shon3i Posted June 14, 2022 Report Share Posted June 14, 2022 https://novi.kupujemprodajem.com/audio/pretpojacala/fx-audio-tube-03-tube-mini-lampasko-predpojacalo/oglas/120392782 Ovako nesto bi zavrsilo posao Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted June 14, 2022 Report Share Posted June 14, 2022 24 minuta ranije, Zexx said: @giZ_Mo nemoj slučajno da se zahebeš da napišeš neku smislenu rečenicu dužu od proste Немој случајно да ти нешто промакне! Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted June 14, 2022 Report Share Posted June 14, 2022 28 minuta ranije, Bendtner said: Mada ne znam da li će tako preko izlaza za slušalice nešto da se promeni. Бар ће се малко појачати Quote Link to comment Share on other sites More sharing options...
Bendtner Posted June 14, 2022 Report Share Posted June 14, 2022 Ok, nisam rekao da neće, već da ne znam da li će. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted June 14, 2022 Report Share Posted June 14, 2022 10 minuta ranije, shon3i said: I da ima zaseban phono output, imao bi problem jer je u pitanju keramicka glava Koja je opet razlicita od MM/MC glava i trazi zaseban preamp. Ovde jedino na ovaj izlaz za sluske ili neki preamp liniskog levela. Pa čovek je uštekao u linijski ulaz na pojačalu i rekao da mu tako radi tiho? Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted June 14, 2022 Report Share Posted June 14, 2022 ..... Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted June 14, 2022 Report Share Posted June 14, 2022 Цео проблем је у типу главе што је и препаметном @Zexx промакло! Quote Link to comment Share on other sites More sharing options...
shon3i Posted June 14, 2022 Report Share Posted June 14, 2022 12 minuta ranije, srdjan_cvetkovic said: Pa čovek je uštekao u linijski ulaz na pojačalu i rekao da mu tako radi tiho? Pa na linijski jedino i moze, ali izgleda da taj predpojacivac nije bas glasan na izlazu, sto i ne cudi. Mada opet gledano predlozeni Analogis ima jak output, dok recimo mnogi phono preampovi imaju dosta tih izlaz. Sa time sto ovde analogis ne moze, vec treba liniski pojacivac, ili pojacivac za sluske. Quote Link to comment Share on other sites More sharing options...
Delija Posted June 14, 2022 Report Share Posted June 14, 2022 Da li stvarno mislite da ima smisla ista ocekivati od "gramofona" od 70 dolara? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted June 14, 2022 Report Share Posted June 14, 2022 1 minut ranije, Delija said: Da li stvarno mislite da ima smisla ista ocekivati od "gramofona" od 70 dolara? Видех то чудо уживо, и ено га у деловима, шалим се Ја не. Quote Link to comment Share on other sites More sharing options...
Zexx Posted June 14, 2022 Report Share Posted June 14, 2022 50 minuta ranije, giZ_Mo said: Цео проблем је у типу главе што је и препаметном @Zexx промакло! Nije propao onaj što se kockao nego onaj što se vadio, džabe ti sad naknadna pamet i kačenje screenshot-ova... Quote Link to comment Share on other sites More sharing options...
agnostic_Nik Posted June 14, 2022 Author Report Share Posted June 14, 2022 1 hour ago, shon3i said: https://novi.kupujemprodajem.com/audio/pretpojacala/fx-audio-tube-03-tube-mini-lampasko-predpojacalo/oglas/120392782 Ovako nesto bi zavrsilo posao а мислиш да оно Analogis (https://www.kupujemprodajem.com/audio/gramofoni-delovi-i-oprema/riaa-gramofonsko-pretpojacalo-analogis-8990422/oglas/127339400) не би одрадило посао? Пробао сам повезивање на линију преко phono (headphones) излаза, али још се слабије чује. Мислим да дефинитивно треба неко грамофонско претпојачало, само је остало питање да ли би ово Analogis задовољило? Quote Link to comment Share on other sites More sharing options...
Bendtner Posted June 14, 2022 Report Share Posted June 14, 2022 53 minutes ago, Delija said: Da li stvarno mislite da ima smisla ista ocekivati od "gramofona" od 70 dolara? U NS stvarno samo programeri i kavčani. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted June 14, 2022 Report Share Posted June 14, 2022 24 minuta ranije, Zexx said: Nije propao onaj što se kockao nego onaj što se vadio, džabe ti sad naknadna pamet i kačenje screenshot-ova... Реци да се шалиш! Quote Link to comment Share on other sites More sharing options...
shon3i Posted June 14, 2022 Report Share Posted June 14, 2022 23 minuta ranije, agnostic_Nik said: а мислиш да оно Analogis (https://www.kupujemprodajem.com/audio/gramofoni-delovi-i-oprema/riaa-gramofonsko-pretpojacalo-analogis-8990422/oglas/127339400) не би одрадило посао? Пробао сам повезивање на линију преко phono (headphones) излаза, али још се слабије чује. Мислим да дефинитивно треба неко грамофонско претпојачало, само је остало питање да ли би ово Analogis задовољило? Ne moze Analogis jer on je predpojacivac phono signala. Phono u Line nivo. Tvoj gramofon vec isporucujue LIne nivo. Druga stvar sto phono predpojacivaci kakav je analogis ( a i svi phono predpojacivaci) ne samo sto pojacavaju signal vec imaju i RIAA ekvilajzer koji bustuje baseve i stisava visoke, tako da kad bi ovaj linijski signal koji izlazi iz gramofona pojacali analogisom dobili bi ste jak zvuk ali skroz izoblicen i pun distorzija najverovatnije. Ja imam Analogis predpojacivac i on je za te pare odlican, ali gramofon mora imati Phono izlaz i zvucnica mora biti Moving Magnet da bi to radilo. To je problem broj dva na ovom gramofonu sto dolazi sa keramickom iglom i za njega treba drugi vid predpojacivaca ako bi islo na phono izlaz. Posto je ovo vec Liniski izlaz znaci za sve tipove LINE - IN, AUX, TAPE ulaza. ostaje jedina opcija nabaviti Linisko pojacalo (sto se moze nabaviti ukljucujuci i ovo fensi sa lampama) ali verovatno na aliekspresu i ebay-u moze za sitne pare da se nabavi nesto sto ce imati potenciometar. Druga opcija je mikseta, treca opcija je pojacalo za slusalice. Takodje treba probati kao sto je predlozeno povezati iz ovog izlaza za slusalice sa gramofona u LINE - IN za to treba 3.5mm sa jedne strane a sa druge 2xRCA kabal (klasican) tu se verovatno mozda dobije malo glasniji signal. Quote Link to comment Share on other sites More sharing options...
