bkrmar Posted August 13, 2019 Report Posted August 13, 2019 Na prodaju odličan visokotonac iz ličnog projekta, u odličnom stanju, kao nov. Nepopravljan i premotavan. Skinut sa kutije, zvučno perfektan. DT-75/8 Impedance (Z) 8 Ω Frequency range fx-20,000 Hz Resonant frequency (fs) 2,000 Hz Rec. crossov. frequ. (fmax. ) (12 dB/oct. ) 3,000 Hz Power rating (RMS) 25 W Peak music power output (MAX) 50 W Sensitivity 90 dB/W/m Voice coil diameter Ø 25 mm Magnet diameter Ø 60 mm Mounting cutout 62 x 70 mm Mounting depth 28 mm Dimensions 93 x 69 x 28 mm Width 93 mm Height 69 mm Depth 28 mm Admiss. ambient temp. 0-40 ° C Weight 0.335 kg Packing unit 1 30 EUR Beograd 063/344-118 Šaljem slike po potrebi
