steva Posted February 1, 2018 Report Share Posted February 1, 2018 Kupio sam ovaj dek za 10e E sad, dek ima problem sa viđenjem trake. Počne lepo da reprodukuje, i ond pomeri traku u stranu i malko je pojede. Očistio sam mehaniku. Pretpostavljam da je pinč roler otišo. Jel ima neko ili zna gde mogu da ga kupim? Quote Link to comment Share on other sites More sharing options...
aco Posted February 1, 2018 Report Share Posted February 1, 2018 Golo g...o.Meni je kao nov to radio.Uz to, zvuk nikakav. Quote Link to comment Share on other sites More sharing options...
Father Posted February 1, 2018 Report Share Posted February 1, 2018 Prvi put vidim ovo kod Technics-a da mu se vratanca otvaraju i zatvaraju na dugme. Možda ne smeju da se guraju rukom već da mehanizam pripremi glave i mehaniku za traku???? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 1, 2018 Report Share Posted February 1, 2018 1 sat ranije, steva said: Jel ima neko ili zna gde mogu da ga kupim? Димензије? Quote Link to comment Share on other sites More sharing options...
steva Posted February 1, 2018 Author Report Share Posted February 1, 2018 Prečnik je 13mm , širina 6.5mm, a širina plastičnog tela je 8mm. Osovinica je 2mm. Vratanca mogu i rukom da se zatvore. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 1, 2018 Report Share Posted February 1, 2018 33 minuta ranije, steva said: Prečnik je 13mm , širina 6.5mm, a širina plastičnog tela je 8mm. Osovinica je 2mm. Имам, дођи и носи к'о поклон. Quote Link to comment Share on other sites More sharing options...
steva Posted February 1, 2018 Author Report Share Posted February 1, 2018 Ima samo jedan problem. Iz Paraćina sam :). Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 1, 2018 Report Share Posted February 1, 2018 То и није неки проблем. 165Км у једном правцу. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted February 1, 2018 Report Share Posted February 1, 2018 2 hours ago, Father said: Prvi put vidim ovo kod Technics-a da mu se vratanca otvaraju i zatvaraju na dugme. Možda ne smeju da se guraju rukom već da mehanizam pripremi glave i mehaniku za traku???? To su skoro svi proizvodjaci uveli 90' godine, mislim da nema nikakve veze sa pripremom mehanike, mnogi su koristili dugme play umesto close pritiska, vrata su se zatvarala i na druge tastere, bar kod nekih masina koliko se secam. Ne secam se sta je radila Aiwa sa Excelia modelima, da li su imali motor za vrata a ne secam se ni za sljakerku 850 iako sam je imao. Quote Link to comment Share on other sites More sharing options...
steva Posted February 1, 2018 Author Report Share Posted February 1, 2018 @ vaN_Helsing Daj neki br telefona. Drugar sutra dolazi u BG. Quote Link to comment Share on other sites More sharing options...
aco Posted February 1, 2018 Report Share Posted February 1, 2018 Technics je imao model 747 ,i kada si stavio kasetu,sam je zatvorio vrata. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 1, 2018 Report Share Posted February 1, 2018 Just now, aco said: Technics je imao model 747 ,i kada si stavio kasetu,sam je zatvorio vrata. Мој 747 није хтео ни да их отвори. Quote Link to comment Share on other sites More sharing options...
aco Posted February 1, 2018 Report Share Posted February 1, 2018 Što mu nisi primakao neku dobru kasetu,možda bi i otvorio. Quote Link to comment Share on other sites More sharing options...
steva Posted February 9, 2018 Author Report Share Posted February 9, 2018 Zahvaljujući vaN_Helsing-u, dek je dobio nov pinč roler. Situacija je sledeća. Više ne žvaće traku bez obzira kako je namotana, već samo na početku trake. Ako se premota par minuta, sve lepo radi. Mislim da je uzrok sporo okretanje prihvatnog koluta. Dek nema idler gumice, nego zupčanike. Jel ima neko ideju šta da gledam? Napon na motoru je ko na šemi. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 9, 2018 Report Share Posted February 9, 2018 Провери да ли су у оси ова два два дела. Један је на глави за брисање а други на рец/плеј глави. Quote Link to comment Share on other sites More sharing options...
