machinori Posted October 16, 2007 Report Share Posted October 16, 2007 Lemljenje srebrom je malo bolje ali i dalje loÅ¡ije od dobrog mehaniÄkog kontakta. Raspitaj se malo, proÄitaj, informiÅ¡i se, pa onda priÄaj. Ovako priÄaÅ¡ napamet. Link to comment Share on other sites More sharing options...
machinori Posted October 16, 2007 Report Share Posted October 16, 2007 Mil-spec je overrated. Link to comment Share on other sites More sharing options...
zflazar Posted October 16, 2007 Report Share Posted October 16, 2007 Ccccc..... Jel neko probao zavarivanje? Link to comment Share on other sites More sharing options...
Zen Mod Posted October 16, 2007 Report Share Posted October 16, 2007 Mil-spec je overrated. Link to comment Share on other sites More sharing options...
zflazar Posted October 16, 2007 Report Share Posted October 16, 2007 Ma i kad je 52-položajni, ni onda nije neÅ¡to... ima viÅ¡ak pozicija... P.S. Bekunis nije krema, nego Äaj... Link to comment Share on other sites More sharing options...
Zen Mod Posted October 16, 2007 Report Share Posted October 16, 2007 Ma i kad je 52-položajni, ni onda nije neÅ¡to... ima viÅ¡ak pozicija... P.S. Bekunis nije krema, nego Äaj... Link to comment Share on other sites More sharing options...
machinori Posted October 16, 2007 Report Share Posted October 16, 2007 pa i jeste- ako gledas sa aspekta Bekunis kreme ; ako gledas sa aspekta vojnicke cizme onda i nije ............ sve sto je mil-spec , uglavnom je izvanrednog kvaliteta ; druga je stvar da li tebi treba elemenat upravo tih kvaliteta koje nalazis u vojnim uredjajima ....... mi bi svi bili srecni da nadjemo mil-spec 32-polozajni quadro preklopnik,pa da pravimo atenuatore ; e - kad nadjemo samo 12-polozajni i to samo dve sekcije,onda kazemo ...... ma i nije mil-spec nesto....... Link to comment Share on other sites More sharing options...
anubisgrau Posted October 16, 2007 Report Share Posted October 16, 2007 siemens mil-spec iz miletovog drvenka je keva. Link to comment Share on other sites More sharing options...
stein Posted October 17, 2007 Report Share Posted October 17, 2007 SuÅ¡tina mil-spec nije ono Å¡to mnogi misle - performansa već trajnost i pouzdanost. Onomad se napravila usporedba izmeÄ‘u klasiÄnih DOT2 ulja za koÄenje i vojnih, silikonskih. Poenta vojne varijante je da silikonsko ulje nikada ne nagriza gumice ili neki deo sistema. Parkiraj pod tri metra peska pedeset kamiona i tenkova spremnih da izvrÅ¡e "udar" na nekog pustinjskog diktatora i pedeset godina kasnije, isti ti kamioni i tenkovi, kada se iskopaju, pale lako, koÄe bez diskusije. Da, koÄe, ali sa brzine od 50kmh je zaustavni trag 100m, isto takvo vozilo, sa istim DOT2 ili DOT3 bi davno u tih 50godina izgubilo koÄnice ali ako spremiÅ¡ kamion sa DOT hidrauliÄnim uljem zaustavni put se skraćuje drastiÄno. Problem je da nakon dve ili tri godine neupotrebe imaÅ¡ kamion bez sistema za koÄenje, menjaj sve gumice, verovatno i cilindre i ulje... To je Äesto luksuz koji vojska nema. OÄuvanje proizvodnje elektronki u tadaÅ¡njem SSSR-u nije bila audiofilska odluka već military stvar: EMS kida iznutrice poluprovodnicima, sovjetske radio stanice rade i posle atomskog udara. ... ako ima ko da ih koristi, ona druga strana je obrala bostan. zelen i kiseo... Sorry za off... Trafo radi posle EMS a chopper napajanje jok. Cevni ispravljaÄ radi, poluprovodniÄki... Mada, s druge strane gledano, mislim da su crknuti hifi ureÄ‘aji nakon Å¡to nam EMS talas protrÄi po kućama predstavlja najmanji problem, ne? Link to comment Share on other sites More sharing options...
