Krca44 Posted December 18, 2019 Report Share Posted December 18, 2019 31 minutes ago, vrobec said: Valjda neće vraćati paket u US. Nadam se da ces nesto postici i dobiti naruceno. Mozda tvoj drugar cija je adresa navedena pozove lokalni UPS koji treba a mu dostavi ? Ne znam da li ce pomoci, svakako ti zelim srecu. Quote Link to comment Share on other sites More sharing options...
banebg81 Posted December 18, 2019 Report Share Posted December 18, 2019 Zašto ne kupujete delove u Srbiji? Quote Link to comment Share on other sites More sharing options...
Krca44 Posted December 18, 2019 Report Share Posted December 18, 2019 Kupujem ali masa toga nema. Wima FKP2 nema niko npr. Trazio sam ih u jedno 15 ili vise prodavnica, niko ih nije imao letos ( to mi je trebalo, na onome sto radim nema mesta nizasta drugo ). 0,1% otpore, ako mi se hoce da platim i stavim, ko ima ? Gde da nadjem Nichicon ili Rubycon kondove ili Elna ako bas hocu ? Sta ima to kupujem a sta nema moram da kupim preko. Drugo su pojave falsh delova. Donose se i prodaju falsh Rubycon i drugi kondovi 200uF/400V i 330uF/400V npr. proverio sam, falsh su iako navodno nisu losi. Meni je mnogo zgodnije da pazarim u lokalu ali ako postoji potreba ( ili ja smatram da postoji ) a delova nema ovde... narucicu iz inostranstva. Quote Link to comment Share on other sites More sharing options...
banebg81 Posted December 18, 2019 Report Share Posted December 18, 2019 ima sve... Quote Link to comment Share on other sites More sharing options...
Krca44 Posted December 18, 2019 Report Share Posted December 18, 2019 (edited) Da mi je znati koja je to prodavnica, ne prepoznajem ovako... Edited December 18, 2019 by Krca44 Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted December 18, 2019 Report Share Posted December 18, 2019 1 sat ranije, banebg81 said: Zašto ne kupujete delove u Srbiji? Ко не купује? Quote Link to comment Share on other sites More sharing options...
banebg81 Posted December 18, 2019 Report Share Posted December 18, 2019 Vidim da ljudi poručuju, snalaze se, u Mađarskoj, aliexpress ... Quote Link to comment Share on other sites More sharing options...
Spachek Posted December 18, 2019 Report Share Posted December 18, 2019 Nichicon ima i kod Tomehttps://www.kupujemprodajem.com//Elektronika-i-komponente/Kondenzatori/Nichicon-specijalno-za-Audio-serije-UFW-UFG-itd--64209038-oglas.htmSent from my SM-A520F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Krca44 Posted December 18, 2019 Report Share Posted December 18, 2019 Nije bas da sam ih trazio ovde, Ruby i Nichicon, samo sam primetio da ih nema u prodavnicama gde sam kupovao i slucajno sam njima popunio minimum neki kod Farnell-a. Otpora MF 0207 1% imam dve kese pune, njih ima po svim nasim radnjama, meni je primarna bila nabavka ovako necega : https://uk.farnell.com/holsworthy-te-connectivity/h847k5bya/res-47k5-0-10-250mw-axial/dp/1751623 https://uk.farnell.com/neohm-te-connectivity/yr1b100rcc/res-100r-0-10-250mw-axial/dp/1083143 Eto zanima me sta ce biti kad se naprave dva ista aparata, jedan sa sitnom boranijom i drugi sa malo boljim elementima. Quote Link to comment Share on other sites More sharing options...
Father Posted December 19, 2019 Report Share Posted December 19, 2019 Evo nešto zanimljivo na šta sam naleteo tražeći gde imaju da se kupe. Allen Bradley RESISTORS special treatment methodAs stated Allen Bradley resistors are carbon composite, being made of an organic material they do have the tendency to absorb water from the atmosphere. This absorption can increase the actual resistance of the component, hence the slightly higher than normal tolerance published on this page. To fix this simply remove the water from the component and seal it. The best method is to place the resistor/s on a baking tray, set your oven to 80 degrees centigrade and leave in the oven for 8 hours. The secret is to remove the mositure slowly if you rush it it will become noisy in circuit. Once cooked seal the body of the component in Shellack (preferably the flakes) to stop any further water absorption. At the end of this procedure you will have a much lower noise, more closely tolerance resistors. Special thanks to Colin Cornish for this excellent tip. https://www.hificollective.co.uk/components/allen_bradley_resistors.html Quote Link to comment Share on other sites More sharing options...
