giZ_Mo Posted March 9 Report Share Posted March 9 3 minuta ranije, Nixie said: Mislim da ovo radi zaštitu i za D klasu. Pošto je mono pojačalo Моно да али сваки чип има два излазна степена кији су према звучнику у мосној вези или ти на српском Bridge! Quote Link to comment Share on other sites More sharing options...
HiFi Lover Posted March 9 Author Report Share Posted March 9 Ne moze ipak kako prodavac pise.Ne moze ako je cip vezan u BTL.🤨 Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 9 Report Share Posted March 9 7 minuta ranije, HiFi Lover said: Сећам се овог циркуса, и шта би на крају? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 9 Report Share Posted March 9 Ne moze ipak kako prodavac pise.Ne moze ako je cip vezan u BTL.То и јесте поента.Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
HiFi Lover Posted March 9 Author Report Share Posted March 9 Stk ,neverovatno.Znaci svira,ne greje se.Kako ga pojacas preko 70,80 posto,pregori osigurac.Nov stk problem resen.😀 Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 10 Report Share Posted March 10 СТК је чудо ал' кад нађеш добар комад! Quote Link to comment Share on other sites More sharing options...
HiFi Lover Posted March 10 Author Report Share Posted March 10 Javljam utiske kad zavrsim ovo i kad stigne soft start.😃 Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 10 Report Share Posted March 10 Јављај Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
HiFi Lover Posted March 10 Author Report Share Posted March 10 Danas skuvao kafu i bockam malo po ploci i vidim da nisam obratio paznju na Signal ground.Signal ground treba da bude vezan na sasiju kao i uzemljenje ili moze da ostane da "lebdi"?Napravio sam sledece Rca konektor-potenciometar-pretpojacalo-pojacalo.😐😐 Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 10 Report Share Posted March 10 Одма' изнад летвице за изводе са трансформатора је трополни конектор за аудио улаз, средњи пин је маса, не видим потребу да се маса води на кућиште!Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
HiFi Lover Posted March 10 Author Report Share Posted March 10 Sistem sam slusao,nije bilo suma,bruma.Pojacavac je takodje povezan interno signal masa- 0v izvod sa trafoa.Pa sam razmisljao ako bi i signal ground vezao na sasiju (uzemljenje) onda bi i centralni izvod sekundara bio vezan na uzemljenje.To mi se nije svidelo bas.Nadam se da ste me razumeli koliko toliko. Na IEC socetu izmedju faze i nule imam x1 kond.Ispod se nalaze jos dva kondenzatora.Mislim da su Y1 kategorija vezani Faza-uzemljenje,Nula-uzemljenje.To sam izvadio iz starog coperskog napajanja.Da li to ostaviti ili skinuti? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 10 Report Share Posted March 10 Искрено не волим да аудио уређаји буду са уземљеним кућиштем, то није бојлер па мора! Quote Link to comment Share on other sites More sharing options...
Nixie Posted March 10 Report Share Posted March 10 Sve zavisi od stepena izolacije trafoa. Ja uvek uzemljim metalnu šasiju direktno na kućni GND. Posle toga koristim posredno uzemljenje elektronike na šasiju. Ne hoću da razmišljam u opšte. Samo mi je pojačalo direktno uzemljeno. Na taj način sve što povežem na njega je takođe uzemljeno, a nema GND loop šanse da se pojavi. Quote Link to comment Share on other sites More sharing options...
HiFi Lover Posted March 10 Author Report Share Posted March 10 Da li je prihvatljivo za centralni izvod sekundara trafoa bude uzemljen s obzirom da ce onda i siganl biti isto uzemljen? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 10 Report Share Posted March 10 Искрено не бих то радио...Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted March 10 Report Share Posted March 10 2 sati ranije, HiFi Lover said: Na IEC socetu izmedju faze i nule imam x1 kond.Ispod se nalaze jos dva kondenzatora.Mislim da su Y1 kategorija vezani Faza-uzemljenje,Nula-uzemljenje.To sam izvadio iz starog coperskog napajanja.Da li to ostaviti ili skinuti? Između faze i nule treba da ide X2, a inače svuda možeš da staviš Y2. To će malo da pomogne sa smetnjama. Quote Link to comment Share on other sites More sharing options...
HiFi Lover Posted March 10 Author Report Share Posted March 10 https://ibb.co/zRZGfG8 Postavio sam sliku kako je trenutno.Dakle moje pitanje,ostaviti tako ili izbaciti sva tri kondenzatora,s obzirom da ce ici soft start ploca i prekidac ce imati dva x2 kondenzatora paralelno?.Pa da ne bude nekih problema,s obzirom da soft start ide direkntno na 220 bez icega makar na slici. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted March 10 Report Share Posted March 10 Ja bih stavio po jedan X2 na primar i sekundar. Da li će biti pre ili posle prekidača, svejedno je. Mislim da ti ovi Y nisu potrebni. Ti 0,1uF su stara vrednost, još iz FM vremena. Ja bih dodao i 22nF. Quote Link to comment Share on other sites More sharing options...
Nixie Posted March 10 Report Share Posted March 10 5 sati ranije, HiFi Lover said: Da li je prihvatljivo za centralni izvod sekundara trafoa bude uzemljen s obzirom da ce onda i siganl biti isto uzemljen? Metalnu kutiju uzemlji direktno, a signal GND (centralnu tačku sekundara transformatora i elektrolita) poveži ovako na šasiju. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 10 Report Share Posted March 10 Ја то не бих радио обзиром да је у питању "Д" класа ампа.Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
Nixie Posted March 11 Report Share Posted March 11 GND je GND zašto ne bi radio? Neka stavi otpornik 100oma i kondenzator 100nf, ne utiče to nikako na rad pojačala. Samo se obezbedio u slučaju da primar probije na sekundar. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 11 Report Share Posted March 11 Samo se obezbedio u slučaju da primar probije na sekundar. Кол'ко се Ја бавим овим скаламеријама то никад' нисам доживео, чуј да пробије примар?????Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
Nixie Posted March 11 Report Share Posted March 11 Sekundar je namotan preko primara kod torusa, između je tanka folija. Postoji mogućnost naponskog proboja u slučaju pojave visokog napona u mreži, recimo kod udara groma u blizini. NIje loše (iz više razloga) imati uzemljen slepi navojak između primara i sekundara. Meni je samo jedan trafo (od Edelinskog) crkao tako što je izgoreo primar, i to na velikom Crescendo pojačalu, tamo negde 90tih. Da li je došlo do proboja izolacije na sekundar ne znam, nisam ni utvrđivao. Pojačalo je preživelo ta događanja. Bilo je direktno uzemljeno na šasiju. Metalna šasija mora biti uzemljena uvek zbog bezbednosti. Kod EI trafoa i C jezgra lako je odvojiti primar i sekundar. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 11 Report Share Posted March 11 Ма све су то случајеви којих је мало/занемарљиво мало.Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
Nixie Posted March 11 Report Share Posted March 11 Kažem retko se dešava, ali nije isključeno. Skoro sam burazeru menjao trafo u nekim 2+1 Microlab zvučnicima, istopio se primar, crko termalni osigurač. Elektronika je preživela. Ne znam zašto se to desilo. Slab je trafo verovatno pa se dosta grejao u zatvorenoj medijapanskoj kutiji, dok nije stradao lak na žici verovatno. Primar je ispod sekundara, i tanka žica. Quote Link to comment Share on other sites More sharing options...
