mihailo_ Posted September 22, 2023 Report Share Posted September 22, 2023 Pozdrav, da li neko zna gde mogu nabaviti siber potenciometar za Ei Hsr 48? U pitanju je stereo 2x100kOhm logaritamski, inace treba da bude za podesavanje visokih tonova. Ovaj sto sad imam je ispravan ali je polomljen. Dimenzije su 70mm duzina, 10mm sirina i 15mm dubina. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 22, 2023 Report Share Posted September 22, 2023 Нема то нигде, џабе тражиш.Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
zek Posted September 22, 2023 Report Share Posted September 22, 2023 1 sat ranije, mihailo_ said: stereo 2x100kOhm logaritamski, inace treba da bude za podesavanje visokih tonova. Jesi li siguran da je logaritamski a ne linearan, jer je za ton kontrolu? Ovde ima malo kraći, linearni. http://www.interhit.rs/80-siber-potenciometri#/osobine_potenciometr-stereo Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 22, 2023 Report Share Posted September 22, 2023 Логаритамски за јачинуПослато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
zek Posted September 22, 2023 Report Share Posted September 22, 2023 5 sati ranije, giZ_Mo said: Логаритамски за јачину To je OK, ali @mihailo_ je napisao da mu treba logaritamski za visoke tonove, što je meni čudno, mislim da za ton kontrole i balans idu linearni potovi. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 23, 2023 Report Share Posted September 23, 2023 Није добро напис'оПослато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
Gorfili Posted September 24, 2023 Report Share Posted September 24, 2023 Ako je samo slomljen dio gdje dolazi dugme, ili bilo koji plastični dio, popravlja se bez problema.... Quote Link to comment Share on other sites More sharing options...
safet Posted September 28, 2023 Report Share Posted September 28, 2023 superlepkom kao što je jedan majstor zalepio sočivo na laseru pa mu je radio punih 20tak minuta 😜 Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 28, 2023 Report Share Posted September 28, 2023 superlepkom kao što je jedan majstor zalepio sočivo na laseru pa mu je radio punih 20tak minuta Само 20м Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
zek Posted September 28, 2023 Report Share Posted September 28, 2023 24 minuta ranije, giZ_Mo said: Само 20м Послато са M2006C3MNG помоћу Тапатока Pa 20 metara i nije baš malo... 🙃 Quote Link to comment Share on other sites More sharing options...
Gorfili Posted September 29, 2023 Report Share Posted September 29, 2023 7 hours ago, safet said: superlepkom kao što je jedan majstor zalepio sočivo na laseru pa mu je radio punih 20tak minuta 😜 Ne znam šta je taj majstor radio, ali znam da sam bar desetak ovih potenciometara sa HSR-a 48/70/140/160 popravio i radilo je poslije godinama Obično se slome izdanci za dugme i to se uz malo spretnosti rješava bez problema. 3D štampa je uvijek opcija, kome je stalo do uređaja, iscimaće se i završiti... Quote Link to comment Share on other sites More sharing options...
mihailo_ Posted October 1, 2023 Author Report Share Posted October 1, 2023 Uspeo sam nekako zalepiti, nije bas centriran ali se i ne primecuje mnogo. Sad da ne pravim novu temu, video sam na oglasima 4 bas zvucnika Ei AZ 0800/BGO-17, 25w 16ohm svaki i dva bas/srednjotonca Ei AZ 0500/BFP-1, 10W 4ohm. Sve ukupno 6500 dinara ili oko 60eur. Prodavac kaze da su ta 4 basa bila po 2 u kutiji vezani paralelno. Jedino o njima znam da su basevi slicnih oznaka isli u Ei Zk40 ali su bili po 4ohm. Da li se isplati napraviti neku kutiju od tih drajvera obzirom da ne znam koje skretnice su tu isle? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted October 1, 2023 Report Share Posted October 1, 2023 Da li se isplati napraviti neku kutiju od tih drajvera obzirom da ne znam koje skretnice su tu isle?Ја не бих правио јер су то веома стари звучници а скретница која би била идеална ако је тро системска кутија АЅ 803.Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