mutayu Posted December 19, 2019 Report Share Posted December 19, 2019 4 hours ago, Father said: Evo nešto zanimljivo na šta sam naleteo tražeći gde imaju da se kupe. Rusi to zovu "tropikalizacija" , priprema za podrucja ekstremno tople, hladne ili vlazne klime. Pored niza dodatnih mera podrazumeva i ovo o cemu govoris. U DIY praksi dovoljno je sve elemente dobro isusiti i onda tacke gde nozice ulaze u kucista zaliti epoksi smolom. Kucista su vec od smole, plasticna ili metalna a nozice kalajisane tako da preostaje samo da se spreci prodor vlage prema unutrasnjosti elementa. Quote Link to comment Share on other sites More sharing options...
Father Posted December 19, 2019 Report Share Posted December 19, 2019 43 minuta ranije, mutayu said: Rusi to zovu "tropikalizacija" Imaju li Rusi neke otpornike ekvivalentnog kvaliteta i tehnološkog procesa izrade kao Allen Bradley carbon composite? Quote Link to comment Share on other sites More sharing options...
Solderer Posted December 19, 2019 Report Share Posted December 19, 2019 Карбон композитни отпорници су превазиђена технологија израде јер имају велика мерна изобличења и висок шум. Пре свега због лошег контакта металних извода и гранулираног угљена од којих су израђени ( диода ефект). Данас се употребљавају само код неких гитарских појачала где се намески жели добити одређени звук у смислу веће агресивности и дисторзије, значи креативно а не неутрално. Неки љубитељи цевних уређаја субјективно преферирају изобличења која они пружају. За хај-фај уређаје данас нема разлога не користити метал филм отпорнике. И карбон филм отпорници имају много боље особине од карбон композитних отпорника. Quote Link to comment Share on other sites More sharing options...
Father Posted December 19, 2019 Report Share Posted December 19, 2019 7 minuta ranije, Solderer said: За хај-фај уређаје данас нема разлога не користити метал филм отпорнике. И карбон филм отпорници имају много боље особине од карбон композитних отпорника. Kakva su vaša iskustva sa metal oksid otpornicima tipa 1W, 2W, jer su se meni subjektivno pokazali izvanredni baš u phono preampu. Nisam ih poredio sa ova dva koja navodite. Čisto me zanima kakvo je vaše iskustvo u poređenju sa metal filmom ili karbon filmom. Quote Link to comment Share on other sites More sharing options...
Solderer Posted December 19, 2019 Report Share Posted December 19, 2019 1 minut ranije, Father said: Kakva su vaša iskustva sa metal oksid otpornicima tipa 1W, 2W, jer su se meni subjektivno pokazali izvanredni baš u phono preampu. Nisam ih poredio sa ova dva koja navodite. Čisto me zanima kavo je vaše iskustvo u poređenju sa melaf filmom ili karbon filmom. Метал оксид отпорници се другачије називају Thick-film отпорници, и направљени су од истог матерјала као и већина СМД отпорника, тамо где није наведено да су Thin film. Thin film SMD и метал филм са изводима су у суштини исти отпорници. Код метал оксида отпорни филм се наноси механички у виду танког слоја пасте. Код метал филма се наноси на керамичко тело у вакууму путем пара металног отпорног матерјала где је слој нанешен много компактније и швршћи. Зато они имају мањи шум од метал оксид типова. Метал оксид отп. се користе на мање критичним местима где се тражи већа снага ( обарање напона нпр.) а не на путу аудио сигнала јер уносе шум. Сада се и метал филм отпорници производе у већим снагама. Карбон филм отпорнике данас нема смисла користити када су цене метал филм отп. изузетно ниске. Булк фоил отпорниси се састоје од отпорне фолије која се ласерски тримује на потребну вредност, и ти отпорници имају убедљиво најбоље, готово идеалне карактеристике. Мана им је изузетно висока цена. Вреди их испробати само на пар места у аудио колима ( отпорници у фидбеку)-. Упоређивао сам их са врхунским метал филмом ( Велвин ) и није било неке велике разлике. Quote Link to comment Share on other sites More sharing options...
