HiFi Lover Posted March 12 Author Report Share Posted March 12 Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 12 Report Share Posted March 12 Уз употребу PWM-a је сасвим довољно. Quote Link to comment Share on other sites More sharing options...
somilenko Posted March 12 Report Share Posted March 12 2 sati ranije, HiFi Lover said: Taj trafo je bas diskutabilan 😃 Nije to taj trafo na koji ti misliš, to je swičersko napajanje, to je step down trafo i da, može biti 1 kW. Kod linearnog napajanja trafo mora biti mnooogo veći, ovo je SMPS. Quote Link to comment Share on other sites More sharing options...
Iron man Posted March 12 Report Share Posted March 12 Na onaj " fantastični" amp turi switchersko napajanje i uzivaj. Kakvi trafoi, slow startovi,...... Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 12 Report Share Posted March 12 То и Ја кажем, а и биће мања кутија!Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
Nixie Posted March 12 Report Share Posted March 12 I za poneko svičersko treba "soft start". Quote Link to comment Share on other sites More sharing options...
Iron man Posted March 12 Report Share Posted March 12 Obicno ima ugradjen Quote Link to comment Share on other sites More sharing options...
Nixie Posted March 12 Report Share Posted March 12 Neki imaju, neki ne treba proveriti pre kupovine. Ako nema, zavari prekidač koji god da staviš. Quote Link to comment Share on other sites More sharing options...
Iron man Posted March 12 Report Share Posted March 12 MA to se i ne gasi Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 12 Report Share Posted March 12 Наравно да има, то су ипак паметна напајања.Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
Nixie Posted March 12 Report Share Posted March 12 Smart napajanja, super stvar. Čovek reče da ima trafo od kilovat, priglup malo jes, samo gvožđe i bakar, al radi poso bolje od bilo kog SMPS. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 12 Report Share Posted March 12 Ма бачене паре..Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
Iron man Posted March 12 Report Share Posted March 12 Greota takav trafo na ono pojačalce Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 12 Report Share Posted March 12 Гре'ота, и Ја кажем....Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
HiFi Lover Posted March 12 Author Report Share Posted March 12 Cenim da ce torusni trafo svakako biti stabilniji i dugotrajniji od smps.Smps je bilo u njemu za one koji nisu procitali od pocetka.Deklarisano na 500w.Kaze prodavac 6A na izlazu.Nema od toga nista.U praksi je bilo ocajno pri vecim opterecenjima.Pojacalo je palilo zastitu od pada napona kada se pojaca preko 40%.Probao sam ga na trafou od 180w iz nekog philipsa sto sam imao i to je bilo nebo i zemlja kazem vam. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 12 Report Share Posted March 12 Ма има тих напајања и великих снага само треба потражити..Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
HiFi Lover Posted March 12 Author Report Share Posted March 12 okacio sam sliku od "1000w".to je 55e bez ptt i opet nisam siguran u deklarisanu snagu.Trafo je trafo Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 12 Report Share Posted March 12 Постоје напајања која дају 1000W и то константно @25°C.Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
Nixie Posted March 12 Report Share Posted March 12 Trafo grec i elektroliti su napajanje bez regulacije, ali trpe svašta. SMPS je stabilisano napajanje ali mora biti jako kvalitetno za pojačalo jer su zahtevi veliki i struja se brzo menja. Da li je SMPS u stanju to da prati, nisam baš skroz uveren. Kao što se i pokazalo, na maloj snazi je super, ali kad se zahtevi pojačaju kreću problemi. Profi pojačala su sva D klase sa SMPS napajanjima. Znači izvodljivo je to tehnički, ali ne za sitne novce. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 12 Report Share Posted March 12 2000W напајање на ибеју је мање од 100€.Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
somilenko Posted March 12 Report Share Posted March 12 3 sati ranije, HiFi Lover said: Cenim da ce torusni trafo svakako biti stabilniji i dugotrajniji od smps.Smps je bilo u njemu za one koji nisu procitali od pocetka.Deklarisano na 500w.Kaze prodavac 6A na izlazu.Nema od toga nista.U praksi je bilo ocajno pri vecim opterecenjima.Pojacalo je palilo zastitu od pada napona kada se pojaca preko 40%.Probao sam ga na trafou od 180w iz nekog philipsa sto sam imao i to je bilo nebo i zemlja kazem vam. To što te je prodavac lagao ne znači da ni jedan smps ne valja, smps napajanje ispravlja, filtrira i reguliše napon, trafo samo vrši konverziju, uporedivo je smps sa trafo + grec + CRC filter u najmanju ruku a za istu snagu, kvalitetni SMPS je jeftiniji, npr HYPEX SMPS1200A180 koji ima 1.2 kW ali stvarno i na audiophonics-u je 230 e, izračunaj koliko košta kršteno linearno napajanje od 1.2 kW sa svim komponentama. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 12 Report Share Posted March 12 Да, Hypex, на њега заборавих..Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
somilenko Posted March 12 Report Share Posted March 12 4 sati ranije, HiFi Lover said: okacio sam sliku od "1000w".to je 55e bez ptt i opet nisam siguran u deklarisanu snagu.Trafo je trafo BTW, šta će ti tu čopersko napajanje, kada ti lepo piše da se dovodi AC a ne DC... 24 V RMS je cca 33 V nakon ispravljanja, ako si koristio smps od 24 V na izlazu, zato je amp palio zaštitu jer je bilo 9 V manji napon na ulazu u sam pojačivač. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 12 Report Share Posted March 12 Да, комплетан исправљач је на плочи ампа.Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
HiFi Lover Posted March 13 Author Report Share Posted March 13 Tacno,pise da se dovodi ac napona na ulazu.Ali moze da se dovede i dc.Samo ce biti pad napona za jednu diodu.Zanemarljivo.Smps koji je bio prethodno je bio +39 -39.nisam napisao da je bilo 24v.Doduse mogao sam generalno i zaobici greca i vezati ditrektno na elektorlite.Dakle napona je bilo dosta ali struje manjka 😀 Jos malo pa ce te me ubediti da izvadim trafo 🤣 Quote Link to comment Share on other sites More sharing options...