ZoranR Posted February 9, 2018 Report Share Posted February 9, 2018 On 2/1/2018 at 12:28 PM, steva said: Kupio sam ovaj dek za 10e Mali oftopik Te, 1990. sam ga pazario u Tehniksu na Novom Beogradu, kod Upina... bese ... i dadoh pola plate. To je valjda poslednja audio komponenta koju sam opusteno i bez natezanja kupio... a posle su dosli ONI. Radio je kao satic 10 godina, dok ga nisam prodao. Nikad nije zguzvao traku Quote Link to comment Share on other sites More sharing options...
steva Posted February 10, 2018 Author Report Share Posted February 10, 2018 Uf... Dek je 97g bio u serisu, zbog istog kvara, našo sam nalepnicu od servisa, i od tad nije korišten. Sve što sam umeo sam proverio. Namestio sam putanju trake, sad je problem nedovoljan pritisak rolera na kapstan :(. Kad pritisnem prstom, vrlo malo, lepo vuče traku. Sad da dumam, kako to da rešim. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted February 10, 2018 Report Share Posted February 10, 2018 On 2/9/2018 at 11:47 AM, ZoranR said: Radio je kao satic 10 godina, dok ga nisam prodao. Nikad nije zguzvao traku Svi dekovi kupljeni novi radili su kao sat. Ja sam 91' kupio Teac V5000 nov i godinama nisam ni razmisljao o servisu, niti mi je padalo na pamet, jednostavno nove mashine su radile odlicno. Sada kada je proslo skoro 25 ili 30 godina ... vec je druga prica, servis obavezan, redovno, kao auto Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 10, 2018 Report Share Posted February 10, 2018 15 minuta ranije, Krca44 said: Svi dekovi kupljeni novi radili su kao sat. Ja sam 91' kupio Teac V5000 nov i godinama nisam ni razmisljao o servisu, niti mi je padalo na pamet, jednostavno nove mashine su radile odlicno. Sada kada je proslo skoro 25 ili 30 godina ... vec je druga prica, servis obavezan, redovno, kao auto Е рек'о си нам нешто ново. Дивим ти се до имбецилности. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted February 10, 2018 Report Share Posted February 10, 2018 1 minute ago, vaN_Helsing said: имбецил Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 10, 2018 Report Share Posted February 10, 2018 1 minut ranije, Krca44 said: Јел то на моју адресу? Quote Link to comment Share on other sites More sharing options...
Krca44 Posted February 10, 2018 Report Share Posted February 10, 2018 5 minutes ago, vaN_Helsing said: Дивим ти се до имбецилности Quote Link to comment Share on other sites More sharing options...
steva Posted February 10, 2018 Author Report Share Posted February 10, 2018 Malo pre pogledah pinc roler na DRM-800A. Kad dek reprodukuje, pritisak na osovinu je puno veci, nego sto mogu da dobijem na Technics-u. Da nije roler sa kojim je dek dosao, manji nego fabricki? Jel ima neko slican dek, da izmeri precnik rolera? Mehanizam sa glavama ne moze vise gore, udari u granicnik, a ako oprugu na roleru opustim, traka ide ubrzano. Ako je malo rastegnem, brzina je ok, ali jede traku na pocetku. Ako, vrlo malo, pritisnem roler na gore, ne zvace! Vec me nervira. Neka ideja? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 10, 2018 Report Share Posted February 10, 2018 27 minuta ranije, steva said: Neka ideja? Хммм, овако на даљину тешко ал' ајде да пробам. Извади механику и види да ли можда граничници могу да се модификују, ту су делови милиметра у питању. Quote Link to comment Share on other sites More sharing options...
aco Posted February 10, 2018 Report Share Posted February 10, 2018 Technics je u to vreme vec bio poznat po lošoj mehanici ,pa samim tim i zvuku.Nema Duplog kapstana,nema svetla u vratima itd,itd.Štedeli su na svemu. Neke glupe AA klase koje nemaju veze sa životom,linearne gluposti i tako dalje. To je pravljeno za decu a ne za ozbiljne ljude.I ovi novi Hifisti što pre to shvate,biće bolje za njih. Quote Link to comment Share on other sites More sharing options...