Father Posted December 19, 2019 Report Share Posted December 19, 2019 Hvala @Solderer , vrlo je korisno to znati. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted December 19, 2019 Report Share Posted December 19, 2019 Father carbon otpori se koriste za restauraciju starih radio aparata i eventualno cevnih pojacala, tamo nekih 50-60-ih su bili maltene standardna tehnologija. To se radi da se ocuva shmek koji stari aparat ima i eventualno se koriste za ono sto Solderer vec navede. Quote Link to comment Share on other sites More sharing options...
Father Posted December 19, 2019 Report Share Posted December 19, 2019 11 minuta ranije, Krca44 said: To se radi da se ocuva shmek koji stari aparat ima Možda su i tajne velikih majstora. Treba imati otvoren um. Allen-Bradley nisu obični ugljenični otpornici. Quote Link to comment Share on other sites More sharing options...
mutayu Posted December 19, 2019 Report Share Posted December 19, 2019 9 hours ago, Father said: Imaju li Rusi neke otpornike ekvivalentnog kvaliteta i tehnološkog procesa izrade kao Allen Bradley carbon composite? Nisam razumeo pitanje. Quote Link to comment Share on other sites More sharing options...
Father Posted December 20, 2019 Report Share Posted December 20, 2019 7 sati ranije, mutayu said: Nisam razumeo pitanje. Nije ni važno, pomislio sam da možda poznaješ rusku proizvodnju elektronskih komponenti pa da znaš neki njihov "carbon composite" otpornik istih ili boljih karakteristika kao Allen-Bradley. Nešto kao, oni njihovi papiri u ulju što su dugo bili popularni kod samograditelja kod nas. Quote Link to comment Share on other sites More sharing options...
ab Posted December 20, 2019 Report Share Posted December 20, 2019 4 minuta ranije, Father said: Nije ni važno, pomislio sam da možda poznaješ rusku proizvodnju elektronskih komponenti pa da znaš neki njihov "carbon composite" otpornik istih ili boljih karakteristika kao Allen-Bradley. Nešto kao, oni njihovi papiri u ulju što su dugo bili popularni kod samograditelja kod nas. Да ли причамо и даље о отпорницима? Quote Link to comment Share on other sites More sharing options...
Zexx Posted December 20, 2019 Report Share Posted December 20, 2019 16 minuta ranije, Father said: Nije ni važno, pomislio sam da možda poznaješ rusku proizvodnju elektronskih komponenti pa da znaš neki njihov "carbon composite" otpornik istih ili boljih karakteristika kao Allen-Bradley. Nešto kao, oni njihovi papiri u ulju što su dugo bili popularni kod samograditelja kod nas. Zna CIA... https://www.cia.gov/library/readingroom/docs/CIA-RDP80-00809A000700030074-5.pdf Quote Link to comment Share on other sites More sharing options...
mutayu Posted December 20, 2019 Report Share Posted December 20, 2019 8 minutes ago, Father said: Nije ni važno, pomislio sam da možda poznaješ rusku proizvodnju elektronskih komponenti pa da znaš neki njihov "carbon composite" otpornik istih ili boljih karakteristika kao Allen-Bradley. Nešto kao, oni njihovi papiri u ulju što su dugo bili popularni kod samograditelja kod nas. Bor-Ugljenicni otpornici serije "БЛП" su bili daleko bolji od Allen-Bradley otpornika. Medjutim kao i Allen-Bradley nisu vise u proizvodnji i tesko ih je nabaviti. Mozes i sam da se uveris u karakteristike: Allen-Bradley https://hfc-fs.s3-eu-west-1.amazonaws.com/s3fs-public/allen_bradley_data_sheet.pdf БЛП http://www.155la3.ru/datafiles/blp_blpa_tu_1975.pdf Ako te zanima aktuelna proizvodnja visokokvalitetnih otpornika pogledaj sledeci link: https://www.erkon-nn.com/products/axial-lead-resistors Ako ti trebaju precizni otpornici male tolerancije preporuka je serija R-126A. Quote Link to comment Share on other sites More sharing options...
Father Posted December 20, 2019 Report Share Posted December 20, 2019 Hvala, proslediću drugaru na uvid, koji mi je napunio glavu na temu Allen-Bradly otpornika. Možda proba i Bor-Ugljenicne otpornike serije "БЛП", ako ih nađe negde. Quote Link to comment Share on other sites More sharing options...
mutayu Posted December 20, 2019 Report Share Posted December 20, 2019 Ako vec gledas na hifi collective gledaj Shinkoh otpornike. Quote Link to comment Share on other sites More sharing options...
