laky Posted November 11, 2018 Report Share Posted November 11, 2018 Pozdrav treba drugaru napajanje za phono 15/16v-20ma. ac. copersko ili linearno. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted November 11, 2018 Report Share Posted November 11, 2018 OK. Quote Link to comment Share on other sites More sharing options...
Ružić Slavoljub Posted November 11, 2018 Report Share Posted November 11, 2018 Blago njemu. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 11, 2018 Report Share Posted November 11, 2018 27 minuta ranije, Peter said: Blago njemu. А и другару. Quote Link to comment Share on other sites More sharing options...
laky Posted November 11, 2018 Author Report Share Posted November 11, 2018 hvala predlog smernica gde ,posto Quote Link to comment Share on other sites More sharing options...
Nixie Posted November 11, 2018 Report Share Posted November 11, 2018 6 minuta ranije, laky said: hvala predlog smernica gde ,posto Za phono ja ne bih stavljao čopersko samo linearno. Jel najjeftinije tipa 3pin sa aliexpress ili nešto skuplje CCS + Šhunt regulator. Jel dvostrano napajanje tipa +15...0...-15VDC ili jednostrano? Quote Link to comment Share on other sites More sharing options...
laky Posted November 11, 2018 Author Report Share Posted November 11, 2018 U pitanju je thorens 001.znaci ako moze bolje od fabrickog. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 11, 2018 Report Share Posted November 11, 2018 А шта боље може од фабричког када се у оригиналном адаптеру налази само трансформатор, што значи да је исправљач унутар тог преампа. Quote Link to comment Share on other sites More sharing options...
laky Posted November 11, 2018 Author Report Share Posted November 11, 2018 pa mislio sam bolji trafo,probao na bose pre par godina stavio c jezgro i bio napredak Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 11, 2018 Report Share Posted November 11, 2018 Ето, "Ц" језгро завршава пос'о. Quote Link to comment Share on other sites More sharing options...
laky Posted November 11, 2018 Author Report Share Posted November 11, 2018 bravo care. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 11, 2018 Report Share Posted November 11, 2018 Ок ал' где наћи "Ц" језгро мале снаге? Quote Link to comment Share on other sites More sharing options...
laky Posted November 12, 2018 Author Report Share Posted November 12, 2018 Pa zato i pitam,sta i gde moze da se nabavi,staviti bolji strujni . Quote Link to comment Share on other sites More sharing options...
Nixie Posted November 12, 2018 Report Share Posted November 12, 2018 34 minuta ranije, laky said: Pa zato i pitam,sta i gde moze da se nabavi,staviti bolji strujni . Pa ima tih malih trafoa koliko hoćeš, ali EI. Stavi znatno jači trafo imaš u KELCO i slično 5,10,16VA trafoe. Ima i kutija i PCB. Jel sigurno taj trafo 15V 20mA? Nešto je mala struja. Recimo 16VA 15VAC http://www.kelco.rs/katalog/detalji.php?ID=8961 http://www.kelco.rs/katalog/detalji.php?ID=14887 Piše za PCB samo trafoi sa dvostrukim sekundarom ali mislim da može i sa jednostrukim ako se koriste samo dve srednje kleme. Quote Link to comment Share on other sites More sharing options...
Iron man Posted November 12, 2018 Report Share Posted November 12, 2018 15V 20ma AC je toliko malo da nikakvo poboljšanje neće doneti bilo šta da mu se unapredi. SVEJEDNO da li je EI, C ili torus. Bilo koji, pa i zidni trafo sa izlazom od 15V će biti dobar.( samo izbaci ispravljač iz zidnog). Ono 20mA je premalo. Da nije 200mA Quote Link to comment Share on other sites More sharing options...
laky Posted November 12, 2018 Author Report Share Posted November 12, 2018 Videcu za koji dan nisam kuci.inace ima na sajtu Quote Link to comment Share on other sites More sharing options...
Nixie Posted November 12, 2018 Report Share Posted November 12, 2018 26 minuta ranije, siroma said: Da nije 200mA Verovatno, 3VA deluje realnije nego 0,3VA. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 12, 2018 Report Share Posted November 12, 2018 1 sat ranije, siroma said: Bilo koji, pa i zidni trafo sa izlazom od 15V će biti dobar.( samo izbaci ispravljač iz zidnog). Мораће већи излазни ДЦ напон ако се избацује исправљач. Quote Link to comment Share on other sites More sharing options...
