generalna_skupstina Posted November 7, 2012 Report Share Posted November 7, 2012 Dodajemo jos malo.. Quote Link to comment Share on other sites More sharing options...
generalna_skupstina Posted November 7, 2012 Report Share Posted November 7, 2012 I poneka zivotinjica.. Quote Link to comment Share on other sites More sharing options...
perodeformero Posted November 7, 2012 Report Share Posted November 7, 2012 Shta ti je beli svet, Beograda ima svuda, ali ne i Zemuna! Quote Link to comment Share on other sites More sharing options...
generalna_skupstina Posted November 8, 2012 Report Share Posted November 8, 2012 Ima i Amsterdama! ..a, za nemanje Zemuna ce da mi plate. Ima da ga napravimo ako treba!!! A, snimi ovo.. Imaju i 'JUNK SCHOOL' !!! Quote Link to comment Share on other sites More sharing options...
perodeformero Posted November 8, 2012 Report Share Posted November 8, 2012 Verovatno tu prodaju ono shto pokupe po kontAjnerima. Quote Link to comment Share on other sites More sharing options...
zoltan Posted May 7, 2013 Author Report Share Posted May 7, 2013 mislim da je sa dolaskom proleca vreme da ozivimo temu.... mada su ove godine pooprilicno preterali sa cenama dozvola otvoriste li sezonu ? Quote Link to comment Share on other sites More sharing options...
sondek Posted May 7, 2013 Report Share Posted May 7, 2013 Ja sam bio dva puta,jednom na poÄetku sezone na Jegricki na babuskolovu-ispade dobra zabava za klinca.Drugi put Glozansko jezero tj. Ribnjak prepun Å¡arana, 1:1 sa juniorom.Milina je gledati klinca od 12g kako se bez pomoći bori s ribom od 2-3kg i to na plovak ,adrenalin proradio...borba,cika vriska,trenutci za pamćenje... Quote Link to comment Share on other sites More sharing options...
beast Posted May 7, 2013 Report Share Posted May 7, 2013 Ako se ovako nastavi, nemar fabrika koje ispuÅ¡taju otrove u reke kao i nespremnost države da se obraÄuna sa ribokradicama, peca će se uskoro samo na komercijalnim jezerima. Quote Link to comment Share on other sites More sharing options...
sondek Posted May 7, 2013 Report Share Posted May 7, 2013 Ima zaista lepo sredjenih mesta tog tipa i sve ih je vise mesta koji sem sportskog ribolova nude niz pratecih sadrzaja (restoran,teniski tereni,apartmani,sadrzaji za decu).Mislim da zaradjuju solidnu lovu( ja licno ne pozalim ni za dinarom,uostalom nema se vremena pa se to svede na par puta godisnje), 1200din je dnevna karta ili pola dana 600,riba je sad vec skuplja nego u ribarnici,prenociste oko 2000,ali startu su ocigledno dosta velika startna ulaganja.Voda je cista i preciscava se konstantno.Kad ne umemo da cuvamo prirodu dobro je i da ima ovakvih mesta gde sve barem funkcionise savrseno i cisto je bez i jednog papirica kao da smo u nemackoj,a ne u srbiji.Kod mene u kuci vaze stroga pravila kad smo u prirodi,ne sme apsoluno nista da se baci ili ostavi u prirodi bilo da smo na pecanju,Dunavu u setnji ili Fruskoj Gori... Najlepse je ipak na vodi u divljini ,onda se uziva u sasvim drugim stvarima i potpuno je nevazno da li ces nesto da upecas.Jegricka je na pr. sjajno mesto za pecanje u pravoj prirodi,redovno platimo dozvolu i odemo u divlji deo sa mestima u trsci,upeca se i tamo ali manje naravno,voda je cista mislim da uopste nema zagadjivaca u toj recici,postoji i mogucnost da te iz tog dela koji je ribnjak u na izlazu i Zablja odvezu camcem dalje do mesta u trsci za par stotina dinara. Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted October 4, 2014 Report Share Posted October 4, 2014 Da se malo odmorim od pisanja o akustici i, možda, navedem nekoga da napiÅ¡e neÅ¡to u ovoj zaboravljenoj temi, Å to se mene tiÄe, ove godine sam bacio 5-6 hiljadarki (ne znam koliko je koÅ¡tala dozvola), nisam ni zabacio... Nego me asociralo pisanje u "vaÅ¡i sistemi", gde ZveroguÅ¡ter kaže "uživaj u sistemu" a Marko329 kaže "hvala, hoću". Elem, priÄao mi jednom PiÅ¡ta iz vikendice pored moje, pasionirani smuÄ‘aroÅ¡, kako je uhvatio ribu svog života, smuÄ‘a od dvanaestak kila. Kada izaÄ‘ete iz SuseÄkog dunavca i preÄ‘ete na drugu stranu Dunava, naiÄ‘ete na ade i peÅ¡Äane sprudove koji se prostiru sve do ulaza u begeÄku Jamu (sa naglaskom na dugouzlazno "a" ) s jedne i BanoÅ¡tora s druge strane. Sve dotle nema naseljenog mesta, priliÄna je divljina i Äesto nema ni pecaroÅ¡a, na puÅ¡komet. To je nizvodno. Uzvodno je joÅ¡ veća vukojebina, do NeÅ¡tina i BaÄke palanke je pustoÅ¡. E, kada naÄ‘ete pogodnu dubinu i kada se lengeriÅ¡ete Äamcem kod nekog od tih sprudova, ako se potrefe i neki drugi parametri, možete uhvatiti, ponekad, takav neki komad. Tog jutra, bio je joÅ¡ jedan pecaroÅ¡, lengerisan, možda, stotinak metara od PiÅ¡te. Kada je ovaj ubacio lovinu u Äamac, onaj mu doviknu: Vi sada možete da idete kući! A PiÅ¡ta mu uzvrati: I hotju! Ovo "tj" treba da doÄara mek maÄ‘arski izgovor, ali je teže doÄarati njegov Å¡eretski glas dok je ovo priÄao, glas koji i sada jasno Äujem, mada je, jadnik, umro pre viÅ¡e od petnaest godina. Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted October 5, 2014 Report Share Posted October 5, 2014 Iju! Nisam ni znao da postoji ova tema. Ja sam pasionirani smudjaros u visegodisnjem celibatu od istog, nazalost. Ali tesim se uvek: Moju ribu jos niko nije uhvatio! Kao sto se nadam i da mi smudj od 8.5 kg, iz 2006., nije riba zivota, kako mi je u danima po hvatanju tog primerka rekao jedan "prijatelj". Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted October 5, 2014 Report Share Posted October 5, 2014 Ali tesim se uvek: Moju ribu jos niko nije uhvatio! I ja se tako nekako teÅ¡im, ali džabe. Planirao sam da ceo septembar pa dokle može, pecam Å¡arana. Spustio Äamac, kupio sve Å¡to treba - džakÄe prekrupe, džakÄe kukuruza, mamce... a onda je vodostaj poludeo i eno ga - joÅ¡ se nije unormalio, a ja nisam baÅ¡ toliki entuzijasta da ÄuÄim u Äamcu na nula stepeni. Ode mas' upropas'. Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted October 5, 2014 Report Share Posted October 5, 2014 Cekaj Januar, belog tvistera na jig glavu, i kao krenes na smudja sa obale u kamenjaru. Nemoj da se iznenadis kad ti dodje divljak od 5+ kg. Naime, jako je cesto to pocelo da se desava da bi bila slucajnost. Quote Link to comment Share on other sites More sharing options...
