sp300b Posted September 14, 2008 Report Share Posted September 14, 2008 Link to comment Share on other sites More sharing options...
Chakija Posted September 14, 2008 Report Share Posted September 14, 2008 BRAVO Jedva cekam utiske Link to comment Share on other sites More sharing options...
stein Posted September 16, 2008 Author Report Share Posted September 16, 2008 Link to comment Share on other sites More sharing options...
Zen Mod Posted September 16, 2008 Report Share Posted September 16, 2008 vooooooooodooooooooooooooo Link to comment Share on other sites More sharing options...
stein Posted September 16, 2008 Author Report Share Posted September 16, 2008 More voodoo... [attachment=1]f5boxing4.JPG[/attachment][attachment=0]f5boxing5.JPG[/attachment] Link to comment Share on other sites More sharing options...
stein Posted September 16, 2008 Author Report Share Posted September 16, 2008 filteri....[attachment=0]f5boxing6.JPG[/attachment] sve je leglo na mesto, nasuprot svim oÄekivanjima... Link to comment Share on other sites More sharing options...
Zen Mod Posted September 16, 2008 Report Share Posted September 16, 2008 ........ sve je leglo na mesto, nasuprot svim oÄekivanjima... Link to comment Share on other sites More sharing options...
stein Posted September 16, 2008 Author Report Share Posted September 16, 2008 even more woodoo[attachment=1]f5boxing7.JPG[/attachment][attachment=0]f5boxing8.JPG[/attachment] Link to comment Share on other sites More sharing options...
Zen Mod Posted September 16, 2008 Report Share Posted September 16, 2008 samoo jedno pitanje - gde si predvideo rupe na dnu i poklopcu ? svaki amp u A klasi mora imati provetravanje kutije , ako ces da ga pravis inzinjerski ; ako neces - onda idi na Passdiy site i pogledaj gomilu primera kako ne treba praviti amp Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 16, 2008 Report Share Posted September 16, 2008 samoo jedno pitanje - gde si predvideo rupe na dnu i poklopcu ? svaki amp u A klasi mora imati provetravanje kutije , ako ces da ga pravis inzinjerski ; ako neces - onda idi na Passdiy site i pogledaj gomilu primera kako ne treba praviti amp Link to comment Share on other sites More sharing options...
stein Posted September 16, 2008 Author Report Share Posted September 16, 2008 samoo jedno pitanje - gde si predvideo rupe na dnu i poklopcu ? svaki amp u A klasi mora imati provetravanje kutije , ako ces da ga pravis inzinjerski ; ako neces - onda idi na Passdiy site i pogledaj gomilu primera kako ne treba praviti amp Link to comment Share on other sites More sharing options...
stefaca Posted September 16, 2008 Report Share Posted September 16, 2008 a zasto bas made in china? mislim da je made in PRC zvucnije. Link to comment Share on other sites More sharing options...
Filipescu Posted September 16, 2008 Report Share Posted September 16, 2008 Definitivno made by PRC&KO Link to comment Share on other sites More sharing options...
stein Posted September 16, 2008 Author Report Share Posted September 16, 2008 pa slika sve govori: "Opasno po život!" napravljeno u Kini mogli bi to uvesti kao obavezujuće... Link to comment Share on other sites More sharing options...
Zen Mod Posted September 17, 2008 Report Share Posted September 17, 2008 4n7 preko svakog celog sekundara dakle - od ~ do ~ , preskaces srednji izvod Link to comment Share on other sites More sharing options...
stein Posted September 17, 2008 Author Report Share Posted September 17, 2008 Da... da... A ova Å¡ema?[attachment=0]f5playing.JPG[/attachment] Link to comment Share on other sites More sharing options...
Chakija Posted September 17, 2008 Report Share Posted September 17, 2008 Samo nek se dobro ukrchka...na tihoj vatri jedno 12-tak sati i ondak da cujemo jel valja ta sklopocija stagod Link to comment Share on other sites More sharing options...
