giZ_Mo Posted May 11, 2012 Report Share Posted May 11, 2012 O kojoj??? Овој Quote Link to comment Share on other sites More sharing options...
Pavlaka Posted May 11, 2012 Report Share Posted May 11, 2012 Овој Ha-ha-ha-ha-ha....Strava! Quote Link to comment Share on other sites More sharing options...
suca77 Posted May 11, 2012 Report Share Posted May 11, 2012 O kojoj??? Upss zaboravi da okacim - evo - Sory... http://www.kupujemprodajem.com/Dual-C-830-2080473-oglas.htm?filter_id=7814119 Quote Link to comment Share on other sites More sharing options...
Retro-Man Posted May 13, 2012 Report Share Posted May 13, 2012 Dual C-830 je kvalitetan dek, napravljen je kao tenk, pouzdan i dugotrajan no ima jedan problem, u mehanici postoji jedan oveÄi zupÄanik koji se zna izvitoperiti ili se zupci orune pa je to onda gotovo nepopravljivo, prije par mijeseci sam nabavio taj dek i imao sam sreÄe da je mehanika i sve ostalo bilo u savrÅ¡enom stanju, bilo je potrebno zamjeniti remenje i napraviti klasiÄno ÄiÅ¡Äenje i podmazivanje. Quote Link to comment Share on other sites More sharing options...
aco Posted May 13, 2012 Report Share Posted May 13, 2012 U pitanju je dek Pioneer ct 757 kada se premotava kaseta udesno,znaÄi nazad,Äuje se neko krckanje u toku premotavanja.U suprotnom smeru se ne Äuje niÅ¡ta.InaÄe ostalo sve dobro radi. Å ta bi to moglo biti Quote Link to comment Share on other sites More sharing options...
Pavlaka Posted May 13, 2012 Report Share Posted May 13, 2012 U pitanju je dek Pioneer ct 757 kada se premotava kaseta udesno,znaÄi nazad,Äuje se neko krckanje u toku premotavanja.U suprotnom smeru se ne Äuje niÅ¡ta.InaÄe ostalo sve dobro radi. Å ta bi to moglo biti Poneses 20€ i u servis,to bi mu bilo to,otprilike! Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted May 13, 2012 Report Share Posted May 13, 2012 Ма не бих то чачкао. Ðека тера тако. Quote Link to comment Share on other sites More sharing options...
suca77 Posted May 14, 2012 Report Share Posted May 14, 2012 Dual C-830 je kvalitetan dek, napravljen je kao tenk, pouzdan i dugotrajan no ima jedan problem, u mehanici postoji jedan oveÄi zupÄanik koji se zna izvitoperiti ili se zupci orune pa je to onda gotovo nepopravljivo, prije par mijeseci sam nabavio taj dek i imao sam sreÄe da je mehanika i sve ostalo bilo u savrÅ¡enom stanju, bilo je potrebno zamjeniti remenje i napraviti klasiÄno ÄiÅ¡Äenje i podmazivanje. Hvala Retro na korisnim informacijama, bez vas nekolicine na ovoj temi sve bi bilo drugacije i problematicnije jer za nase lepe Deck - ice ovakve informacije su od presudnog znacaja pre kupovine. Hvala jos jednom, obraticu paznju na to pre bilo kakve kupovine tog Duala PS.................Kakav je zvucno , da li je troglav i da li ima kalibraciju. Cena mislim da je ok - covek trazi 50 ak eura... Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted May 14, 2012 Report Share Posted May 14, 2012 Звучно, ко зна какав је? Иначе је троглави а и пише. Quote Link to comment Share on other sites More sharing options...
Retro-Man Posted May 14, 2012 Report Share Posted May 14, 2012 SuÄo kao Å¡to kaže StoN, Dual C-830 je troglavi dek ali nema mogoÄnost za vanjsko podeÅ¡avanje kalibracije i biasa, dek je zvuÄno vrlo dobar no ja ga nisam neÅ¡to detaljinije testirao niti poredio sa drugim dekovima jer mi je ionako važan samo zbog kolekcije i kao podsjetnik na rane 80' kada sam skoro svakodnevno obijao bratiÄu vrata samo da bi vidio na trenutak dek, uh kad se sijetim koliko sam samo maÅ¡tao o njemu. Stanje zupÄanika se može provjeriti sluÅ¡anjem rada mehanike iako bi bilo najbolje otvoriti dek i detaljnije pregledati stanje, naravno ako se prodavac slaže i ako je dek blizu. Quote Link to comment Share on other sites More sharing options...