trotter Posted October 5, 2014 Report Share Posted October 5, 2014 U slucaju da ima varalicara, mogu me kontaktirati preko pp za alex lures, hand made balsa wood lures, bez trgovacke marze za clanove foruma. Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted October 6, 2014 Report Share Posted October 6, 2014 Sa tvisterima imam samo nekoliko nemuÅ¡tih pokuÅ¡aja. Jedan kućni prijatelj je majstor, decenijama je visio na Å¡picu kod kanala u NS, viÅ¡e puta je bio u konkurenciji za smuÄ‘a godine. Tvrdi da mu je jedne godine "Å¡nur" odneo, na prevaru, tip koji je smuvao fotografiju. I on je imao Å¡arana od nekih sedam kila, na neku od tih gumenih igraÄkica. Jednom je, kaže, pola sata imao "neÅ¡to" na udici, nije mogao da ga digne sa dna. A onda se "to", jednostavno, otkaÄilo. Posle par dana je dobio herpes sa kojim se dugo muÄio. Ja sam dugo bio strastveni varaliÄar. Ali, sve sam otkrivao sam i uÄio na sopstvenim greÅ¡kama. Tako sam, jednom, stajao na kamenom Å¡poru, preko kojeg je prelivala voda, stvarajući nizvodno snažne virove. Kao Å¡to bi svaki poÄetnik-entuzijasta uradio, bacao sam neku glupu veliku kaÅ¡iku u te virove. DoduÅ¡e, probao sam i da je spuÅ¡tam u veliku dubinu, Å¡to je već imalo nekog smisla. A onda sam, krajiÄkom oka, primetio da se sa uzvodne strane, na svega par metara od mene, povremeno deÅ¡ava neÅ¡to Äudno. I tu su bili virovi, pa sam samo naslutio da se tu deÅ¡ava i neki neobiÄni poremećaj u vodi. Bio je već sumrak. Izmakao sam se do suvog dela kamena i potražio neku prigodniju varalicu, ali je jedina upotrebljiva bio meps, duguljasti leptir, dvojka, sa dvokrakom udiÄicom, jer se jedan krak bio slomio. Leptir se u brzoj vodi sumanuto obrtao, bio je to potpuno neprimeren mamac. Ipak, posle svega nekoliko ubaÄaja, izvadio sam smuÄ‘a od tri kile, malo kasnije joÅ¡ jednog kilaÅ¡a. Posle sam nekoliko sezona odlazio tamo, septembar je bio udarni, i nikad se nije desilo da ne uhvatim nijednog. Bacao sam obiÄnu izduženu, usku, metalnu kaÅ¡iku. IskljuÄivo sat-dva pred mrak. DoduÅ¡e, nije doÅ¡ao nijedan krupniji, u proseku je to bilo kilu ipo do dve. Onda je poÄelo sve Äešće da se deÅ¡ava da ne bude ni udarca, pa sam batalio mesto. Tada sam već imao i "rapale", samo se smuÄ‘ bio, nekako, proredio. Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted October 6, 2014 Report Share Posted October 6, 2014 U slucaju da ima varalicara, mogu me kontaktirati preko pp za alex lures, hand made balsa wood lures, bez trgovacke marze za clanove foruma. Ujko, ako nije tajna, da li ih ti pravis? Quote Link to comment Share on other sites More sharing options...
trotter Posted October 6, 2014 Report Share Posted October 6, 2014 Nije tajna, ne pravim ih ja, poznajem vlasnika firme i mogu da pitam za cene. Verujem da bi moglo da se dobije po proizvodjackoj ceni. Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted October 6, 2014 Report Share Posted October 6, 2014 Sa tvisterima imam samo nekoliko nemuÅ¡tih pokuÅ¡aja. Jedan kućni prijatelj je majstor, decenijama je visio na Å¡picu kod kanala u NS, viÅ¡e puta je bio u konkurenciji za smuÄ‘a godine. Tvrdi da mu je jedne godine "Å¡nur" odneo, na prevaru, tip koji je smuvao fotografiju. I on je imao Å¡arana od nekih sedam kila, na neku od tih gumenih igraÄkica. Jednom je, kaže, pola sata imao "neÅ¡to" na udici, nije mogao da ga digne sa dna. A onda se "to", jednostavno, otkaÄilo. Posle par dana je dobio herpes sa kojim se dugo muÄio. Ja sam dugo bio strastveni varaliÄar. Ali, sve sam otkrivao sam i uÄio na sopstvenim greÅ¡kama. Tako sam, jednom, stajao na kamenom Å¡poru, preko kojeg je prelivala