Opel Posted February 11, 2008 Report Share Posted February 11, 2008 Pozdrav svima! Imam problem sa AR-5 zvucnicima pa bih vas molio za pomoc oko toga. Problemi su: 1. nemam visokotonce pa bih hteo da nadjem iste ili odgovarajucu zamenu 2.popravku jednog srednjetonca (malo jedan krcka pri odredjenim frekvencijama) 3.zamenu kondezatora u skretnici Zaboravio sam da kazem dase radi o AR-5 zvucnicima iz serije u kojoj je bio i AR-3a/improved sa kojim deli visokotonce i srednjetonce a razlika je u basu jer je kod 5-ce 10 inca a kod 3-ke 12 inca, drugacijoj skretnici (ar-5,cross over: 650 Hz,5000 Hz; ar-3, 575 Hz, 5000 Hz ) kao i drugacijoj impedansi AR-5 8 oma a AR-3 4 oma. Link to comment Share on other sites More sharing options...
ozzy Posted February 11, 2008 Report Share Posted February 11, 2008 Pouzdano i valjano http://www.sinevoice.com/ Link to comment Share on other sites More sharing options...
anubisgrau Posted February 12, 2008 Report Share Posted February 12, 2008 Jos pouzdanije, Nenad Napijalo. Link to comment Share on other sites More sharing options...
koks Posted February 12, 2008 Report Share Posted February 12, 2008 Jos pouzdanije, Nenad Napijalo. Link to comment Share on other sites More sharing options...
stex Posted February 12, 2008 Report Share Posted February 12, 2008 Ako ti je Paraćin bliži, imaÅ¡ odliÄnog majstora. Link to comment Share on other sites More sharing options...
machinori Posted February 12, 2008 Report Share Posted February 12, 2008 Ako ti je Paraćin bliži, imaÅ¡ odliÄnog majstora. Link to comment Share on other sites More sharing options...
Opel Posted February 12, 2008 Author Report Share Posted February 12, 2008 Hvala na brzim odgovorima! Samo bez svadje bar ovog puta koji je bolji itd .... Link to comment Share on other sites More sharing options...
shavija Posted February 12, 2008 Report Share Posted February 12, 2008 Zasto, ako smem da znam? Link to comment Share on other sites More sharing options...
koks Posted February 12, 2008 Report Share Posted February 12, 2008 Samo pali vatru ... da naravno kod Sinise, Nesa je isao u srednju skolu kad je taj zvucnik izasao. Naravno obojica su fenomenalni na svoj nacin ali SInisa je bolji za vintage svakako. Poz Link to comment Share on other sites More sharing options...
sax.hifi Posted April 9, 2008 Report Share Posted April 9, 2008 Pozdrav svima! Imam problem sa AR-5 zvucnicima pa bih vas molio za pomoc oko toga. Problemi su: 1. nemam visokotonce pa bih hteo da nadjem iste ili odgovarajucu zamenu 2.popravku jednog srednjetonca (malo jedan krcka pri odredjenim frekvencijama) 3.zamenu kondezatora u skretnici Zaboravio sam da kazem dase radi o AR-5 zvucnicima iz serije u kojoj je bio i AR-3a/improved sa kojim deli visokotonce i srednjetonce a razlika je u basu jer je kod 5-ce 10 inca a kod 3-ke 12 inca, drugacijoj skretnici (ar-5,cross over: 650 Hz,5000 Hz; ar-3, 575 Hz, 5000 Hz ) kao i drugacijoj impedansi AR-5 8 oma a AR-3 4 oma. Link to comment Share on other sites More sharing options...
