David.1992 Posted October 5, 2023 Report Share Posted October 5, 2023 Dobar dan. U fabrici sam zaboravio slušalice Superlux HD-681 EVO. Pošteni nalazač nije prijavio nadređenima da je pronašao izgubljene slušalice. Saznao sam da imaju da se kupe Superlux HDB 671 koje su malo skuplje pa razmatram njih da kupim. Molim Vas za preporuku. Akcenat stavljam na kvalitet zvuka. Superlux HDB 671 Connection via Bluetooth or cable The soft composite material earpads provide incredible isolation and ultimate comfort New developed 40mm driver Much tighter bass, purer vocals. Spaciousness, balance, clarity carried through among ranges Furnished with headphone cable Specifications: Type: Closed Manufacturer: Superlux Model: HDB671-Balck Maximum SLP: 95 dB Impedance: 32 ohms Frequency responce: 20 - 20000 Hz Cable: Replaceable, 1.05 m Straith cable Weight: 238 g Headphones charging time: 2.5 h Music display: 13 h In the black Superlux HD-681 EVO Dinamicke slusalice Circumaural (full size) Semi-open 50 mm Driver Peak SPL: 98 dB Impedance: 32 Ohm Frequency Range: 10 - 30000 Hz Maximum Power: 300 mW 3,5 mm Stereo mini-jack Weight (excluding cable): 276 g Colour: white Quote Link to comment Share on other sites More sharing options...
zek Posted October 5, 2023 Report Share Posted October 5, 2023 671 su skuplje verovatno zato što imaju bluetooth, ali su po svim ostalim parametrima lošije od 681 EVO. Da li ima zvučnih razlika ne znam, neka komentariše neko ko je slušao i jedne i druge. Quote Link to comment Share on other sites More sharing options...
Denny Posted January 6 Report Share Posted January 6 Sennheiser hd 560s. Možda je druga cenovna kategorija ali npr. ja sam ih po preporuci za neke malo bolje slušalice uzeo sebi polovne pre jedno godinu i nešto dana, pošto su mi nove iz radnje bile skupe u tom datom momentu i vrlo sam zadovoljan sa njima. U proseku kad pogledam najviše slušam muziku na njih jer zvuče bolje i od mog vintage a i od modernog Hi-fi sistema koje sam bio više platio. Quote Link to comment Share on other sites More sharing options...
