djuki035 Posted May 16, 2016 Report Share Posted May 16, 2016 Da li je neko imao iskustva sa ovim vintage cd playerom? da li je kvalitetan ili da se zaobilazi? i kakav je zvucno ako nekio zna ? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted May 16, 2016 Report Share Posted May 16, 2016 2 minuta ranije, djuki035 said: da se zaobilazi? Заобиђи. Quote Link to comment Share on other sites More sharing options...
djuki035 Posted May 16, 2016 Author Report Share Posted May 16, 2016 mator je dosta 85 godiste mogu da biram izmedju njega i sony cdp xe 330 pa od ova dva jedan, na poklon dace mi covek Quote Link to comment Share on other sites More sharing options...
marko012po Posted May 16, 2016 Report Share Posted May 16, 2016 da se zaobilazi? Заобиђи. bas toliko los? Sent from my SM-T310 using Tapatalk Quote Link to comment Share on other sites More sharing options...
djuki035 Posted May 16, 2016 Author Report Share Posted May 16, 2016 9 minuta ranije, stoN_Cold said: Заобиђи. mator je dosta 85 godiste mogu da biram izmedju njega i sony cdp xe 330 pa od ova dva jedan, na poklon dace mi covek Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted May 16, 2016 Report Share Posted May 16, 2016 3 minuta ranije, marko012po said: bas toliko los? Матор. Quote Link to comment Share on other sites More sharing options...
djuki035 Posted May 16, 2016 Author Report Share Posted May 16, 2016 Just now, stoN_Cold said: Матор. sta mislis za onaj sony cdp xe330 Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted May 16, 2016 Report Share Posted May 16, 2016 Just now, djuki035 said: mator je dosta 85 godiste mogu da biram izmedju njega i sony cdp xe 330 pa od ova dva jedan, na poklon dace mi covek Боље гледај CD-X 880. Quote Link to comment Share on other sites More sharing options...
djuki035 Posted May 16, 2016 Author Report Share Posted May 16, 2016 5 minuta ranije, stoN_Cold said: Боље гледај CD-X 880. ma moram da odaberem jedan od ova dva jer dobijam od caletovog druga ta dva ima pa mi reko da uzmem jedan Quote Link to comment Share on other sites More sharing options...
zek Posted May 16, 2016 Report Share Posted May 16, 2016 Ako možeš uzmi oba na probu, pa koji ti bolje legne u tvoj sistem taj zadrži. Quote Link to comment Share on other sites More sharing options...
djuki035 Posted May 16, 2016 Author Report Share Posted May 16, 2016 1 minut ranije, zek said: Ako možeš uzmi oba na probu, pa koji ti bolje legne u tvoj sistem taj zadrži. mogu da uzmem oba pa jedino da zakacim oba i isti disk dda vidim koji se bolje cuje Quote Link to comment Share on other sites More sharing options...
djuki035 Posted May 16, 2016 Author Report Share Posted May 16, 2016 2 minuta ranije, zek said: Ako možeš uzmi oba na probu, pa koji ti bolje legne u tvoj sistem taj zadrži. po specs yamaha ima dynamic range 96db a sony 92 db,,,,, ostalo isto po specs Quote Link to comment Share on other sites More sharing options...
zek Posted May 16, 2016 Report Share Posted May 16, 2016 Ma ne gledaj te cifre, to ništa ne znači. Kad ga ubaciš u tvoj lanac sa pojačalom i zvučnicima, onda ćeš da vidiš kako koji svira. Slušaj što duže možeš, za sat-dva se ne može steći dobar utisak. Po mogućstvu nekoliko dana i sa različitim diskovima, da vidiš kako koji čita i lošije narezane diskove, i lošije originale (bugare) i sl. Quote Link to comment Share on other sites More sharing options...
djuki035 Posted May 16, 2016 Author Report Share Posted May 16, 2016 4 minuta ranije, djuki035 said: po specs yamaha ima dynamic range 96db a sony 92 db,,,,, ostalo isto po specs da li to utice na kvalite zvuka Quote Link to comment Share on other sites More sharing options...
djuki035 Posted May 16, 2016 Author Report Share Posted May 16, 2016 5 minuta ranije, zek said: Ma ne gledaj te cifre, to ništa ne znači. Kad ga ubaciš u tvoj lanac sa pojačalom i zvučnicima, onda ćeš da vidiš kako koji svira. Slušaj što duže možeš, za sat-dva se ne može steći dobar utisak. Po mogućstvu nekoliko dana i sa različitim diskovima, da vidiš kako koji čita i lošije narezane diskove, i lošije originale (bugare) i sl. tako cy i uraditi hvala ti Quote Link to comment Share on other sites More sharing options...
djuki035 Posted May 22, 2016 Author Report Share Posted May 22, 2016 uzeo sam sony mnogo je bolji laser brze cita i ne preskace dok yamaha je znala da preskoci Quote Link to comment Share on other sites More sharing options...
marko012po Posted May 22, 2016 Report Share Posted May 22, 2016 uzeo sam sony mnogo je bolji laser brze cita i ne preskace dok yamaha je znala da preskoci Imam taj Yamaha plejer, istina, zna da preskoci. Sent from my GT-I9300 using Tapatalk Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted May 22, 2016 Report Share Posted May 22, 2016 Мени Јамаха никада није прескочила. Quote Link to comment Share on other sites More sharing options...
djuki035 Posted May 22, 2016 Author Report Share Posted May 22, 2016 STARA DOSTA PA VEROVATNO ZATO PRESKOCI IAKO IZGLEDA KAO NOVA. I YAMAHA IMA MALO VECU DUBINU U ODNOSU NA SONY. Quote Link to comment Share on other sites More sharing options...
