lucas Posted September 5, 2007 Report Share Posted September 5, 2007 moze neki info? Link to comment Share on other sites More sharing options...
Zen Mod Posted September 5, 2007 Report Share Posted September 5, 2007 moze neki info? s obzirom odakle si ulinkovao sliku- treba ti jos neki info? sve sto su ti tamo napisali vredi ........... novi (heavy) plint,kompletan servis , po mogucstvu druga rucka i uzivaj........ Thorens eater Link to comment Share on other sites More sharing options...
first Posted September 5, 2007 Report Share Posted September 5, 2007 moze neki info? Link to comment Share on other sites More sharing options...
Zen Mod Posted September 5, 2007 Report Share Posted September 5, 2007 zaboravih ovo: http://www.lenco-lovers.com/ Link to comment Share on other sites More sharing options...
lucas Posted September 5, 2007 Author Report Share Posted September 5, 2007 Link to comment Share on other sites More sharing options...
paja959 Posted September 5, 2007 Report Share Posted September 5, 2007 Pocetkom/krajem '70 je to vazio "za gramafon" tanjir od 4kg,balansirani,izuzetno veliki,jak motor sa mogucnoscu permanentnog podesavanja brzine od 33-78rpm,rucka teska,gumice koje sluze za "vesanje" rucice vrlo lako se suse,rucka propada ili tone na tomgumenom vesanju.Ima relativno visoki "rumble" zbog prenosnog mehanizma koji koristi.menjao to negde pocetkom '80 za Thorens 160 i odjednom se otvorio jedan novi svet za mene na dobro poznatim LP-ima. Vrlo pouzdana masina,cesto su ih u ono vreme koristili po diskotekama. Postoji neki "revival" u zadnje vreme bas za ovaj Lenco model( i Lenco L78),odstranjuje se rucka,radi se novo kuciste(ide se maltene do perverziteta,video neke tako preradjene modele )stavlja se ili SME 3009/2 ili Rega RB250/300,tako preradjene ih koriste ili za reprodukciju ploca na 78rpm,ili mono snimaka s tim da je to obicno onda "drugi gramafon" u sistemu... Link to comment Share on other sites More sharing options...
PrekoBare Posted September 5, 2007 Report Share Posted September 5, 2007 moze neki info? Link to comment Share on other sites More sharing options...
lucas Posted September 5, 2007 Author Report Share Posted September 5, 2007 taj lenco kao i revox pojacalo, tanderberg dek, i peerless diy zucnike sam dobio od ujaka, pa me zanima sta sam to u stvari dobio pricas o sinergiji, predpostavljam da ovi uredjaji fino idu jedan sa drugim? (ako nista drugo po dizajnu se stvarno slazu - svi su neverovatno lepi ) Link to comment Share on other sites More sharing options...
lucas Posted September 5, 2007 Author Report Share Posted September 5, 2007 i da josh nesto. upravo sam pokusao da pustim neku plocu na ovom lencu i desila se sledeca stvar. prvo kad sam ga upalio kao da se motor malo nakasljao. znaci nije odmah poceo da vrti plocu nego se ceo gramofon zatresao i polako krenuo da vrti plocu. ovo se desilo samo prvi put kad sam ga upalio. e sad pb je sto kad ga prikljucim na pojacalo nema nikakvog signala. znaci bas nista se ne cuje... da nije nesto sa iglicom? inace gramofon je stajao dosta dugo neupotrebljen Link to comment Share on other sites More sharing options...
Zen Mod Posted September 5, 2007 Report Share Posted September 5, 2007 imam dva komada L75 i jedan L78 fama koja se podigla na netu je apsolutno opravdana , bar s moje tacke gledista ; u originalnim plintovima su malo bolji od Toske 15 ,ali kad mu das dobar plint i kulturnu rucku........... trci u krugovima oko torensa btw - imao sam i par torensa...... Link to comment Share on other sites More sharing options...
paja959 Posted September 6, 2007 Report Share Posted September 6, 2007 i da josh nesto. upravo sam pokusao da pustim neku plocu na ovom lencu i desila se sledeca stvar. prvo kad sam ga upalio kao da se motor malo nakasljao. znaci nije odmah poceo da vrti plocu nego se ceo gramofon zatresao i polako krenuo da vrti plocu. ovo se desilo samo prvi put kad sam ga upalio. e sad pb je sto kad ga prikljucim na pojacalo nema nikakvog signala. znaci bas nista se ne cuje... da nije nesto sa iglicom? inace gramofon je stajao dosta dugo neupotrebljen Link to comment Share on other sites More sharing options...
