D i g i t a L Posted December 14, 2014 Author Report Share Posted December 14, 2014 Jok i nisam.Ti znas komsija da smo spasili Ruse,jer je Eugen princ prebacen da ugusi republiku.Cela je Evropa pevala Lili Marlen,a mi nasu Od Topole..... . Nego proradi li Banu irDAC kako treba? Quote Link to comment Share on other sites More sharing options...
DejanM Posted December 14, 2014 Report Share Posted December 14, 2014 AirPlay je prakticna opcija, radi dobro ali podrzava najvise 16/48. Zato ako je Hi Res cilj, onda AirPlay nije najbolja opcija. Quote Link to comment Share on other sites More sharing options...
Dark Magician Posted December 14, 2014 Report Share Posted December 14, 2014 High-res ionako nema nikakve koristi, osim mastera ako je bolji, gde downsample neće niÅ¡ta odneti. A poÅ¡to nijedan snimak ne koristi dinamiÄki opseg ni 16-bit, 24-bit je traćenje prostora. Quote Link to comment Share on other sites More sharing options...
Iron man Posted December 14, 2014 Report Share Posted December 14, 2014 AirPlay je prakticna opcija, radi dobro ali podrzava najvise 16/48. Zato ako je Hi Res cilj, onda AirPlay nije najbolja opcija. AirPlay je vrlo praktican ali mi zvucno nije dorastao zadatku (bez da se provuce kroz externiDAC). Ima li nekih novosti u AirPlay produkciji? Koji sad DAC koriste? Quote Link to comment Share on other sites More sharing options...
Vlajo Posted December 14, 2014 Report Share Posted December 14, 2014 Nego proradi li Banu irDAC kako treba? Kaže da radi ! Quote Link to comment Share on other sites More sharing options...
Bane025 Posted December 14, 2014 Report Share Posted December 14, 2014 Radi,radi samo tako,svira da ne poverujeÅ¡ . PoruÄio sam i napajanje od komÅ¡ije @impulsa.. ! ....jedina stvar koju ne uspevam je da pustim izvorni 176,4 khz ,kako je kod vas ? Ja sam dosad "naiÅ¡ao" na samo 2 takva izdanja..sve ostalo klizi ko podmazano... Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted December 14, 2014 Author Report Share Posted December 14, 2014 Na zalost irDAC ne moze da pusti 176.4.Podesi ovde 88.2 ili 44.1 i to je vise nego dovoljno. I naravno ako nemas (a verujem da imas) plugin za foobar http://sourceforge.net/projects/sacddecoder/ Quote Link to comment Share on other sites More sharing options...
prophet Posted December 14, 2014 Report Share Posted December 14, 2014 Radi,radi samo tako,svira da ne poverujeÅ¡ . PoruÄio sam i napajanje od komÅ¡ije @impulsa.. ! ....jedina stvar koju ne uspevam je da pustim izvorni 176,4 khz ,kako je kod vas ? Ja sam dosad "naiÅ¡ao" na samo 2 takva izdanja..sve ostalo klizi ko podmazano... Ne podržava 176,4. Supported sample rates: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz Ovo Å¡to je digital naveo važi samo za sacd.iso Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted December 14, 2014 Author Report Share Posted December 14, 2014 Vazi za sve fajlove koji idu preko ovog plugina DSDIFF i DSF(raspakovani ISO). Quote Link to comment Share on other sites More sharing options...
Bane025 Posted December 14, 2014 Report Share Posted December 14, 2014 Hvala Ljubiša,evo stoji tako na 88.2 khz u pluginu i fino gura Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted December 14, 2014 Author Report Share Posted December 14, 2014 Nema na cemu druze. PoruÄio sam i napajanje od komÅ¡ije @impulsa.. ! Kad stigne napajanje i sve se to "slegne",usvira bice to veoma lep sistem. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted December 14, 2014 Report Share Posted December 14, 2014 Čekam da vidim da li će napajanje biti lepše od mog. Ako bude - idem u Sombor na pecanje ... Quote Link to comment Share on other sites More sharing options...
Jimmy_92 Posted December 26, 2014 Report Share Posted December 26, 2014 Imam jedno pitanje, nesto cudno se desava sa DAC-om ili napajanjem. POceo je da se gasi, tipa u sred pesme se ugasi bukvalno na jednu sekundu (samo cakne) i ponovo se upali kao da nista nije bilo. Eksterno napajanje je upaljeno kao i obicno. Ne znam u cemu je frka, ovo je od juce pocelo da se desava i desava se relativno cesto. Pomagajte Quote Link to comment Share on other sites More sharing options...
