ivanp Posted May 15, 2013 Report Share Posted May 15, 2013 Molim da mi ako neko zna, odgovori kako se iskljuÄuje bass boost na risiveru Sony STR-DB840qs. Kad je opcija ukljuÄena svetli lampica levo dole na displeju. Sa analognih ulaza nemam problema jer sluÅ¡am u direkt modu. Kupio sam risiver od preprodavca, skinuo uputstvo, ali neÅ¡to mi ne ide. Ne nalazim ili ne vidim (mator sam, mnogo). Nemam daljinac. Ivan Quote Link to comment Share on other sites More sharing options...
Vlajo Posted May 15, 2013 Report Share Posted May 15, 2013 Izgleda samo preko daljinca, mada verovatno postoji opcija pritiskanjem na enter dugme i ulazak u meni ... Quote Link to comment Share on other sites More sharing options...
Silver Surfer Posted May 15, 2013 Report Share Posted May 15, 2013 Mozda su napisali negde u manualu... http://www.docs.sony.com/release/STRDB940.PDF Quote Link to comment Share on other sites More sharing options...
ivanp Posted May 16, 2013 Author Report Share Posted May 16, 2013 Mozda su napisali negde u manualu... http://www.docs.sony.com/release/STRDB940.PDF Vlajo nsam uspeo sa enter. Postoji dugmence za ulaženje u setap ali nisam naÅ¡ao opciju za iskljuÄenje bass boost a. Kao Å¡to sam napisao u prvom postu, skinuo sam manual. NeÅ¡to previÄ‘am ili ne vidim. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted May 16, 2013 Report Share Posted May 16, 2013 I ja sam malo prelistao manual, nisam našao neko objašnjenje ... Quote Link to comment Share on other sites More sharing options...
kameleon Posted May 16, 2013 Report Share Posted May 16, 2013 I ja mislim da moze samo preko daljinca. Ili ako moze drugacije, ne znam ni ja taj nacin, a inace posedujem 940QS. Ako imas od koga da pozajmis neki Sony daljinac sa bass boost dugmetom, to je resenje. Quote Link to comment Share on other sites More sharing options...
gvlada Posted May 16, 2013 Report Share Posted May 16, 2013 Nikada ne kupujte AVR bez daljinskog jer dosta opcija je dostupno samo preko istog. Cena zasebnog ili rezervnog od dobavljaca cesto je prevelika. Quote Link to comment Share on other sites More sharing options...
kameleon Posted May 16, 2013 Report Share Posted May 16, 2013 Upravo tako, ali sta da se radi... Quote Link to comment Share on other sites More sharing options...
Silver Surfer Posted May 16, 2013 Report Share Posted May 16, 2013 Vlajo nsam uspeo sa enter. Postoji dugmence za ulaženje u setap ali nisam naÅ¡ao opciju za iskljuÄenje bass boost a. Kao Å¡to sam napisao u prvom postu, skinuo sam manual. NeÅ¡to previÄ‘am ili ne vidim. Prevideo sam da si gledao manual... ... inace, nisam do sada gledao manual za risivere takvog tipa... izgleda kao da objasnjavaju kako se setuje SpaceShuttle Quote Link to comment Share on other sites More sharing options...
ivanp Posted May 16, 2013 Author Report Share Posted May 16, 2013 Hvala na trudu drugari. Moraću da naÄ‘em daljinac na zajam, a imam univerzalac sa mogućnošću uÄenja pa ... ... inace, nisam do sada gledao manual za risivere takvog tipa... izgleda kao da objasnjavaju kako se setuje SpaceShuttle Surferu veruj svaki tako izgleda Äak i najjeftiniji i osnovni modeli (Yamaha na pr.). Quote Link to comment Share on other sites More sharing options...
uzvarb Posted May 20, 2013 Report Share Posted May 20, 2013 A da probas da ga resetujes na fabricke vrednosti, jer bas boost nije ukljucen po prvom paljenju. Ugasis risiver i drzis power taster oko 5 sekundi. Quote Link to comment Share on other sites More sharing options...
ivanp Posted May 21, 2013 Author Report Share Posted May 21, 2013 A da probas da ga resetujes na fabricke vrednosti, jer bas boost nije ukljucen po prvom paljenju. Ugasis risiver i drzis power taster oko 5 sekundi. Hvala najlepÅ¡e Uzvarb. Iskreno, nije mi palo na pamet. Mada bi precizno uputstvo bilo da kod ukljuÄivanja držiÅ¡ power taster 5 sekundi. Uspeo sam. Hvala i svima ostalima na trudu. Sad mi preostaje da setujem SpaceShuttle ponovo Å¡to bi rekao Surfer . Quote Link to comment Share on other sites More sharing options...
Vlajo Posted May 21, 2013 Report Share Posted May 21, 2013 Ništa bez Uzvarb-a Quote Link to comment Share on other sites More sharing options...
gvlada Posted May 21, 2013 Report Share Posted May 21, 2013 Ma nista bez daljinskog! Kupi jos jedan takav avr pa taman imas za bi-amp a daljinskim kotrolises oba uredjaja istovremeno. Quote Link to comment Share on other sites More sharing options...
ivanp Posted May 21, 2013 Author Report Share Posted May 21, 2013 Ma nista bez daljinskog! Kupi jos jedan takav avr pa taman imas za bi-amp a daljinskim kotrolises oba uredjaja istovremeno. Imam ja neki univerzalni daljinac koji mi podrzava sve opcije koje mi trebaju. Od bi ampinga sam daleko nekoliko svetlosnih godina, da ne objasnjavam previse. Jbg cedim suvu drenovinu pozdrav Quote Link to comment Share on other sites More sharing options...
uzvarb Posted May 21, 2013 Report Share Posted May 21, 2013 Može se naći tih sony daljinaca od risivera za cenu oko 10 eur. Samo treba naći što priblizniji po opcijama. Da, ugašen risiver pri paljenju zadržati taster 5 sec. pisao u žurbi, al bitno je da ste uspeli. Pozdrav! Quote Link to comment Share on other sites More sharing options...
safet Posted May 21, 2013 Report Share Posted May 21, 2013 a ja taman našao original knjigu ili upustvo za upotrebu za str-db 940 i 840 pa ako treba ... Quote Link to comment Share on other sites More sharing options...
ivanp Posted May 21, 2013 Author Report Share Posted May 21, 2013 a ja taman naÅ¡ao original knjigu ili upustvo za upotrebu za str-db 940 i 840 pa ako treba ... Safete, ne ljuti se, ali proÄitaj moj prvi post. Pažljivo. Pozdrav Quote Link to comment Share on other sites More sharing options...