Borko_KA Posted September 17, 2008 Report Share Posted September 17, 2008 BRAVO BRAVO u rekordnom roku! Puscaj pa pisi kako se cuje (ne mora bas 12 sati sacekaj sat dva i kreci). Link to comment Share on other sites More sharing options...
stein Posted September 17, 2008 Author Report Share Posted September 17, 2008 Za sada mogu da kažem sasvim pouzdano sledeće: 1) Sastavljanje je zbog mojih unutraÅ¡njih demona bilo praćeno, sada je već jasno, nepotrebnim nervozama... 2) PojaÄalo se ne Äuje. Kada se priÄ‘e kućiÅ¡tu, trafo tiho zvrnda (zuji, whatever) meÄ‘utim, sa potenciometrom otvorenim (kao da ga i nema) na zvuÄnicima nema ama baÅ¡ ni trunke bilo Äega. Podrazumeva se da je pojaÄalo ukljuÄeno 3) Prelazne pojave kod paljenja: nema. Ni membrana da se zaljulja (reÄ je o Fostexima sa nominalno 94dB/W/m - oni definitivno pokažu takve mane pre bilo kojih manje osetljivih) 4) Ovo je prvo pojaÄalo posle mog Stradivarija koje svira onako kako je Bog zapovedio (a koje sam srećan da imam - imao - Äuo kod sebe) Dalje utiske ću kako budu nadolazili... I evo joÅ¡ jedne sliÄke pred zatvaranje... [attachment=0]f5boxing9.JPG[/attachment] Uz sliku bih dodao par komentara... Gore na sredini se nalazi centralna taÄka uzemljavanja. Na nju se nakaÄena dva NTC termistora koji uzemljavaju nulte potencijale (tzv mase), uzemljenje iz elektriÄne mreže, oba hladnjaka (poÅ¡to nemaju drugi meÄ‘usobni elektriÄni kontakt) i prednja ploÄa na kojoj je trafo na koju je nakaÄen i "screen" izvod sa trafoa. Vod uzemljenja je prepleten sa dva voda za napajanja (~220V/50Hz) a dole se vidi da je na luster klemni ubaÄen 0.1uF/275V izvaÄ‘en iz jednog napajanja i NTC u grani primara. Sve mase su spojene na jednom jedinom Å¡arafu (po kanalu) a odatle se uzemljava na već spomenuti Å¡araf na zadnjoj ploÄi preko termistora. I to je to. Sve ostalo već znate... Link to comment Share on other sites More sharing options...
Filipescu Posted September 17, 2008 Report Share Posted September 17, 2008 BRAVO, vidimo se uskoro! Link to comment Share on other sites More sharing options...
sp300b Posted September 17, 2008 Report Share Posted September 17, 2008 Link to comment Share on other sites More sharing options...
stein Posted September 17, 2008 Author Report Share Posted September 17, 2008 Ja sam ljudi takav nered napravio da joÅ¡ uvek skupljam delove po sobi. Muzika sviri, tranzistori (izlazni) krÄkaju se na stabilnih 51C, hladnjak drži konstantno stabilnih 48C na gornjoj povrÅ¡ini, trafo tek-tek mlak, a onako audiofilsko sluÅ¡anje sad i da hoću ne mogu da izvedem. Sutra idem na kontrolu kod lekara pa moram da sve stvarno spremim jer ako me oteraju da od prekosutra idem da radim onda... Link to comment Share on other sites More sharing options...
Borko_KA Posted September 17, 2008 Report Share Posted September 17, 2008 Koliko kila hladnjka dajes da ne posaljem shefu link sa foruma? Link to comment Share on other sites More sharing options...
stein Posted September 17, 2008 Author Report Share Posted September 17, 2008 Koliko kila hladnjka dajes da ne posaljem shefu link sa foruma? Link to comment Share on other sites More sharing options...
sp300b Posted September 17, 2008 Report Share Posted September 17, 2008 Sta si povezao na F5 i kako ? Koji CD player i koji pot na ulazu. edit: ...u stvari vidim http://www.diyaudio.com/forums/showthread.php?postid=1612269#post1612269' rel="external nofollow"> Link to comment Share on other sites More sharing options...