vlado78 Posted May 15, 2012 Report Share Posted May 15, 2012 Imam jedno pitanje, vec sam postavljao slike pb/rec glave svog denona dr-m34hr koji ima fizicki ostecen deo glave.Pb polovina je ostecena a rec je skroz sacuvana i zanima me da li je moguce premostiti zice sa ostecenog dela za reprodukciju na neostecen deo za snimanje i dek koristiti samo za playback.Znaci da li je moguce polovinu glave koja je predvidjena za rec da bude za play? Unapred hvala i pozdrav. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted May 15, 2012 Report Share Posted May 15, 2012 Imam jedno pitanje, vec sam postavljao slike pb/rec glave svog denona dr-m34hr koji ima fizicki ostecen deo glave.Pb polovina je ostecena a rec je skroz sacuvana i zanima me da li je moguce premostiti zice sa ostecenog dela za reprodukciju na neostecen deo za snimanje i dek koristiti samo za playback.Znaci da li je moguce polovinu glave koja je predvidjena za rec da bude za play? Unapred hvala i pozdrav. Пробај, мада главе ниÑу иÑте и питање је прилагођења. Quote Link to comment Share on other sites More sharing options...
SandroNS Posted May 17, 2012 Report Share Posted May 17, 2012 KonaÄno sam ga danas doneo iz Sombora, izgleda odliÄno napravljen, neverovatno uzevÅ¡i u obzir da je Philips "mainstream" proizvodjaÄ i kada se digne poklopac postaje jasno zaÅ¡to je koÅ¡tao onda dosta para a posebno u profi verziji. Glave odliÄne, nažalost nije skroz ispravan odnosno zvuÄi muljavo, tamno, kao da je azimut pomeren ali nisam siguran da je to problem. Ovih dana apsolutno nemam vremena da se njime zanimam, ostaće za jun. Evo par slika. Totalno je truba Å¡to na Å¡tampanim kolima nigde nema oznaka za delove, da se zna koji je koji, prosto ne znam kako da se ovo servisira, Äak i sa Å¡emom... Kretenizam. Quote Link to comment Share on other sites More sharing options...
SandroNS Posted May 17, 2012 Report Share Posted May 17, 2012 Evo i slike prednjeg dela da se vidi o Äemu se radi. Zanimljivo da dek nema izvedenu kontrolu za bias na prednjoj ploÄi, osnovno za kvalitetan snimak, mada mi se Äini da ima posebne trimere po kanalu i po tipu trake za fino podeÅ¡avanje unutra, nisam siguran, nemam Å¡emu a nema ni jedne oznake na Å¡tampi. Quote Link to comment Share on other sites More sharing options...
ZoranBG Posted May 17, 2012 Report Share Posted May 17, 2012 I ovaj moj je zvucao muljavo, ali ne toliko, a opet ga je Pioneer CTF900 zgazio kao FAP zabu... Jel' da da je mehanizam malo grub i ima vibracija od grubih zupcanika? Ali je opet odlican.... Meni su se cak klimatale i one silne sitne kartice sa leve strane deka, mislio sam da je neko skinuo osigurace sa njih, ali vidim da je i ovde isto... Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted May 17, 2012 Report Share Posted May 17, 2012 Zanimljivo da dek nema izvedenu kontrolu za bias na prednjoj ploÄi, osnovno za kvalitetan snimak, mada mi se Äini da ima posebne trimere po kanalu i po tipu trake za fino podeÅ¡avanje unutra, nisam siguran, nemam Å¡emu a nema ni jedne oznake na Å¡tampi. Гледано Ñ Ð»ÐµÐ²Ð° у деÑно: Фер - Хром - Метал. Quote Link to comment Share on other sites More sharing options...
TERMINATOR Posted May 21, 2012 Report Share Posted May 21, 2012 Pozdrav kolege.Zanima me jedna stvar u vezi sa mojim pioneer CT-443 dekom.Sa leve strane izmedju dugmeta za paljenje i za otvaranje vratanca imam jedan mali prekidac koji koristim kad snimam kasete.E sad mene zanima sledece.Na tom prekidacu kad ga okrenem prema levo onda snimam kasetu.Kad stoji na sredini onda je na off,a kad okrenem skroz desno onda je play.Zanima me kakva je razlika izmedju of i play .Za cega tacno sluzi...Takodje ja sam ga do sada drzao na sredini na off kad sam slusao pesme.Da li da stavim na play ? Quote Link to comment Share on other sites More sharing options...
