durd Posted August 28, 2025 Report Posted August 28, 2025 Hegel H80 sa ugrađenim Dacom i daljincem. 700e Technical Specifications Digital inputs: 2 coax, 2 optical and 1 USB Analog inputs: 2 RCA unbalanced (1 configurable) and 1 XLR Balanced input Output Power: 75 W pc into 8 Ohms, 125 W pc into 4 Ohms Frequency response: 5 Hz - 100.000 Hz Signal-to-noise ratio: More than 100dB Crosstalk: Less than -100dB Distortion: Less than 0.01% @ 50W 8 Ohms 1kHz Intermodulation: Less than 0.01% (19kHz + 20kHz) Damping Factor: More than 1000 Dimensions/Weight: 10cm x 43cm x 34.5cm (HxWxD), 12kg
