29 minutes ago, anubisgrau said:
ko prodaje taj matrix?
Registuješ se kod njih na sajtu i poručiš direktno.Najboplj opcija kod nekog drugara u EU pa ti on donese,izbegneš dodatni harač.
22 sati ranije, 空也 said:
Šta fali NUC-u koji već imaš za Roon core?
Roon Nucleus je NUC prepakovan u fensi kućište.
Koji NUC, koji Nucleus? Nije sve isto. Nativni DSD i visekanalni DSP zahteva sposoban procesor koji potire generalizovanu tvrdnju NUC = Roon Nucleus.
Naravno da nije sve isto.
Poenta je da je, hardverski, Roon Nucleus = NUC.
Kolega nije naveo koji tačno model NUC-a ima, tako da je pitanje u mom postu bilo: "Šta fali NUC-u koji već imaš za Roon core?"
Tokom godina se širila ponuda, menjali su modeli Nucleus-a, a samim time i modeli NUC-ova koji su u njih spakovani.
Sad, koji je tačno model NUC-a u kom Nucleusu... i to se može istražiti.
Trenuntni modeli Nucleusa su One i Titan.
Google AI pretraga kaže:
The Roon Nucleus One contains an Intel Celeron N5105 processor.
Roon Labs has traditionally used Intel's Next Unit of Computing (NUC) platform as the foundation for its servers, the Nucleus One is a cost-effective, "turn-key" appliance designed for libraries of up to 100,000 tracks.
Key Internal Specifications:
  • Processor: Quad-core Intel Celeron N5105.
  • Memory: 4GB RAM (DDR4), though some users have successfully upgraded this to 16GB.
  • Storage: A small internal M.2 SSD for the Roon OS and database, with an additional 2.5” SATA tray for internal library storage up to 8TB.
  • Cooling: Unlike the fanless original Nucleus, the One uses a quiet internal fan for thermal management.
For more demanding tasks like DSD upsampling or managing significantly larger libraries, Roon typically recommends the higher-tier Nucleus Titan or a DIY Intel NUC running Roon Optimized Core Kit (ROCK).
The Roon Nucleus Titan is built around an ASUS NUC 13 Pro mainboard.
Specifically, the device uses the following internal hardware configuration:
  • Processor: An Intel Core i3-1315U (13th Generation "Raptor Lake") processor. This represents a shift for Roon's flagship; while previous high-end models like the Nucleus+ used Core i7 chips, the Titan's 13th-gen i3 provides a 36% performance boost and improved power efficiency over those older i7 units.
  • Memory: 8GB of RAM (typically 2 x 4GB SDRAM), which offers 80% more bandwidth than previous generations.
  • Storage: A 256GB NVMe SSD is pre-installed for the Roon OS (operating system) and library database.
  • Expansion: It includes an internal bay for a 2.5-inch SATA SSD (up to 8TB) for local music storage.
Unlike standard NUC kits, the Nucleus Titan is housed in a bespoke, fanless chassis designed for passive cooling and silent operation in high-end audio environments.
Trenutna NUC preporuka od strane Roon labs:
...Kod klinca u sobi i dalje svira moj prastari Squeezbox Touch.
Iz radoznalosti sam ga preko USB-a zakačio na Matrix Audio X-SPDIF 2 DDC i ta kombinacija sa Naim nDAC-om radi savršeno, zvuk je više nego odličan!
PS
Na Touch-u je instaliran EDO plugin koji omogućava USB vezu sa DAC-om.
Ne salju u drzave gde imaju distributera. Provereno.
Cak i da salju, nema sanse da bude povoljnije. Pricam iz prve ruke. Koga zanima, moze da proba.
Da se vratimo na temu. Prvoklasna sprava. 💯
30 minuta ranije, Delija said:
anubisgrau said:
što vas više čitam sve više se pitam šta hvali wiim mini?
To je kao da si pitao sta fali USB gramofonu.
Вечита дилема неписмених.... хвали или фали.... Делија је лепо написао.
Jel ima neko da je probao ove Ian Canada RPI based zaebancije?
Flagship compact size FIFO Re-clock Streamer/DDC KITs with Ultracapaci – IanCanada
Imam allo digione signature sa Volumio i to vrhunski radi, ali cu u nekom momentu verovatno sastaviti neki Ianov kombo sa I2S izlazom i jacim master klokom. Ima gomila kombinacija i varijanti i moze se lepo skutijati u neko audiophonics ili modushop kuciste.
Dobije se ozbiljan zvuk za ne tako mnogo para.
