuziram ili ublazim? Quote Link to comment Share on other sites More sharing options...
Father Posted May 13, 2015 Report Share Posted May 13, 2015 TepihÄina, za poÄetak. Sta sa tepihom, bez njega je kao u bazenu...? Sta predlazes kao zamenu? Pod mi je Tarketov laminat, nije bas umilan sa refleksijama! Quote Link to comment Share on other sites More sharing options...
Nomimasen Posted May 13, 2015 Report Share Posted May 13, 2015 Većinu stvari koje pominjeÅ¡ možeÅ¡ priliÄno dobro kontrolisati kućnim inventarom. Police sa knjigama, fotelje, slike na zidovima, biljke. RazliÄite kombinacije materijala. Uz malo gimnastike i pretumbavanja mogući su dobri rezultati. Betonski zidovi mogu biti problematiÄni. Od kakvog je materijala pod? StoÄići ili bilo kakve prepreke izmeÄ‘u mesta sluÅ¡anja i zvuÄnika u stanju su da naprave daleko viÅ¡e Å¡tete no refleksije koje pominjeÅ¡. Rad na položaju zvuÄnika može da unese kvalitativne pomake koje je nemoguće nadoknaditi drugim putem. Quote Link to comment Share on other sites More sharing options...
prophet Posted May 13, 2015 Report Share Posted May 13, 2015 Nešto sam se zanimao, Da li si pokušao da sistem zarotiraš za 90 stepeni i da ga postaviš na duži zid? Quote Link to comment Share on other sites More sharing options...
Father Posted May 13, 2015 Report Share Posted May 13, 2015 Jesam, pre mnogo godina ali to nije imalo veze sa zivotom. Kao da sam nabio glavu u tamburu. Nista dobro nisam cuo u takvoj postavci. Quote Link to comment Share on other sites More sharing options...
