impuls Posted January 8, 2012 Report Posted January 8, 2012 http://www.ebay.ch/itm/TDK-MA-X-90-BLANK-AUDIO-CASSETTE-TAPE-NEW-SEALED-GERMANY-1990-/260927823201?pt=Audio_Zubeh%C3%B6r&hash=item3cc0829d61 Quote
Tutti Posted January 8, 2012 Report Posted January 8, 2012 Kada nema drugih dobre su i normalke,ja nabavio TDK D 60 iz 1986 8 komada.Narednih dana ocekujem jos normalki istog proizvodjaca starije proizvodnje.Sta da kazem... :thumbsup2 Po meni jedna od najboljih normalki koje sam koristio i jedna od najlepsih. Quote
vlado78 Posted January 8, 2012 Report Posted January 8, 2012 Treba da mi stigne(izmedju ostalih) jedna tdk-ar100. Mislim da sam nekada davno imao jednu i da sam na trenutak pomislio da je hrom traka.Jedva cekam a takodje ce tu biti po nekoliko maxell xll-s60,tdk d90-60 u skoro svim verzijama, sony ux i uxs, tdk-sa90, basf chrome extra90,sony super ef60,i jos svasta nesto a takodje se radujem i philips CDone normalkama na koje moj Denon snima za oskara Quote
ScepanBG Posted January 8, 2012 Report Posted January 8, 2012 Evo BASF kaseta iz moje kolekcije,mada sam u medjuvremenu nasao jos nekoliko(koje nisu na ovoj slici). Quote
vlado78 Posted January 8, 2012 Report Posted January 8, 2012 Scepane, kakve su Emtec sound1 normalke?Imalo je nekoliko 60-ki u ponudi ali se plasim problema(vec sam spominjao da moji dekovi(osim teshnics rs-bx606)tesko mogu da snime bez izoblicenja) kao sa basf hrom trakama. Quote
vlado78 Posted January 9, 2012 Report Posted January 9, 2012 Opet malo svega http://project-c90.magnetofon.de/tapes_tdk.htm Quote
ScepanBG Posted January 13, 2012 Report Posted January 13, 2012 Scepane, kakve su Emtec sound1 normalke?Imalo je nekoliko 60-ki u ponudi ali se plasim problema(vec sam spominjao da moji dekovi(osim teshnics rs-bx606)tesko mogu da snime bez izoblicenja) kao sa basf hrom trakama. Nisam ih jos probao. Quote
Koko Bil Posted January 18, 2012 Report Posted January 18, 2012 Za mene su TDK normal trake najbolje koje sam imao prilike da probam, mada nemam egzotiku od traka, kao neki drugi clanovi. Po meni jedna od najboljih normalki koje sam koristio i jedna od najlepsih. Nedavno sam kupio 10 ovih kaseta i mogu prijaviti da sam krajnje nezadovoljan. Prvoj kaseti koju sam snimio mehanizam je otkazao već pri prvom presluÅ¡avanju. Drugu nisam mogao da kalibriÅ¡em - u high poziciji morao sam joÅ¡ da povećam rec level a bias je otiÅ¡ao do kraja levo, u -20 i opet je levi kanal treptao. Kad sam umesto nje uzeo maxell ur60 koja u lokalnoj fotokopirnici koÅ¡ta 80 dinara, nije bilo nikakvih problema. Malo pomerim level, malo bias, i kad se namesti - stoji kao zakucano na markeru. Jednom kad me ne bude mrzelo otpakovaću ih sve i videti ima li upotrebljivih. InaÄe, navodno su made in japan i 1985. godiÅ¡te Moguće i da su nekakvi pirati, zato sam i stavio sliku. Ako jesu, onda dobro. Ne sećam sekoliko sam ih platio ali nije bilo preterano skupo. Ako nisu, onda sam jako razoÄaran u tdk. Quote
suca77 Posted January 19, 2012 Report Posted January 19, 2012 Nedavno sam kupio 10 ovih kaseta i mogu prijaviti da sam krajnje nezadovoljan. Prvoj kaseti koju sam snimio mehanizam je otkazao već pri prvom presluÅ¡avanju. Drugu nisam mogao da kalibriÅ¡em - u high poziciji morao sam joÅ¡ da povećam rec level a bias je otiÅ¡ao do kraja levo, u -20 i opet je levi kanal treptao. Kad sam umesto nje uzeo maxell ur60 koja u lokalnoj fotokopirnici koÅ¡ta 80 dinara, nije bilo nikakvih problema. Malo pomerim level, malo bias, i kad se namesti - stoji kao zakucano na markeru. Jednom kad me ne bude mrzelo otpakovaću ih sve i videti ima li upotrebljivih. InaÄe, navodno su made in japan i 1985. godiÅ¡te Moguće i da su nekakvi pirati, zato sam i stavio sliku. Ako jesu, onda dobro. Ne sećam sekoliko sam ih platio ali nije bilo preterano skupo. Ako nisu, onda sam jako razoÄaran u tdk. Kolega nisi ti jedini kome se to desava kasete su sigurno originalne, jednostavno godine su ucinile svoje, emulzija na trakama nije vecna odnosno popusta vremenom, samo sto neke manje neke vise pokazuju probleme pri snimanju, a neke rade normalno Zasto je to tako ne bih znao da ti objasnim znam samo da sam se puno puta iznervirao, mislio sam da mi je deck neispravan medjutim naidje po neka kaseta koja mi ne pravi probleme i shvatim da u stvari nije do njega vec do kaseta. Nazalost kako godine budu prolazile sve vise cemo se sretati s tim problemom, pomiri se sa tim Quote
