giZ_Mo Posted July 25, 2017 Report Share Posted July 25, 2017 14 minuta ranije, picturesd said: Zadovoljstvo je imati vas ovde. Све је лепо и красно ал' што не написа одакле си? Quote Link to comment Share on other sites More sharing options...
picturesd Posted July 25, 2017 Author Report Share Posted July 25, 2017 Samir Delic, fororeporter staza 30 god, Novi Pazar. Quote Link to comment Share on other sites More sharing options...
picturesd Posted July 26, 2017 Author Report Share Posted July 26, 2017 Evo fotografija trafoa i gde je lezao. Polomljene su mu plasticne stranice tako da trenutno nemam ideju kako da ga vezem za gumice i rupe sa srafovima. Quote Link to comment Share on other sites More sharing options...
picturesd Posted July 26, 2017 Author Report Share Posted July 26, 2017 Jos jedna fotka. Trafo odozdo, strana sa kojom lezi. Quote Link to comment Share on other sites More sharing options...
picturesd Posted July 26, 2017 Author Report Share Posted July 26, 2017 Jos jedna Quote Link to comment Share on other sites More sharing options...
picturesd Posted July 26, 2017 Author Report Share Posted July 26, 2017 I leziste sa "dascicama" Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 26, 2017 Report Share Posted July 26, 2017 54 minuta ranije, picturesd said: I leziste sa "dascicama" То су летвице. Quote Link to comment Share on other sites More sharing options...
den!s Posted July 26, 2017 Report Share Posted July 26, 2017 On 7/24/2017 at 16:12, Willi Studer said: Transformator zuji u dva slučaja: kada je labav ili kada je opterećen. Pošto sa slike vidim da pojačalo nije osvežavano, verujem da se to dešava zbog suvih elektrolita u napajanju... Da se nadovežem na ovu temu, ako nije problem… 1. Pošto torusni trafo nema limove, šta kod njega može biti labavo pa zuji? Namotaji bakarne žice su popustili? 2. Ako su suvi elektroliti u napajanju, to znači da trafo trpi veća opterećenja od nominalnih? 3. Ovo je strujni filter koji blago zuji. Da li može nešto da se uradi po pitanju toga? Hvala! Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 26, 2017 Report Share Posted July 26, 2017 1 minut ranije, den!s said: А шта је на слици. Quote Link to comment Share on other sites More sharing options...
picturesd Posted July 26, 2017 Author Report Share Posted July 26, 2017 Da li da ovaj trafo lakiram, da izvesni majstor utopi trafo u lak? Vecina iole strucnih ljudi kaze d je zasusio i da je to izvor zujanja. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 26, 2017 Report Share Posted July 26, 2017 3 minuta ranije, picturesd said: Da li da ovaj trafo lakiram, da izvesni majstor utopi trafo u lak? Vecina iole strucnih ljudi kaze d je zasusio i da je to izvor zujanja. Наравно, нећеш ништа покварити. Quote Link to comment Share on other sites More sharing options...
borchee Posted July 26, 2017 Report Share Posted July 26, 2017 On 25. 7. 2017 at 2:52 PM, borchee said: Ako je daskica između trafoa i metalne ploče sa gumenim ležištima i trafo leži na daskici a daskica na metalnoj ploči, tu ti može biti problem. Možda nije jedini, ali uzrok glasnijeg zujanja jeste. Uzmi nešto mekano (npr. sunđer), stavi trafo na njega i proveri...ako sa blizine jedva čujno zuji, utapanje verovatno neće biti potrebno, ali ako ti to neko jeftino napravi - napisa ti @stoN_Cold da neće štetiti. Sunđer ti je samo za pokus, nemoj ga ostaviti unutra. Quote Link to comment Share on other sites More sharing options...
den!s Posted July 26, 2017 Report Share Posted July 26, 2017 @stoN_Cold Strujni filter. Moduli Dezorel filtera. Quote Link to comment Share on other sites More sharing options...
den!s Posted July 27, 2017 Report Share Posted July 27, 2017 13 sati ranije, stoN_Cold said: А шта је на слици. Meni na telefonu pokazuje fotografiju, a na računaru ne? Quote Link to comment Share on other sites More sharing options...
picturesd Posted July 27, 2017 Author Report Share Posted July 27, 2017 Jel su ovi limeni nosaci originalni? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 27, 2017 Report Share Posted July 27, 2017 Из ког уређаја је тај трансформатор? Quote Link to comment Share on other sites More sharing options...
borchee Posted July 27, 2017 Report Share Posted July 27, 2017 Da, limeni nosači su originalni, ali to je trafo za B750 a ne B750mkII. U takvom smislu si možeš napraviti nosače i za tvog. Quote Link to comment Share on other sites More sharing options...
picturesd Posted July 27, 2017 Author Report Share Posted July 27, 2017 Pise Revox B750. Ovako je naziv fotografije: "Studer_Revox_B750_Trafo_Kabelsatz_33460_0" Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 27, 2017 Report Share Posted July 27, 2017 7 minuta ranije, picturesd said: Pise Revox B750. Ovako je nazif fotografije: "Studer_Revox_B750_Trafo_Kabelsatz_33460_0" Да, али не МК2. МК2 има прикључке. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 27, 2017 Report Share Posted July 27, 2017 Ајде сликај трансформатор али тако да се види део у који улази навртка. Quote Link to comment Share on other sites More sharing options...
picturesd Posted July 27, 2017 Author Report Share Posted July 27, 2017 Nema toga dela gde ulazi navrtka, izlomljeno je. Vidi se na gornjim fotkama. :/ Quote Link to comment Share on other sites More sharing options...
borchee Posted July 27, 2017 Report Share Posted July 27, 2017 U razmislak...uzmeš neki L-profil, malo režeš, napraviš rupe u skladu sa gumama, zaljepiš na trafo, prišarafiš i to je to. Još elegantnije ako u L-profil urežeš navoj. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 27, 2017 Report Share Posted July 27, 2017 3 sati ranije, picturesd said: Nema toga dela gde ulazi navrtka, izlomljeno je. Направи тј. импровизуј. Quote Link to comment Share on other sites More sharing options...
picturesd Posted July 28, 2017 Author Report Share Posted July 28, 2017 Ovo je mnogo dobro objasnjeno. Hvala svima, hvala stoN_Cold, hvala borchee. Lep pozdrav. p.s. Trafo je otiso na lakiranje. Cekam da se vrati od "frizera". Quote Link to comment Share on other sites More sharing options...
den!s Posted July 28, 2017 Report Share Posted July 28, 2017 1. Pošto torusni trafo nema limove, šta kod njega može biti labavo pa zuji? Namotaji bakarne žice su popustili?2. Ako su suvi elektroliti u napajanju, to znači da trafo trpi veća opterećenja od nominalnih? Quote Link to comment Share on other sites More sharing options...