agnostic_Nik Posted June 14, 2022 Author Report Share Posted June 14, 2022 знам да је керамичка звучница... кад си рекао: "Takodje treba probati kao sto je predlozeno povezati iz ovog izlaza za slusalice sa gramofona u LINE - IN za to treba 3.5mm sa jedne strane a sa druge 2xRCA kabal (klasican) tu se verovatno mozda dobije malo glasniji signal" то сам већ пробао као што сам рекао, из phono излаза (3.5mm) у RCA на мом Microlab FC330 и звук је још слабији. Једино сам заборавио исто то урадити али спојити на моју Samsung линију, али мислим да би било исто као и са Microlab-ом. Quote Link to comment Share on other sites More sharing options...
shon3i Posted June 14, 2022 Report Share Posted June 14, 2022 Da li u tom slucaju utice Volume potenciometar ? Ili je on samo za integrisane zvucnike ? Ako je tako onda samo neki predpojacivac ali linijskog signala moze da spasi situaciju ili neka mikseta ili sta god sto pojacava liniski signal Quote Link to comment Share on other sites More sharing options...
agnostic_Nik Posted June 15, 2022 Author Report Share Posted June 15, 2022 17 hours ago, shon3i said: I da ima zaseban phono output, imao bi problem jer je u pitanju keramicka glava Koja je opet razlicita od MM/MC glava i trazi zaseban preamp. Ovde jedino na ovaj izlaz za sluske ili neki preamp liniskog levela. да ли је онда боље ово претпојачало за мој грамофон?https://www.kupujemprodajem.com/audio/pretpojacala/pp500-phono-pream-plifier-novo-uvoz-swiss/oglas/138388217?filter_id=1456700113 Quote Link to comment Share on other sites More sharing options...
agnostic_Nik Posted June 15, 2022 Author Report Share Posted June 15, 2022 14 hours ago, shon3i said: Da li u tom slucaju utice Volume potenciometar ? Ili je on samo za integrisane zvucnike ? Ako je tako onda samo neki predpojacivac ali linijskog signala moze da spasi situaciju ili neka mikseta ili sta god sto pojacava liniski signal Погледај шта сам добио као одговор од Denver support-a кад сам их питао да ли би било добро оно Analogis претпојачало за мој грамофон. Шта је он сад ту тачно мислио? Да спојим ово Analogis preamplifier на излаз за слушалице? Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted June 15, 2022 Report Share Posted June 15, 2022 Iskreno, pos***m im se na gramofon i pametnog koji ga je ovako smislio. Quote Link to comment Share on other sites More sharing options...
Delija Posted June 15, 2022 Report Share Posted June 15, 2022 Za te pare nemas ni igracku za (@Bendtner mafijasku) decu, tako da... Quote Link to comment Share on other sites More sharing options...
shon3i Posted June 15, 2022 Report Share Posted June 15, 2022 1 sat ranije, agnostic_Nik said: Погледај шта сам добио као одговор од Denver support-a кад сам их питао да ли би било добро оно Analogis претпојачало за мој грамофон. Шта је он сад ту тачно мислио? Да спојим ово Analogis preamplifier на излаз за слушалице? Pa on covek misli ne preko izlaza za slusalice vec preko cinceva da tu povezes analogis ali je napomenuo da se koristi phono output. ali gledajuci ono upustvo gramofona izgleda da nemas mogucnost da prebacis na phono Mnogi ti gramofoni. bar sam ja vidjao na RCA (cinc) izlazima imaju mogucnost biranja da li ce signal biti phono ili liniski, obicno tu negde bude prekidac kojim se to regulise. u tom slucaju ako kod tebe ima taj prekidac trebas ga saviti u phono polozaj i na taj nacin ce signal zaobilaziti interni preamp i onda mozes da ides na eksterni predpojacivac kakav je analogis. Opet kad tako povezes zvuk verovatno nece biti naoptimalniji jer je keramicka zvucnica u pitanju i koliko se secam zvuk ce biti plitak. setih se da sam gledao ovaj video tu je sve objasneno https://www.youtube.com/watch?v=3nsPGILzrRs Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted June 15, 2022 Report Share Posted June 15, 2022 1 sat ranije, agnostic_Nik said: Шта је он сад ту тачно мислио? Искрено тај Мортен је тешки шабан 😁 Quote Link to comment Share on other sites More sharing options...
Nixie Posted June 15, 2022 Report Share Posted June 15, 2022 Nešto mi nije jasno, može li to da se pojača koliko treba za normalno slušanje, bez obzira gde je položaj potenciometra za jačinu? Znači jel u max. položaju potenciometra dovoljno glasno ili nije? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted June 15, 2022 Report Share Posted June 15, 2022 Тол'ко o Denver фирми Quote Link to comment Share on other sites More sharing options...