Willi Studer Posted September 6, 2007 Report Share Posted September 6, 2007 taj lenco kao i revox pojacalo, tanderberg dek, i peerless diy zucnike sam dobio od ujaka, pa me zanima sta sam to u stvari dobio pricas o sinergiji, predpostavljam da ovi uredjaji fino idu jedan sa drugim? (ako nista drugo po dizajnu se stvarno slazu - svi su neverovatno lepi ) Dobio si ujaka macana. Link to comment Share on other sites More sharing options...
ZoranBG Posted September 6, 2007 Report Share Posted September 6, 2007 Vintage rariteti, cak i ako su odlicni, se ne prodaju bas tako lako, jer mali broj ljudi zna sta je to i koliko vredi. Ako ne verujete meni, pitajte ZoranaBg Link to comment Share on other sites More sharing options...
Iron man Posted September 6, 2007 Report Share Posted September 6, 2007 Ja sam jedva prodao B&O receiver. Sad mi zao , bolje da mi je ostao za vikendicu makar. Link to comment Share on other sites More sharing options...
Dacho Posted September 17, 2007 Report Share Posted September 17, 2007 i da josh nesto. upravo sam pokusao da pustim neku plocu na ovom lencu i desila se sledeca stvar. prvo kad sam ga upalio kao da se motor malo nakasljao. znaci nije odmah poceo da vrti plocu nego se ceo gramofon zatresao i polako krenuo da vrti plocu. ovo se desilo samo prvi put kad sam ga upalio. e sad pb je sto kad ga prikljucim na pojacalo nema nikakvog signala. znaci bas nista se ne cuje... da nije nesto sa iglicom? inace gramofon je stajao dosta dugo neupotrebljen Link to comment Share on other sites More sharing options...
lucas Posted September 19, 2007 Author Report Share Posted September 19, 2007 evo juce sam ga ponovo prikljucio i svirao je?!? ne znam kako ali juce je svirao, doduse ne bas sjajno. zvuk je iskrivljen i mutan. na pojacalu imam switch za MM i MC, ali ne znam kojeg je tipa gramofon. Sta uopste znaci MM i MC? kabl koj ide od gramofona do pojacala definitivno nije dobar, njega cu morati da zamenim, jer krci kada se malo pomeri. ipak imam utisak da je do josh necega a ne samo do kabla? sta vi mislite? mozda motor ne mota ravnomerno? Link to comment Share on other sites More sharing options...
stein Posted September 19, 2007 Report Share Posted September 19, 2007 pojacalu imam switch za MM i MC, ali ne znam kojeg je tipa gramofon. Sta uopste znaci MM i MC? Link to comment Share on other sites More sharing options...
paja959 Posted September 19, 2007 Report Share Posted September 19, 2007 mozda motor ne mota ravnomerno Link to comment Share on other sites More sharing options...
Dacho Posted September 19, 2007 Report Share Posted September 19, 2007 I joÅ¡ neÅ¡to ljudi, svakako rastaviti tj skinuti tanjur i doći do ležaja, sve lijepo oÄistiti i staviti novo adekvatno ulje. To obiÄno zna biti problem kod boljih gramafona i uzrokuje jodlanje i zavijanje jer ležaj pruža nekakv otpor . Link to comment Share on other sites More sharing options...