voda, stvarajući nizvodno snažne virove. Kao Å¡to bi svaki poÄetnik-entuzijasta uradio, bacao sam neku glupu veliku kaÅ¡iku u te virove. DoduÅ¡e, probao sam i da je spuÅ¡tam u veliku dubinu, Å¡to je već imalo nekog smisla. A onda sam, krajiÄkom oka, primetio da se sa uzvodne strane, na svega par metara od mene, povremeno deÅ¡ava neÅ¡to Äudno. I tu su bili virovi, pa sam samo naslutio da se tu deÅ¡ava i neki neobiÄni poremećaj u vodi. Bio je već sumrak. Izmakao sam se do suvog dela kamena i potražio neku prigodniju varalicu, ali je jedina upotrebljiva bio meps, duguljasti leptir, dvojka, sa dvokrakom udiÄicom, jer se jedan krak bio slomio. Leptir se u brzoj vodi sumanuto obrtao, bio je to potpuno neprimeren mamac. Ipak, posle svega nekoliko ubaÄaja, izvadio sam smuÄ‘a od tri kile, malo kasnije joÅ¡ jednog kilaÅ¡a. Posle sam nekoliko sezona odlazio tamo, septembar je bio udarni, i nikad se nije desilo da ne uhvatim nijednog. Bacao sam obiÄnu izduženu, usku, metalnu kaÅ¡iku. IskljuÄivo sat-dva pred mrak. DoduÅ¡e, nije doÅ¡ao nijedan krupniji, u proseku je to bilo kilu ipo do dve. Onda je poÄelo sve Äešće da se deÅ¡ava da ne bude ni udarca, pa sam batalio mesto. Tada sam već imao i "rapale", samo se smuÄ‘ bio, nekako, proredio. Ma da i u ribolovu (da se ogradim i kazem smudjolovu) je isto kao i u hifi. Koliko tu tek ima "pravila koja se moraju postovati" i mahom se ljudi dogmatski odnose prema tim "zapovestima". Ustvari je napredak u eksperimentisanju i improvizacijama na zadate teme. Da se razumemo i u dogmi u ovom slucaju ima istine, ali to su temelji i dobro poznate cinjenice, nikakav mambo-dzambo koji se vazda zeli poturiti. Jednom sam u Torontu, u jednoj auto-mehanicarskoj radnji naleteo na papir na kome je pisalo: Simple asa dat! Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted October 6, 2014 Report Share Posted October 6, 2014 Ma pitam 'nako, iz znatizelje. Slabo bacam, mogu reci nikako Rapale i ostalu drvenariju iako ih imam onoliko. A da se pecalo na njih, pecalo se, ne mogu da kazem. Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted October 6, 2014 Report Share Posted October 6, 2014 O nekim boljim vremenima, iliti cvetanje Tise Sada je to turistiÄka atrakcija na ulaznom delu Tise u naÅ¡u zemlju. Ovde je (Tisu) doÄekuje Veliki BaÄki Kanal, najzagaÄ‘eniji vodeni resurs u Evropi. Nizvodno od njega preživljavaju samo otporniji oblici života. Dok sam živeo u Zrenjaninu (do '67.) Äesto smo, biciklom, odlazili na Tisu, na pecanje, to je petnaestak kilometara vožnje. Na pecanje se moglo ići i bez mamaca, jer je sama reka bila prepuna onih najidealnijih - larvi vodenog cveta. To su larve koje izgledom podsećaju na malog rovca, proseÄne dužine oko 2cm, i žive u rupama koje same izbuÅ¡e u tvrdom glinovitom dnu. DoduÅ¡e, kada je voda u porastu, teže je bilo doći do nje, jer se larve sporo premeÅ¡taju u pliću vodu. U svrhu lakÅ¡eg hvatanja larvi, ribari su koristi tzv bager - metalnu konusnu tvorevinu, nevelikog preÄnika, nataknutu na dugu Å¡ticu. Bagerom se zahvatala glina, u jednom zahvatu je moglo biti i do dve stotine larvi. Ta larva je bila omiljena hrana apsolutno svih vrsta ribe. Tisa je bila prepuna keÄige. Mi, klinci, smo koristili kratke pecaljke sa po dve udice. Pa se deÅ¡avalo da vadiÅ¡ dve ribe odjednom - smuÄ‘arka i deveriku, recimo. Nikada nisam prisustvovao cvetanju Tise, dogaÄ‘aju prikazanom na klipu, jer se ono deÅ¡ava nekog neodreÄ‘enog, pogodnog, dana u maju mesecu. Po priÄanju moga oca, broj ovih letećih bića je bio toliki, da nije video suprotnu obalu. Quote Link to comment Share on other sites More sharing options...
