nesone Posted September 9, 2020 Author Report Share Posted September 9, 2020 idemo dalje..... 1 sat ranije, somilenko said: 1 sat ranije, somilenko said: 15 minuta ranije, Delija said: I @nesone je dovukao neke furune od visekanalnih pojacala jos jedan i stajem. obecavam. Quote Link to post Share on other sites
nesone Posted September 9, 2020 Author Report Share Posted September 9, 2020 Jedan 1585 kad dodje Atmos. I dosta vise furuna. Quote Link to post Share on other sites
SUROKVL Posted September 9, 2020 Report Share Posted September 9, 2020 Poenta priče je, ako ima jedan dovodni kabl, može da montira i petnaestostruku utičnicu, neće ga rasteretiri, kao ni osigurač.... Quote Link to post Share on other sites
patason Posted September 9, 2020 Report Share Posted September 9, 2020 hoce ako je na tu uticnicu vezano vise osiguraca .....ajde Delija kazi ono tvoje "lebe mekani...." Quote Link to post Share on other sites
simplicisius Posted September 9, 2020 Report Share Posted September 9, 2020 Kolega NESONE je svoje pitanje stavio u odgovarajuću rubriku. Kada je shvatio da neće moći sam da reši problem ni uz dobronamernu pomoć foruma pozvao je profesionalca! Pametno!! Quote Link to post Share on other sites
zek Posted September 9, 2020 Report Share Posted September 9, 2020 1 sat ranije, patason said: hoce ako je na tu uticnicu vezano vise osiguraca ..... ??? Quote Link to post Share on other sites
nkrgovic Posted September 9, 2020 Report Share Posted September 9, 2020 Ovo "vise osiguraca" ni meni nije jasno. Vise osiguraca jedino moze ako ima i vise dovodnih kablova. Ali onda bi trebalo i vise "dozni" - ne postoji dupla uticnica sa dva para kablova za ulaz - sve su sa jednim. Quote Link to post Share on other sites
somilenko Posted September 9, 2020 Report Share Posted September 9, 2020 Može da se desi da ako je npr. planirana trofazna utičnica, a naknadno improvizovana monofazna, i sproveden petožilni kabel da se iskoriste 2 žice za jednu, dve žice za drugu utičnicu a uzemljenje da bude zajedničko. Svaka od utičnica dobije po svoj monofazni osigurač u razvodnom ormanu i to je to. Obeležavanje provodnika nije po PS-u ali eto radiće i imaće 2 x 16 A utičnice, doduše ako neki prethodni RO nije ograničenje a uzemljenje će biti zajedničko, pa je u slučaju da su mu uređaji uzemljeni i groundloop unapred rešen...Jedino dozna mora da se menja i same utičnice, no ovo je sve šta bi bilo kad bi bilo...Sent from my ONEPLUS A6003 using Tapatalk Quote Link to post Share on other sites
patason Posted September 9, 2020 Report Share Posted September 9, 2020 45 minuta ranije, nkrgovic said: Ovo "vise osiguraca" ni meni nije jasno. Vise osiguraca jedino moze ako ima i vise dovodnih kablova. Ali onda bi trebalo i vise "dozni" - ne postoji dupla uticnica sa dva para kablova za ulaz - sve su sa jednim. bridzovano Quote Link to post Share on other sites
nesone Posted September 12, 2020 Author Report Share Posted September 12, 2020 Inace naruceni, kablovi i produzna letva od druga Zeljka iz AR. Veci presek kablova. U medjuvremenu, postoji jos jedna uticnica koja ce se koristiti samo za video signal, a 1. uticnica samo za potrosace HIFI. Tako da razdvajam oba signala. Quote Link to post Share on other sites
nesone Posted September 12, 2020 Author Report Share Posted September 12, 2020 Ne dupla uticnica, nego posebna koja ce radti samo za video signal. Za TV, projektor, i OPPO 103 itd.... Quote Link to post Share on other sites
black coffe Posted September 12, 2020 Report Share Posted September 12, 2020 On 9.9.2020. at 22:06, somilenko said: Može da se desi da ako je npr. planirana trofazna utičnica, a naknadno improvizovana monofazna, i sproveden petožilni kabel da se iskoriste 2 žice za jednu, dve žice za drugu utičnicu a uzemljenje da bude zajedničko. Svaka od utičnica dobije po svoj monofazni osigurač u razvodnom ormanu i to je to. Obeležavanje provodnika nije po PS-u ali eto radiće i imaće 2 x 16 A utičnice, doduše ako neki prethodni RO nije ograničenje a uzemljenje će biti zajedničko, pa je u slučaju da su mu uređaji uzemljeni i groundloop unapred rešen... Jedino dozna mora da se menja i same utičnice, no ovo je sve šta bi bilo kad bi bilo... Sent from my ONEPLUS A6003 using Tapatalk Trofazni vod ima tri faze (R,S i T ) jednu nulu i uzemljenje . Svaka faza ima svoj osigurač i napon između njih je 380 V , a između njih i nule je 220-240 V . cc 4kw je cc 16 A . Potrošači bez soft starta če izbaciti bimetalni osigurač ako imaju blizu 4 kw . Ako se rasterete po fazama neče . Quote Link to post Share on other sites
somilenko Posted September 12, 2020 Report Share Posted September 12, 2020 Pročitaj početnu rečenicu posta, piše "improvizovana monofazna utičnica", tj. iskorišćene samo tri žile od petožilnog kabla i ostale dve neiskorišćene bi bilo pojašnjenje fraze pod navodnicima, pa da su eventualno ostale dve slobodne žile u zidu koje bi se mogle iskoristiti za još jednu utičnicu sa posebnim osiguračem samo na "vrućem" vodu, ovo podrazumeva, kako je i napomenuto u samom postu intervenciju i na razvodnoj kutiji.Svi veći potrošači imaju soft start i polazna struja je dosta veća od nominalne bez soft starta, te ga isti moraju imati i start uređaja nije istovremen pa da ako u zbiru imaju 4 kW izbace osigurač tako lako, dodatno, svaki osigurač ima svoju krivu i ne reaguje na kratka preopterećenja do određene mere.Za konkretne uređaje ne znam ali je na primer polazna struja kaveznih asinhronih motora pri direktnom startu jednaka 6 x nominalna, ali kao što sam napisao ranije, to je jako kratko, pa se motor koji vuče npr. 20 A nominalne struje ne brani sa osiguračem od 120 A, sve zavisi od karakteristike osigurača, što opet zavisi i od tipa osigurača...U Srbiji je mrežni napon faza nula 230 V, tako da je međufazni napon kod trofaznih potrošača sqrt(3) x 230 = 400 V.No sve ovo nije bitno ali može nekom biti zanimljiva informacija. Sent from my ONEPLUS A6003 using Tapatalk Quote Link to post Share on other sites
nesone Posted September 12, 2020 Author Report Share Posted September 12, 2020 Isto mi je i drug moj govorio. Majstor. Ja imam uredjaje, koji mere napon u kuci. To su dva uredjaja za inverter klime, za grejanje. Napon je isti, na oba sprata kuce. 230V. Nema padanja napona. Blizu, od kuce je na par stotina metara je transformator. Quote Link to post Share on other sites
somilenko Posted September 12, 2020 Report Share Posted September 12, 2020 Da, i kod mene je napon iznenađujuće konstantan, gotovo zakucano 230 V tj. najmanje sam do sada očitao 229.8 a najviše 230.05 V. SN/NN trafo mi je takođe relativno blizu, stotinjak metara.Sent from my ONEPLUS A6003 using Tapatalk Quote Link to post Share on other sites
