okibokis Posted April 27, 2012 Report Share Posted April 27, 2012 http://www.youtube.com/watch?v=ISTsDD_yYgs Quote Link to comment Share on other sites More sharing options...
okibokis Posted April 27, 2012 Report Share Posted April 27, 2012 Quote Link to comment Share on other sites More sharing options...
okibokis Posted April 27, 2012 Report Share Posted April 27, 2012 Ovo bi trebalo uvesti za nase prodavacice kao prijemni,a ne onako da klackaju kao penzioneri Quote Link to comment Share on other sites More sharing options...
okibokis Posted April 27, 2012 Report Share Posted April 27, 2012 Danas me nesto krenulo ,ali pogledajte samo !!! Quote Link to comment Share on other sites More sharing options...
okibokis Posted April 27, 2012 Report Share Posted April 27, 2012 I posle nasi konobari traze baksis!Zasta bre:)) Quote Link to comment Share on other sites More sharing options...
Vlajo Posted May 1, 2012 Report Share Posted May 1, 2012 WTF ? Reversing ? On 23 Hz ? Quote Link to comment Share on other sites More sharing options...
Alister Posted May 1, 2012 Report Share Posted May 1, 2012 WTF ? Reversing ? On 23 Hz ? " This is really simple but has such an awesome effect. Fill a bucket full of water and place it about 5 feet off the ground. Place a subwoofer about 1 foot lower than the bucket. Run a plastic tube from the top bucket down in front of the subwoofer. Tape the tube to the front of the speaker. Then aim the end of the tube to an empty bucket on the floor. Get the water flowing from the top bucket. Now just generate a 24 hz sine wave and set your camera to 24 fps and watch the magic happen. Basically your cameras frame rate is synced up with the rate of the vibrations of the water so it appears to be frozen or still. Now if you play a 23 hz sine wave your frame rate will be off just a little compared to the sine wave causing the water to "move backward" or so as it appears. You can play a 25 hz sine wave and cause the water to move slowly foward. " Quote Link to comment Share on other sites More sharing options...
Vlajo Posted May 1, 2012 Report Share Posted May 1, 2012 " This is really simple but has such an awesome effect. Fill a bucket full of water and place it about 5 feet off the ground. Place a subwoofer about 1 foot lower than the bucket. Run a plastic tube from the top bucket down in front of the subwoofer. Tape the tube to the front of the speaker. Then aim the end of the tube to an empty bucket on the floor. Get the water flowing from the top bucket. Now just generate a 24 hz sine wave and set your camera to 24 fps and watch the magic happen. Basically your cameras frame rate is synced up with the rate of the vibrations of the water so it appears to be frozen or still. Now if you play a 23 hz sine wave your frame rate will be off just a little compared to the sine wave causing the water to "move backward" or so as it appears. You can play a 25 hz sine wave and cause the water to move slowly foward. " Sad je malo jasnije ... Hvala ... Quote Link to comment Share on other sites More sharing options...
boskogit Posted May 2, 2012 Report Share Posted May 2, 2012 Quote Link to comment Share on other sites More sharing options...
sondek Posted May 2, 2012 Report Share Posted May 2, 2012 Jbt krenuli u pozoriste,bice skoro kraj sveta.Jos malo ce i na jazz koncerte,zasad samo uzmu karte ali nikad ne dodju,pa im sednem na mesto kad upale mrak. Quote Link to comment Share on other sites More sharing options...
Chowek Posted May 3, 2012 Report Share Posted May 3, 2012 Jbt krenuli u pozoriste,bice skoro kraj sveta.Jos malo ce i na jazz koncerte,zasad samo uzmu karte ali nikad ne dodju,pa im sednem na mesto kad upale mrak. Ako ne ubedljivo najbolji, onda svakako jedan od najboljih marketinÅ¡kih nastupa u poslednjih par godina imala je Beogradska filharmonija. Ni ove godine nisu razoÄarali: Beogradska filharmonija ulazi u politiÄki život Srbije Quote Link to comment Share on other sites More sharing options...
