TERMINATOR Posted January 6, 2014 Report Share Posted January 6, 2014 Problem je po malo cudan.Rezac,programi svi rade kako valja.Ali jedan album konkretno Riblje Corbe pravi problem.Burrn uopste ne primecuje pesme,a nero ih stavi na listu,ali nece da nareze. Quote Link to comment Share on other sites More sharing options...
trotter Posted January 6, 2014 Report Share Posted January 6, 2014 Probaj da preimenujeÅ¡ pesme tako da nazivi budu bez latiniÄnih karaktera. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted January 6, 2014 Report Share Posted January 6, 2014 Skrati ime dotiÄnoj pesmi, može i to da bude Quote Link to comment Share on other sites More sharing options...
TERMINATOR Posted January 6, 2014 Author Report Share Posted January 6, 2014 Skrati ime dotiÄnoj pesmi, može i to da bude Nije samo jedna pesma.Sve su na listi u pitanju.Jednu sam prikazao da bi se videlo da sa radi o waw fajlu. Quote Link to comment Share on other sites More sharing options...
TERMINATOR Posted January 6, 2014 Author Report Share Posted January 6, 2014 Ima li neko ideju ?Kako da resim problem? Quote Link to comment Share on other sites More sharing options...
Vlajo Posted January 6, 2014 Report Share Posted January 6, 2014 Mene Äesto zeza Burrrn, ali sam mu naÅ¡ao caku, vrlo prostu. Deinstaliram pa instaliram ponovo i onda radi. Uvek uspeva. Probaj i to ... Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted January 7, 2014 Report Share Posted January 7, 2014 Ja mislim da je Trotter u pravu - reimenuj fajlove na disku i promeni nazive u ".cue" fajlu. Verovatno smeta ÄŒorba. Quote Link to comment Share on other sites More sharing options...
rodoljub68 Posted January 7, 2014 Report Share Posted January 7, 2014 Ipak treba da se proveri da li je samo taj album u pitanju. Da se meni to desilo probao bih sa drugim programom. Ja iskljuÄivo, za audio fajlove, koristim Conwon Media Center. Mali je i besplatan. Sa Burrnom imam veÄito problema, a Nero ume da izda, a da ne znaÅ¡. Iskren pozdrav i svako dobro. Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted January 7, 2014 Report Share Posted January 7, 2014 koristim Conwon Media Center Probao sam ga. ali ne vidim kako se rešava situacija kada su sve pesme smeštene u jedan veliki fajl? Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted January 7, 2014 Report Share Posted January 7, 2014 Nisi naveo da li je album u jednom FLAC ili APE fajlu sa CUE sheetom iz koga pokuÅ¡avaÅ¡ da režeÅ¡ CD. Ako jeste, raspakuj album u pojedinaÄne numere u WAV-u i preimenuj fajlove u redne brojeve: 01, 02, 03... Quote Link to comment Share on other sites More sharing options...
trotter Posted January 7, 2014 Report Share Posted January 7, 2014 Koliko vidim sa priložene sliÄice on ima svaku numeru kao poseban WAV fajl. Ako su ti fajlovi standardni dvokanalni, 16-bitni i sa sempling rate od 44.1kHz ne vidim Å¡ta je problem da se narežu. Burrrn sam koristio sigurno 5-6 godina (dok sam joÅ¡ rezao diskove...) i apsolutno nikad nisam imao problem kad su ispoÅ¡tovana navedena pravila koje sam pomenuo iznad. Izuzetak su bili pokuÅ¡aji rezanja albuma nekih brazilskih izvoÄ‘aÄa gde su nazivi pesama na portugalskom jeziku koji ima karakteristiÄna slova i koje Burrrn nije prepoznavao. Moguće je da je i sa latinicom (ž, Å¡, Ä‘, Ä, ć) isti problem. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted January 7, 2014 Report Share Posted January 7, 2014 Koliko vidim sa priložene sliÄice on ima svaku numeru kao poseban WAV fajl. Ako su ti fajlovi standardni dvokanalni, 16-bitni i sa sempling rate od 44.1kHz ne vidim Å¡ta je problem da se narežu. Burrrn sam koristio sigurno 5-6 godina (dok sam joÅ¡ rezao diskove...) i apsolutno nikad nisam imao problem kad su ispoÅ¡tovana navedena pravila koje sam pomenuo iznad. Izuzetak su bili pokuÅ¡aji rezanja albuma nekih brazilskih izvoÄ‘aÄa gde su nazivi pesama na portugalskom jeziku koji ima karakteristiÄna slova i koje Burrrn nije prepoznavao. Moguće je da je i sa latinicom (ž, Å¡, Ä‘, Ä, ć) isti problem. Windows... Quote Link to comment Share on other sites More sharing options...