perodeformero Posted October 6, 2014 Report Share Posted October 6, 2014 Nije tajna, ne pravim ih ja, poznajem vlasnika firme i mogu da pitam za cene. Verujem da bi moglo da se dobije po proizvodjackoj ceni. Aha! Pa posle nema para za policajce, prosvetare, i ostale Å¡trajkaÄe u najavi!(Živi bili) Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted July 10, 2015 Report Share Posted July 10, 2015 Umrela tema skroz-naskroz. ProÅ¡le godine sam izvadio dozvolu negde u septembru, posle dan-dva je Dunav krenuo u veliki porast, pa se ispostavilo da sam bacio pare - cele sezone nisam ni zabacio. Proteklih nekoliko dana sam posvetio upijanju znanja sa Jutjuba, vezanih za upotrebu gumenih mamaca za lov smuÄ‘a, jer sam tu veoma tanak. Danas sam sveÄano odneo dole motor i sve Å¡to treba za otvaranje sezone. Skoro da je sveÄanost propala, jer se pokazalo da na crevu za dovod goriva fali pumpica. Naime, kada sam poslednji put upotrebljavao motor, dotiÄna pumpa je pukla. Odmah sam je kupio, ali je nisam montirao a vreme je taj momenat prekrilo zaboravom. No, kako to već biva, jedan propust se popravi drugim. Budući da sam zaboravio da odvrnem oduÅ¡ak na rezervoaru, nadpritisak koji se stvorio u njemu proteklih toplih dana je nagurao toliko goriva u motor da je i curelo... Uzgred, priÄe da gorivo posle dužeg stajanja izlapi su obiÄna patka. Evo, sada će dve godine kako sam napunio rezervoar i napravio smeÅ¡u. Radi bez problema. Dakle, bilo je kasno popodne i trknuo sam do mesta koje sam oÅ¡acovao kao pogodno da upotrebim znanje sa Jutjuba, i da na brzinu namlatim Å¡togod smuÄ‘eva. Promenio sam jedno tri mesta i zakljuÄio nekoliko stvari: - oni snimaju samo ono kada neÅ¡to uhvate a ne i ono kada ceo dan vitlaju Å¡tap bez veze. - nijedno od tih mesta sa klipova nije duboko i brzo kao Dunav. Trebaće mi teže glave. - bolje da pecam Å¡arana - sve to mi je sve viÅ¡e zamorno. Potpuno sam kolabirao. Ili da batalim, ili da Äešće upražnjavam. Za sada, ovo drugo. PoÅ¡to svaka pecaroÅ¡ka priÄa treba da bude krunisana hvalisanjem, evo... Pre dve godine sam isto krenuo da pazarim dozvolu negde u septembru. ViÅ¡e ih nisu imali pa sam priuÅ¡tio sebi nekoliko bespravnih izlazaka na vodu. Rezultat - dva Å¡arana i jedna babuÅ¡ka. Veći je imao 7.5kg. Pravi "oklagijaÅ¡"... kako taj vuÄe, ljudi moji. Quote Link to comment Share on other sites More sharing options...
Lilyhammer Posted July 10, 2015 Report Share Posted July 10, 2015 Recite vi meni: Gde radi dobra riba? Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted July 10, 2015 Report Share Posted July 10, 2015 Ukoliko pitanje nije dvosmisleno, nalaženje dobrog mesta za pecanje je najvažniji preduslov za uspeh. Nema generalne preporuke, zavisi od toga šta želimo da lovimo. U Novom Sadu je, recimo, kej u delu od Žeželja do kanala oduvek bio dobar za grabljivce (so, smuđ). Quote Link to comment Share on other sites More sharing options...
gvlada Posted July 10, 2015 Report Share Posted July 10, 2015 Isplati li ti se pecanje bez dozvole? Kazne nisu male... Quote Link to comment Share on other sites More sharing options...