nikstev2000 Posted May 4, 2012 Report Share Posted May 4, 2012 Ako ne ubedljivo najbolji, onda svakako jedan od najboljih marketinÅ¡kih nastupa u poslednjih par godina imala je Beogradska filharmonija. Ni ove godine nisu razoÄarali: Beogradska filharmonija ulazi u politiÄki život Srbije Ne bih se baÅ¡ složio sa tim "najbolji"...I sam si postovao linkove od kojih je gosn.Tasovac pozajmljivao (da budem fin)... http://www.hi-files.com/forum/index.php?/topic/5774-youtube-highlights/page__st__1260#entry416359 Ovo Å¡to on radi je marketing,po mom miÅ¡ljenju nesuvisli i kvazielitistiÄki,kao i, na kraju krajeva nastup u Strahinjića Bana.Ja volim espresso u jednom kafiću u toj ulici,a eto sticajem okolnosti nasluÅ¡an sam muzike viÅ¡e od većine poÅ¡tovaoca lika i dela gorepomenutog.Treba napraviti razliku izmeÄ‘u marketinga,dobrog ukusa i samoreklamerstva.Filharmoniji ovakav "nastup" ne treba...Ako je poenta bila poniziti posetioce kafiće u S.Bana,razumem;ako je bila poenta pokazati nekulturu svih politiÄkih struktura i to razumem.Ali onda treba lepo reći vi ste seljaci,vi drugi sirovine, a mi smo elita...... Za to vreme gosn. Tasovac vedri i oblaÄi u nekoj emisiji sa nekim likom koji sebe naziva milime..,ne,kilogra...,ne...Äudno nekako...Ćelavi neki...Nekako mi to ne ide jedno sa drugim..Možda će me neki marketinÅ¡ki struÄnjak demantovati,ali mislim da ovde postoji reklama radi reklame i (kvazi)kontraverza radi kontraverze.I kao treći Äin svega toga pojavljuju se mugshotovi muziÄara u GSP-u...Tretirani su kao kriminalci,ili je kriminal pod kojim uslovima rade?Hmm...Makes you think ...Da ne teram dalje u ironiju i sarkazam meni se ovaj naÄin eksponiranja ne dopada,a zaista bih voleo da se neko struÄan u oblasti marketinga javi i da svoje miÅ¡ljenje o tome. Ideja,ciljna grupa,efekat i Å¡ta već spada u uslov za dobru reklamu i njen uspeÅ¡an plasman... Quote Link to comment Share on other sites More sharing options...
sondek Posted May 4, 2012 Report Share Posted May 4, 2012 glasam za 365 dana godisnje predizborne cutnje,ali svake godine i prvog koji mi uz to pokloni plocu dnevno. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted May 4, 2012 Report Share Posted May 4, 2012 Materijalisto ! (Ja 'oću cd ...) Quote Link to comment Share on other sites More sharing options...
pantaNS Posted May 6, 2012 Report Share Posted May 6, 2012 http://www.youtube.com/watch?v=na0uQsXeijo&feature=player_embedded#! Quote Link to comment Share on other sites More sharing options...
okibokis Posted May 7, 2012 Report Share Posted May 7, 2012 Kom pravcu pripada ovaj naÄin svirke,hteo bih da nadjem neÅ¡to sliÄno na netu? Quote Link to comment Share on other sites More sharing options...
Floyd Posted May 7, 2012 Report Share Posted May 7, 2012 Kom pravcu pripada ovaj naÄin svirke,hteo bih da nadjem neÅ¡to sliÄno na netu? Nenormalnom možda. Quote Link to comment Share on other sites More sharing options...
okibokis Posted May 7, 2012 Report Share Posted May 7, 2012 Nenormalnom možda. Zašto nenormalnom? Quote Link to comment Share on other sites More sharing options...
machinori Posted May 8, 2012 Author Report Share Posted May 8, 2012 Pocetnik... Quote Link to comment Share on other sites More sharing options...
Chowek Posted May 13, 2012 Report Share Posted May 13, 2012 Quote Link to comment Share on other sites More sharing options...
Timmy Posted May 13, 2012 Report Share Posted May 13, 2012 Diskutabilan IQ Quote Link to comment Share on other sites More sharing options...
box Posted May 13, 2012 Report Share Posted May 13, 2012 Xtra Quote Link to comment Share on other sites More sharing options...
boskogit Posted May 15, 2012 Report Share Posted May 15, 2012 http://www.youtube.com/watch?feature=player_embedded&v=rcddITj7-t4#! Quote Link to comment Share on other sites More sharing options...
perodeformero Posted May 15, 2012 Report Share Posted May 15, 2012 Quote Link to comment Share on other sites More sharing options...
box Posted May 15, 2012 Report Share Posted May 15, 2012 jel ono Buja svira `armoniku? Quote Link to comment Share on other sites More sharing options...