profesor Posted January 19, 2012 Report Posted January 19, 2012 Ja nabavio jos malo normalki TDK D 90 iz 1988. godine.Nazalost prethodnih dana nisam snimao prethodne modele kao sto sam obecao zbog smrtnog slucaja u zeninoj familiji.Preminuo joj je teca pa sam bio zauzet organizacijom sahrane.U narednom periodu cu to uraditi i objaviti rezultate,a mozda to uradim i kod nekih clanova foruma koji imaju top modele kaset dekova.Slike idu kasnije. Quote
profesor Posted January 19, 2012 Report Posted January 19, 2012 Ja sam nabavio normal kasete tdk d 90 iz 1988. godine,kao sto sam i napisao u nekom prethodnom postu.Na zalost nisam ispunio obecanje o testiranju prethodnih kaseta, zbog smrtnog slucaja u zeninoj familiji.Preminuo joj je teca pa sam bio zauzet pripremanjem sahrane.U narednom periodu cu testiirati kasete, kao sto sam rekao na mojim dekovima, mada postoji mogucnost da ih testiram kod nekih clanova foruma koji imaju top modele dekova.U svakom slucaju iznecu svoje rezultate i zapazanja.Slike idu kasnije. Quote
aco Posted January 19, 2012 Report Posted January 19, 2012 Ja sam nabavio normal kasete tdk d 90 iz 1988. godine,kao sto sam i napisao u nekom prethodnom postu.Na zalost nisam ispunio obecanje o testiranju prethodnih kaseta, zbog smrtnog slucaja u zeninoj familiji.Preminuo joj je teca pa sam bio zauzet pripremanjem sahrane.U narednom periodu cu testiirati kasete, kao sto sam rekao na mojim dekovima, mada postoji mogucnost da ih testiram kod nekih clanova foruma koji imaju top modele dekova.U svakom slucaju iznecu svoje rezultate i zapazanja.Slike idu kasnije. Te D normal kasete nikad nisu ni bile dobre.I u ona vremena da bi dobio visoke trebao si Bias pomeriti do nebesa Quote
vlado78 Posted January 19, 2012 Report Posted January 19, 2012 Ja sam sa ovim novijim tdk-d 90 prilicno zadovoljan, međutim kada sam probao da snimim na tdk-ar100 nisam mogao da verujem da je to normal kaseta.Vec sam je davno imao i bio prezadovoljan a sada je opet tako.Za mene, to je ubedljivo najbolja normal kaseta.Citao sam po stranim forumima i ljudi kazu da su zbog nje prestali da kupuju sa90 Quote
vlado78 Posted January 19, 2012 Report Posted January 19, 2012 kupio sam je polovnu, prilicno ocuvanu.Ostavicu da vidite koliko je kostala(mada znam da ce mnogi kazati da ustvari toliko i vredi ali ipak nije tako). http://www.limundo.com/kupovina/Tehnika/Audio/Ostalo/kaseta-TDK-AR100/4128768 a tek ove http://www.limundo.com/kupovina/kasete-MAXELL-XLII90-4-komada-/4128759 ili ove http://www.limundo.com/kupovina/kasete-MAXELL-XLII-S-60-2-komada-/4128548 ili ove http://www.limundo.com/kupovina/kasete-SONY-UX-90-3-komada-/4128740 i jos dosta toga... Polovno ali solidno ocuvano Quote
ScepanBG Posted January 19, 2012 Report Posted January 19, 2012 Malo Raks kaseta u kolekciji. Secam se da su Raks Cabrio kasete bile da se kupe kod nas u Robnim kucama Beograd. Quote
vlado78 Posted January 19, 2012 Report Posted January 19, 2012 Secam se da su Raks Cabrio kasete bile da se kupe kod nas u Robnim kucama Beograd. Imalo ih je ponegde, ja sam ih kupovao jer su bile dobre a opet dosta jeftinije.Mislim da sam radije kupovao sd-sx, takodje cro2. Kada nije bilo nekog izbora za cro2 znam da sam kupovao Sony superEF, koje su bile odlicne.Ima li nesto da se kupi po nasim prodavnicama osim Maxell UR,Tdk-d ili Sony ef/hf(novijih modela)? Quote
stex Posted January 20, 2012 Report Posted January 20, 2012 Tdk D su bile i ostale Ä‘ubre, a Tdk AR, je odliÄna kaseta. Quote
vlado78 Posted January 20, 2012 Report Posted January 20, 2012 Tdk D su bile i ostale Ä‘ubre, a Tdk AR, je odliÄna kaseta. Tako je, snimak elektronske muzike prepune dubokih basova, sarenih srednjih sa obiljem reverb-a kao i gomilom svakakvih visokih tonova na nivou i od preko +4db bez puno podesavanja bias-a i takodje bez izoblicenja.Stvarno vrhunska kaseta.Da mogu da nabavim koju novu bio bih srecan kao dete. Quote
vlado78 Posted January 24, 2012 Report Posted January 24, 2012 Malo i Fuji-a u kolekciji. Kako izgledaju, imas li golisav komad? Quote
acazr Posted January 26, 2012 Report Posted January 26, 2012 Možda nekom treba. p.s. nemam veze s oglasom http://www.kupindo.c...-m-audio-kasete Quote