Aciko Posted May 21, 2012 Report Share Posted May 21, 2012 Za cega tacno sluzi... Za slušanje i snimanje kaseta uz upotrebu Timer-a, lepo piše na deku. Quote Link to comment Share on other sites More sharing options...
TERMINATOR Posted May 21, 2012 Report Share Posted May 21, 2012 Za slušanje i snimanje kaseta uz upotrebu Timer-a, lepo piše na deku. Kod mene je malo izlizano pa gore ako ima ja ionako nmg da procitam.Kad slusam da li da drzim na off ili na play ?Sad pogledah na internetu.Pise Timer off ... Quote Link to comment Share on other sites More sharing options...
Aciko Posted May 21, 2012 Report Share Posted May 21, 2012 Kod mene je malo izlizano pa gore ako ima ja ionako nmg da procitam.Kad slusam da li da drzim na off ili na play ? Uvek drži na OFF ako ne koristiš tajmer. Quote Link to comment Share on other sites More sharing options...
NShappy Posted May 21, 2012 Report Share Posted May 21, 2012 To ti nema veze ako nemaÅ¡ tajmer, a zapravo služi da odredi kako će se dek ponaÅ¡ati kada dobije napajanje. Ti tajmeri rade tako Å¡to se napojni kabel za ureÄ‘aj ukljuÄi u taj timer te on u podeseno vreme da napajanje ureÄ‘aju a on u momentu dobijanja napajanja ne radi niÅ¡ta (off), poÄne da snima (rec) ili poÄne da svira (play). Položaj prekidaÄa inaÄe uopÅ¡te na utiÄe na rad play ili rec funkcije. Ali ako ostane na play ili rec, ureÄ‘aj će poÄeti da svira ili snima pri svakom prekidu pa dolasku napajanja. MožeÅ¡ to i da probaÅ¡ ukljuÄenjem i iskljuÄenjem ureÄ‘aja. Quote Link to comment Share on other sites More sharing options...
aco Posted May 21, 2012 Report Share Posted May 21, 2012 To ti nema veze ako nemaÅ¡ tajmer, a zapravo služi da odredi kako će se dek ponaÅ¡ati kada dobije napajanje. Ti tajmeri rade tako Å¡to se napojni kabel za ureÄ‘aj ukljuÄi u taj timer te on u podeseno vreme da napajanje ureÄ‘aju a on u momentu dobijanja napajanja ne radi niÅ¡ta (off), poÄne da snima (rec) ili poÄne da svira (play). Položaj prekidaÄa inaÄe uopÅ¡te na utiÄe na rad play ili rec funkcije. Ali ako ostane na play ili rec, ureÄ‘aj će poÄeti da svira ili snima pri svakom prekidu pa dolasku napajanja. MožeÅ¡ to i da probaÅ¡ ukljuÄenjem i iskljuÄenjem ureÄ‘aja. Ali on ima tajmer i treba da drži na OFF Quote Link to comment Share on other sites More sharing options...
NShappy Posted May 22, 2012 Report Share Posted May 22, 2012 Nisam to shvatio iz njegovog posta. Ako ga ima, Å¡to onda pita Äemu prekidaÄ?!? Quote Link to comment Share on other sites More sharing options...
Duck Posted May 22, 2012 Report Share Posted May 22, 2012 K'o kanda nema, samo je mislio da kad snima, treba da stoji na rec. a kad slusa muziku, na play. Iz prethodnih postova moze i da vidi da nema nikakvog uticaja na pomenute funkcije. Dek i snima i reprodukuje, bez obzira na polozaj tajmera. Quote Link to comment Share on other sites More sharing options...
TERMINATOR Posted May 22, 2012 Report Share Posted May 22, 2012 K'o kanda nema, samo je mislio da kad snima, treba da stoji na rec. a kad slusa muziku, na play. Iz prethodnih postova moze i da vidi da nema nikakvog uticaja na pomenute funkcije. Dek i snima i reprodukuje, bez obzira na polozaj tajmera. Nisam znao. Quote Link to comment Share on other sites More sharing options...