TERMINATOR Posted January 7, 2014 Author Report Share Posted January 7, 2014 Sve su waw fajlovi.Problem je samo sa tim albumom,ostalo sve radi.Nije do programa jer ni nero ni burrn isto ***** prave.Probacu da preimenujem pa saljem rezultate. Quote Link to comment Share on other sites More sharing options...
TERMINATOR Posted January 7, 2014 Author Report Share Posted January 7, 2014 Izveo sam mali eksperiment.Umesto imena pesme napisao samo 1 i radi .Znaci problem je u nazivu pesme ipak.. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted January 7, 2014 Report Share Posted January 7, 2014 Bitno da je rešeno. Sad sam i ja sebi našao baš taj album malo da slušam. Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted January 8, 2014 Report Share Posted January 8, 2014 Ja koristim foobar za rezanje audio cd-a i nikad nisam imao nikakav problem.Selektujem pesme odmah sa liste i on sve ostalo odradi(konvertovanje,rezanje). Quote Link to comment Share on other sites More sharing options...
TERMINATOR Posted January 8, 2014 Author Report Share Posted January 8, 2014 Ja koristim foobar za rezanje audio cd-a i nikad nisam imao nikakav problem.Selektujem pesme odmah sa liste i on sve ostalo odradi(konvertovanje,rezanje). Nikad njega nisam probao za rezanje. Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted January 8, 2014 Report Share Posted January 8, 2014 Ovu komponentu http://www.foobar2000.org/components/view/foo_burninate ako nemash skini i ubaci u foobar components(levi dupli klik na nju).Ako imash obelezi listu za rezanje desni klik mishom na listu pa convert pa na dnu liste write audio cd. Quote Link to comment Share on other sites More sharing options...
TERMINATOR Posted January 8, 2014 Author Report Share Posted January 8, 2014 Ovu komponentu http://www.foobar2000.org/components/view/foo_burninate ako nemash skini i ubaci u foobar components(levi dupli klik na nju).Ako imash obelezi listu za rezanje desni klik mishom na listu pa convert pa na dnu liste write audio cd. Hvala. Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted March 14, 2014 Report Share Posted March 14, 2014 Ja koristim foobar za rezanje audio cd-a i nikad nisam imao nikakav problem.Selektujem pesme odmah sa liste i on sve ostalo odradi(konvertovanje,rezanje). Da li koristiti Replay Gain i Dither kao opcije koje daje pri narezivanju? Da li je na kraju dana snimak bolji sa selektovanim pomenutim opcijama ili bez njih, zna li neko? Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted March 14, 2014 Report Share Posted March 14, 2014 Dither ne koristim(jer rezem cd iz flaca,ako rezesh iz mp3 ili nekog drugog lossy ukljuchi),replay gain (apply album gain,prevent clipping according to album peek) da. Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted March 15, 2014 Report Share Posted March 15, 2014 Hvala Krsh! Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted March 15, 2014 Report Share Posted March 15, 2014 Nema nachem druze . Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted May 4, 2014 Report Share Posted May 4, 2014 Dither ne koristim(jer rezem cd iz flaca,ako rezesh iz mp3 ili nekog drugog lossy ukljuchi),replay gain (apply album gain,prevent clipping according to album peek) da. I samo da dodam, ako neko zeli da nareze disk koji ide u kontinuitetu, tj. nema razmaka izmedju pesama nego se nastavljaju jedna na drugu (npr. The Dark Side of the Moon), obavezno u meniju stiklirati i burn gapleslly. Quote Link to comment Share on other sites More sharing options...