lucas Posted September 20, 2007 Author Report Share Posted September 20, 2007 Ako je prva slika sa tvog gramafona(nije skinuta sa net-a) imas "stroboskop" u sredini tanjira/kod osovine:postavis neku lampu malo blize gramafonu,odaberes pravilan broj obrtaja i gledas "da li se crtice pomeraju napred nazad ili su konstantno u jednom mestu".Crtica treba da stoji bez pomeranja napred/nazad u jednom mestu!Sa ruckom kojom biras broj obrtaja pronadji ono mesto/poziciju,makar to ne bilo u lezistu za odredjeni broj obrtaja koji je fabricki "odredjen".Olabavis saraf kod "svakok lezista" i pomeris tako leziste da odgovara stvarnom broju okretaja sa stroboskopa.Zategnes sarafe.Nemoj da te ovo brine,ravnomerna konusna osovina motora omogucava tacno podesavanje potrebne brzine.Godinama,usled trenja taj pogonski tockic se smanjuje,pa treba dostelavati. Drugo proveri da li se tanjir okrece "slobodno",bez muljanja.Proveri da li "mehanicka kocnica" radi pravilno,tj da li je iskljucena kad je gramafon ukljucen.To ti je neko parce lima na ciji kraj je navuceno kao kratko plasticno crevo duzine mozda 0,5cm-1cm,ono se nekako mehanicki "dize" kad iskljucis gramafon i mehanickim trenjem usporava okretanje tanjira. Link to comment Share on other sites More sharing options...
paja959 Posted September 21, 2007 Report Share Posted September 21, 2007 Re lucas:ako sam ja dobro razumeo kako su mi telefonom objasnjavali:negde pri dnu osovine(verovatno je to kuciste osivine(?) se nalazi neki mali saraf M3,ovo treba malo odvrnuti,i dolazi se do "kuglice",ona treba da se izvadi,ocisti lepo od prljavstine,i leziste iste.Ovo posle ciscenja,kuglica/leziste treba da se podmaze mascu.Za ulje koriste 15W40,moze i sinteticko.Ako sve dobro "dihtuje"(znaci nije istrosena osovina) sve se lepo polako spusta(tanjir),sa sporim izduvavanjem vazduha iz osovine+kucista osovine Link to comment Share on other sites More sharing options...
Zen Mod Posted September 21, 2007 Report Share Posted September 21, 2007 skini tanjir sa konusa centralne osovine sa brute force koristi samo prste..... uhvati tanjir sa dve strane ( dijametralno) i vuci ako bas ne uspes tako- uzmi dve letvice i radi to isto-na polugu.... posle toga odvrnes M3 sraf koji osigurava osovinicu,izvuci istu,izvadi kuglicu(okranuvsi gm naopako) peri cauru i osovinu benzinom za ciscenje ,sipaj 20W40 i uzivaj ako si dovoljno spreman- rastavi i motor,operi osovinu i lezajeve i podmazi istim uljem manuali su dostupni na netu Link to comment Share on other sites More sharing options...
lucas Posted September 21, 2007 Author Report Share Posted September 21, 2007 @zen ako mozes baci mi neki link, ako ne probacu sam da nadjem. inace nisam danas stigao nista da uradim (dug dan na faxu) ali racunam na ovaj vikend, pa se javljam ponovo. inace u vezi te masti - kako se ona kupuje i gde? udjem u hifi radnju i kazem dajte mi 15w40 ili 20w40? Link to comment Share on other sites More sharing options...
paja959 Posted September 22, 2007 Report Share Posted September 22, 2007 Re lucas:to je obicno,multigradno motorno ulje(15W40,20W40).Za mast vidi sa Zen-om,on ga ne spomnje. Link to comment Share on other sites More sharing options...
Dacho Posted September 22, 2007 Report Share Posted September 22, 2007 U pravilu bilo kakva mast nebi smjela ići u ležaj gramafona jer ipak pruža nekakav otpor pri vrtnji ležaja. Å to se tiÄe ulja bolje je Å¡to rijeÄ‘e ulje upotrijebiti, polusintetiÄko npr. 5W40 ili Äak je dobro ulje za podmazivanje precizne mehanike, recimo za Å¡ivaće maÅ¡ine. Takvog ulja ima u većim Å¡oping cetrima od Singera, Bagat ili sl. u malim boÄicama i namjenjena su baÅ¡ za sliÄnu svrhu gdje je bitno Å¡to manje trenje. Link to comment Share on other sites More sharing options...
