ninja Posted February 9, 2008 Report Share Posted February 9, 2008 Posle "par" sati vozikanja na putu izmedju Göteborga i Osla i nazad, vratio sam se kuci. Pun pun kamera i naplatnih kucica na Norveskoj strani. Advantage/Bladelius Thor je prodat jos pre 2 sedmice i u kuci je tisina ... ali nece vise . Ledja me bole od unosenja u kuci bez ikakve pomoci ali valjd ace biti vrijedno! Je li neko moze da pogodi sta je "doletilo" paja959 nema pravo glasa! Link to comment Share on other sites More sharing options...
Iron man Posted February 9, 2008 Report Share Posted February 9, 2008 Da nije B&O? Link to comment Share on other sites More sharing options...
ninja Posted February 9, 2008 Author Report Share Posted February 9, 2008 Da nije B&O? Link to comment Share on other sites More sharing options...
BokiTokiVoki Posted February 9, 2008 Report Share Posted February 9, 2008 Ako te ledja bolje, onda sigurno nisu switching ciglice. A ovoga ostalog ima baš mnogo: Plinius, Classe, Bryston,Karan,......Nije valjda EC? Kome to treba u životu? Ajd' daj neki hint ili asocijaciju. Ko će to da gadja? Link to comment Share on other sites More sharing options...
ninja Posted February 9, 2008 Author Report Share Posted February 9, 2008 Ako te ledja bolje, onda sigurno nisu switching ciglice. A ovoga ostalog ima baš mnogo: Plinius, Classe, Bryston,Karan,......Nije valjda EC? Kome to treba u životu? Ajd' daj neki hint ili asocijaciju. Ko će to da gadja? Link to comment Share on other sites More sharing options...
beatgoeson Posted February 9, 2008 Report Share Posted February 9, 2008 Hoće biti nešto o tome u Svenska Dagbladetu? Link to comment Share on other sites More sharing options...
catalyst Posted February 9, 2008 Report Share Posted February 9, 2008 Pojacalo je 48 kg van kutije a pred pojacalo je lakse. Oba su dual-mono, a pojacalo cak sa dva strujna kabla i 2 on/Off dugmeta! Link to comment Share on other sites More sharing options...
ninja Posted February 9, 2008 Author Report Share Posted February 9, 2008 @beatgoeson, pre ce izaci u Politikinom Zabavniku @Gorane, nece. Nema vise "poboljsanja" ... u svakom slucaju ne za jedan mnogo duzi period. Malo informacije o pred-pojacalu: The X's elegant design follows the . . . purist approach of using zero negative feedback to achieve the desired goals of wide bandwidth and circuit linearity. No buffers, followers or op amps are used anywhere in the signal path. The X features a symmetrical N-channel Unistage® gain block that is biased at an extraordinary 250mA to provide the high-current operation that has become a hallmark of . . . design. Dual-mono construction is combined with over 130,000µF of power supply capacitance to yield instantaneous response to the most demanding signal requirements. All of this capability is presented in a sleek new industrial design that complements the balanced execution within. Link to comment Share on other sites More sharing options...
ninja Posted February 9, 2008 Author Report Share Posted February 9, 2008 Malo o pojacalu: The XX is constructed as two individual amplifiers on one frame to capture many of the benefits of monoblock construction while maintaining the convenience of a single chassis. This dual-mono construction extends to separate power cords, power switches, transformers, and circuit modules. The XX could be cut down the middle with an acetylene torch and both halves would still play. Link to comment Share on other sites More sharing options...
anubisgrau Posted February 9, 2008 Report Share Posted February 9, 2008 BAT? Link to comment Share on other sites More sharing options...
BokiTokiVoki Posted February 9, 2008 Report Share Posted February 9, 2008 Nadjoh. PretpojaÄalo BAT VK-40 Power Amplifier BAT VK-600 Link to comment Share on other sites More sharing options...
anubisgrau Posted February 9, 2008 Report Share Posted February 9, 2008 Dzaba ti, prvi sam pogodio. Koje zvucnike planiras za ovo veselje? Link to comment Share on other sites More sharing options...
BokiTokiVoki Posted February 9, 2008 Report Share Posted February 9, 2008 Kucao sam dok si postovao. Nisam ni video. U svakom sluÄaju, dobit ćeÅ¡ nagradu - lizalicu. Link to comment Share on other sites More sharing options...
lemond Posted February 9, 2008 Report Share Posted February 9, 2008 Ja se ponadao da cu da vidim nekog Link to comment Share on other sites More sharing options...
ninja Posted February 9, 2008 Author Report Share Posted February 9, 2008 BAT? Link to comment Share on other sites More sharing options...
ninja Posted February 9, 2008 Author Report Share Posted February 9, 2008 Nadjoh. PretpojaÄalo BAT VK-40 Power Amplifier BAT VK-600 Link to comment Share on other sites More sharing options...
ninja Posted February 9, 2008 Author Report Share Posted February 9, 2008 Dzaba ti, prvi sam pogodio. Koje zvucnike planiras za ovo veselje? Link to comment Share on other sites More sharing options...
BokiTokiVoki Posted February 9, 2008 Report Share Posted February 9, 2008 Prvi je dobar ali drugi ne VK-500 sa BatPakom jo pojacalce koje jedva sam izvadi iz kutija! Link to comment Share on other sites More sharing options...
ninja Posted February 9, 2008 Author Report Share Posted February 9, 2008 ]BAT VK-40: BAT VK-500 + Bat Pak: Link to comment Share on other sites More sharing options...
BokiTokiVoki Posted February 9, 2008 Report Share Posted February 9, 2008 OdliÄan izbor. Bar po slici. Ja se ne bih bunio. Mljac! Si imao prilike pre da probaÅ¡ to kod kuće? Sada se nećeÅ¡ provući ni pod razno za neki textić sa utiscima. Respons + BAT. Imam utisak da te joÅ¡ kopka izvor. Am I right? Link to comment Share on other sites More sharing options...
ninja Posted February 9, 2008 Author Report Share Posted February 9, 2008 edit: Ispravljam se, vidim da VK-500 košta dosta manje od VK-600. I nije toliko. Uživaj! Link to comment Share on other sites More sharing options...
ninja Posted February 9, 2008 Author Report Share Posted February 9, 2008 OdliÄan izbor. Bar po slici. Ja se ne bih bunio. Mljac! Si imao prilike pre da probaÅ¡ to kod kuće? Sada se nećeÅ¡ provući ni pod razno za neki textić sa utiscima. Respons + BAT. Imam utisak da te joÅ¡ kopka izvor. Am I right? Link to comment Share on other sites More sharing options...
BokiTokiVoki Posted February 9, 2008 Report Share Posted February 9, 2008 Ja sam davno prestao da kupujem novo! U svakom slucaju, tip je neki skoro "bolesno pedantan" tehnicki podkovan. Imao ih je 2.5 godine i onda ih je pri renoviranju kuce spakovao u kutije i temperaturno regulisanu sobu na skoro tri godine. Sada su pregledani i prodati .... meni Niti jedne ogrebotine ni znaka da su koristeni! A od zvucnika ima ... Respons Link to comment Share on other sites More sharing options...
BokiTokiVoki Posted February 9, 2008 Report Share Posted February 9, 2008 Ovo za izvor bas ne kontam! Link to comment Share on other sites More sharing options...
ninja Posted February 9, 2008 Author Report Share Posted February 9, 2008 Izvor : CD player, gramofon, Etc. Link to comment Share on other sites More sharing options...