viccpa Posted October 17, 2007 Report Share Posted October 17, 2007 ali ne morate da se brinete. ko prezivi udar detektovace zracenje Germanijumskim detektorima. p.s. naravno, ocuvanim u olovnim kutijama sa zidovima debljine 55 cm Link to comment Share on other sites More sharing options...
zflazar Posted October 17, 2007 Report Share Posted October 17, 2007 "Prvo Hifi, zatim žene i deca uskloniÅ¡te..." Nadalje, u sluÄaju nuklearnog udara, ko preživi, može kvalitetno sluÅ¡ati muziku samo sa Altmann-ovih BYOB ureÄ‘aja, poÅ¡to se oni napajaju na 'kumulator. Zna se, napon sa generatora je "prljav" i neaudiofilski. Link to comment Share on other sites More sharing options...
viccpa Posted October 17, 2007 Report Share Posted October 17, 2007 nemoj tako, prezivece i pasivni preampi, prava stvar za neke nove generacije ko zna kakvih oblika zivota! Link to comment Share on other sites More sharing options...
machinori Posted October 17, 2007 Report Share Posted October 17, 2007 SuÅ¡tina mil-spec nije ono Å¡to mnogi misle - performansa već trajnost i pouzdanost. Onomad se napravila usporedba izmeÄ‘u klasiÄnih DOT2 ulja za koÄenje i vojnih, silikonskih. Poenta vojne varijante je da silikonsko ulje nikada ne nagriza gumice ili neki deo sistema. Parkiraj pod tri metra peska pedeset kamiona i tenkova spremnih da izvrÅ¡e "udar" na nekog pustinjskog diktatora i pedeset godina kasnije, isti ti kamioni i tenkovi, kada se iskopaju, pale lako, koÄe bez diskusije. Da, koÄe, ali sa brzine od 50kmh je zaustavni trag 100m, isto takvo vozilo, sa istim DOT2 ili DOT3 bi davno u tih 50godina izgubilo koÄnice ali ako spremiÅ¡ kamion sa DOT hidrauliÄnim uljem zaustavni put se skraćuje drastiÄno. Problem je da nakon dve ili tri godine neupotrebe imaÅ¡ kamion bez sistema za koÄenje, menjaj sve gumice, verovatno i cilindre i ulje... To je Äesto luksuz koji vojska nema. OÄuvanje proizvodnje elektronki u tadaÅ¡njem SSSR-u nije bila audiofilska odluka već military stvar: EMS kida iznutrice poluprovodnicima, sovjetske radio stanice rade i posle atomskog udara. ... ako ima ko da ih koristi, ona druga strana je obrala bostan. zelen i kiseo... Sorry za off... Trafo radi posle EMS a chopper napajanje jok. Cevni ispravljaÄ radi, poluprovodniÄki... Mada, s druge strane gledano, mislim da su crknuti hifi ureÄ‘aji nakon Å¡to nam EMS talas protrÄi po kućama predstavlja najmanji problem, ne? Link to comment Share on other sites More sharing options...
zflazar Posted October 17, 2007 Report Share Posted October 17, 2007 Mala digresija: u sluÄaju EMS-a ode i Altmann... Dakle, ostaje gramofon, pasivni preamp, lampaÅ¡ki RIA i lampaÅ¡ki AMP... Kakva budućnost hifia: Äist povratak u proÅ¡lost... Link to comment Share on other sites More sharing options...
viccpa Posted October 17, 2007 Report Share Posted October 17, 2007 ostaje nam samo da se nadamo da je EMS proslost... btw, prvi koji ce detektovati EMS su vlasnici germanijumskih uredjaja, tako da teoretski imaju vece sanse da se sakriju u olovni kovceg Link to comment Share on other sites More sharing options...
anubisgrau Posted October 17, 2007 Report Share Posted October 17, 2007 ATOMSKI SLEVA! Link to comment Share on other sites More sharing options...
Quattor Posted October 17, 2007 Report Share Posted October 17, 2007 Eh, mene od svih EMS-ova najviše brine PMS! Link to comment Share on other sites More sharing options...
stein Posted October 17, 2007 Report Share Posted October 17, 2007 Eh, mene od svih EMS-ova najviše brine PMS! Link to comment Share on other sites More sharing options...
Archived