Alexandar Posted December 26, 2014 Report Share Posted December 26, 2014 Ako je nov i u garanciji, zovi Simu, on ce najbolje da ti pomogne. Mada, moze biti i do transporta. Narocito ako je vezan USB-om. Probaj na svim ulazima, cisto da to eliminises. Quote Link to comment Share on other sites More sharing options...
Jimmy_92 Posted December 26, 2014 Report Share Posted December 26, 2014 Ma da, nov je i imam papire. I na usb-u je, nemam uslova da ga probam na drugim ulazima... Quote Link to comment Share on other sites More sharing options...
nino69 Posted December 26, 2014 Report Share Posted December 26, 2014 Probaj ti za poÄetak drugi USB kabel, meni se isto na Pioneeru znalo dogoditi da odjednom prestane svirati (s HDD-a). Stavio drugi kabel i sve ok. Ne bi se baÅ¡ trebao ugasiti kada ima svoje napajanje, ali tko zna. Quote Link to comment Share on other sites More sharing options...
SUROKVL Posted December 26, 2014 Report Share Posted December 26, 2014 A da nije onaj isti problem sa strujom koji si imao ranije sa Sedrom ?! Quote Link to comment Share on other sites More sharing options...
Jimmy_92 Posted December 26, 2014 Report Share Posted December 26, 2014 Ajde pribacu i to mada dadoh silne pare za usb, ne ide da ga menjam i ako je do njega. Mada to opet ne odjasnjava zasto se to sad desava posle toliko vremena sa istim komponentama i podesavanjima!? A ako je problem sa strujom to he izvan mojih moci, kao sto sam i sedru morao da promenim zbog toga... Quote Link to comment Share on other sites More sharing options...
durd Posted December 26, 2014 Report Share Posted December 26, 2014 Meni se to desavalo pre oko godinu ili dve dana , samo cakne par puta dnevno, i tako nedelju dana , i posle odjednom prestalo... pripisao sam to losem naponu u kraju. nisam saznao da li je do daca ili je komp prekidao signal... Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted December 26, 2014 Author Report Share Posted December 26, 2014 Naljutio si Malishana,reko si da je vrtilica bolja.Sad protestuje,nece da svira.Mnogo je osetljive prirode,nisi trebo da ga ljutis. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted December 26, 2014 Report Share Posted December 26, 2014 Ja ne smem da Äitam ovo o irDac kliktanju ... Jeste li sigurni da je mom autu dobro ... Moram ovog mog ljubimca da uÅ¡uÅ¡kam bolje, zima se pojaÄala, pa da se ne na'ladi ... Quote Link to comment Share on other sites More sharing options...
Jimmy_92 Posted December 26, 2014 Report Share Posted December 26, 2014 Znaci moram da cekam da prodje.. Quote Link to comment Share on other sites More sharing options...
Jimmy_92 Posted December 28, 2014 Report Share Posted December 28, 2014 Hoce li neko da mi pomogne oko ovog studanja dac-a, ne prestaje? Quote Link to comment Share on other sites More sharing options...
peterson Posted December 28, 2014 Report Share Posted December 28, 2014 Ja sumnjam na ta divlja napajanja koja koristite. Quote Link to comment Share on other sites More sharing options...
trotter Posted December 28, 2014 Report Share Posted December 28, 2014 Koji OS je na racunaru? Laptop ili desktop? Ako je laptop, probaj sledeće: "Ok I got it. It's a windows 7 glitch and explains why my old PC was fine as it ran on XP..... So go into control panel and set the power options to show additional plans and select High Performance. Next, choose Never for when the PC goes to sleep. Then set your CPU to allow background processing. Worked a treat for me, and I would like to thank Matthew Neighbour at Arcam for pointing me in the right direction." Znam da je Äudno Å¡to je do skoro sve radilo bez problema ali probaj, bar da precrtaÅ¡ ovo citirano, ako nije to. MožeÅ¡ prvo da reinstaliraÅ¡ drajver pre toga (deinstall, reboot, instalacija drajvera, reboot), Quote Link to comment Share on other sites More sharing options...
