zek Posted July 19, 2020 Report Share Posted July 19, 2020 1 sat ranije, Darth Maul said: која верзија MacMini-ја би била добра Jedna od ove dve varijante, jer mogu da se lako otvore i zamene HDD i doda memorija po želji: Mac mini "Core i7" 2.3 (Late 2012) sa Intel Core I7-3615QM Mac mini "Core i7" 2.6 (Late 2012) sa Intel Core I7-3720QM Link to comment Share on other sites More sharing options...
sondek Posted July 19, 2020 Report Share Posted July 19, 2020 Kako to mislis opticki audio kroz 3.5mm jack? Link to comment Share on other sites More sharing options...
zek Posted July 19, 2020 Report Share Posted July 19, 2020 1 minut ranije, sondek said: Kako to mislis opticki audio kroz 3.5mm jack? Ovako Link to comment Share on other sites More sharing options...
Darth Maul Posted July 19, 2020 Report Share Posted July 19, 2020 @zek Хвала пуно друг! @sondek Ево изворни пост: "Pretty much all recent Macs that have a 3.5mm jack is capable of digital audio output, it is in S/PDIF signal but in the form of mini TOSLINK connector. The 3.5mm jack is double duty for regular analog in/out as well which is why most people are confused by this fact." Значи колико ја разумем на једном крају интерконект кабла је 3.5мм, а на другом крају је оптички прикључак. А сам излаз може да пропусти S/PDIF сигнал. Link to comment Share on other sites More sharing options...
sondek Posted July 19, 2020 Report Share Posted July 19, 2020 Kabl je ujedno i digitalni i analogni.Ako ide na dac provodi digitalni,ako ide na amp onda analogni audio signal.Optickim se svakako ne vodi audio signal vec kako i pise digital audio signal. Link to comment Share on other sites More sharing options...
Spachek Posted July 19, 2020 Report Share Posted July 19, 2020 Bas kao i Chromecast audioSent from my SM-A520F using Tapatalk Link to comment Share on other sites More sharing options...
TurboMaximus Posted July 19, 2020 Report Share Posted July 19, 2020 3 sati ranije, shon3i said: Nekih 30-40cm trenutno je otprilike, ako mi verujes nemam metar pri ruci da bi izmerio tacno.. Hvala. Link to comment Share on other sites More sharing options...
zek Posted July 19, 2020 Report Share Posted July 19, 2020 2 sati ranije, sondek said: Kabl je ujedno i digitalni i analogni Nije i ne može biti, samo je 3,5mm konektor zajednički za analognu bananicu od 3,5mm ili optički kabl sa 3,5mm konektorom kao gore na slici. Link to comment Share on other sites More sharing options...
zek Posted July 19, 2020 Report Share Posted July 19, 2020 2 sati ranije, Darth Maul said: Значи колико ја разумем на једном крају интерконект кабла је 3.5мм, а на другом крају је оптички прикључак. Na oba kraja je optički priključak, samo je oblik drugačiji zbog konekcije. Link to comment Share on other sites More sharing options...
Darth Maul Posted July 19, 2020 Report Share Posted July 19, 2020 @zek Да да тако сам и ја закључио да је оптички на оба краја али што на једном крају има тај 3.5мм конектор. Тако да видим да ће MacMini радити посао баш како треба. Link to comment Share on other sites More sharing options...
Delija Posted July 19, 2020 Report Share Posted July 19, 2020 2 sati ranije, sondek said: Kabl je ujedno i digitalni i analogni.Ako ide na dac provodi digitalni,ako ide na amp onda analogni audio signal.Optickim se svakako ne vodi audio signal vec kako i pise digital audio signal. Iskoriscena je ista "crna rupa" za dve stvari I na mojoj matoroj ASUS Xonar STX zvucnoj karti je na istom konektoru i opticki i koaksijalni digitalni izlaz. Sa odgovarajucim adapterom (napomena - to nije konverter!) se bira zeljeni izlaz - ovde su cak i oba aktivna u isto vreme. Link to comment Share on other sites More sharing options...
sondek Posted July 19, 2020 Report Share Posted July 19, 2020 17 minuta ranije, zek said: Nije i ne može biti, samo je 3,5mm konektor zajednički za analognu bananicu od 3,5mm ili optički kabl sa 3,5mm konektorom kao gore na slici. Ma jasno,opticki kabl je sasvim drugaciji.mislio sam na ulaz,lapsus. Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
