Mingus,Mingus Posted January 21, 2013 Report Share Posted January 21, 2013 Verovatno je bilo ali ne mogu da pronadjem.Da li postoje bolji drjveri i softver za ovu karticu. http://www.esi-audio.com/products/julia/ http://download.esi-audio.com/?w=esi&p=6&g=1&l=en Quote Link to comment Share on other sites More sharing options...
pantaNS Posted January 21, 2013 Report Share Posted January 21, 2013 http://download.esi-audio.com/?w=esi&p=6&g=1&l=en Quote Link to comment Share on other sites More sharing options...
garson Posted January 21, 2013 Report Share Posted January 21, 2013 Bolji od cega? Quote Link to comment Share on other sites More sharing options...
Mingus,Mingus Posted January 22, 2013 Author Report Share Posted January 22, 2013 Od fabrickih i dodatni software. Quote Link to comment Share on other sites More sharing options...
SomiKnight Posted January 22, 2013 Report Share Posted January 22, 2013 Ne znam sta ce ti bolji, tj sta fali ovim drajverima i software-u? Da se ogradim doduse od verzije 1.15 drajvera koja ne radi bas dobro, meni licno se desava da se izgubi zvuk nacisto na primer u operi, pa moram da je restartujem i slicno, tako da sam se vratio na 1.11 , doduse trenutno probam 1.14 i za sad je ok. Quote Link to comment Share on other sites More sharing options...
Mingus,Mingus Posted January 23, 2013 Author Report Share Posted January 23, 2013 Mislio sam mozda da ne postoje bolji a i softver. Quote Link to comment Share on other sites More sharing options...
Mostly Harmless Posted June 15, 2013 Report Share Posted June 15, 2013 DoÅ¡la mi je, neplanirano, pod ruku ova kartica. Kakva su vaÅ¡a iskustva, vredi li je saÄuvati da odraÄ‘uje funkciju DAC-a ili prodati pa uložiti u neki DAC tipa Lampucera, recimo? Quote Link to comment Share on other sites More sharing options...
Mingus,Mingus Posted June 19, 2014 Author Report Share Posted June 19, 2014 Da ne zapocinjem novu temu nastavi cu se.Hteo bih da zamenim karticu ali da ima izlaz za predpojacalo i slusalice sa mikrofonom.Sta preporucu je te a da je u klasi ove kartice,zvucno i po ceni.Moze i usb.Imam Philips Integralac i Sony zvucnike. http://www.player.rs/pci/e/esi-julia/pro/6223 Kratak opis Juli@ features highest quality 24-bit 192Khz ADC (114dB) and DAC (112dB) for the best quality audio. The unique swappable I/O socket allows you to choose your analog connectors between unbalanced RCA jacks and balanced TRS jacks. You don't have to configure your studio to Juli@, you can configure Juli@ to your studio. Juli@'s EWDM drivers provide unparalled performance and stability, and provide support for all professional audio applications using ASIO and GSIF drivers. With the powerful EWDM drivers and MIDI I/O Juli@ is perfect for post-production studios, one man bands and use with mixers and you can monitor the inputs and outputs directly through the digital mixer.... Da li je moguce koristiti mikrofon sa slusalicama ili samo mikrofon i ako ne moze dali postoji dodatak.Treba mi radi ucenja stranog jezika. Quote Link to comment Share on other sites More sharing options...
