mmilovan Posted June 5, 2013 Report Share Posted June 5, 2013 Tergitol? http://www.hi-files.com/forum/index.php?/topic/25568-knosti-record-cleaner-as-milos-suggested/page-2#entry485467 . Svakako i to! Quote Link to comment Share on other sites More sharing options...
空也 Posted June 5, 2013 Report Share Posted June 5, 2013 To je sasvim u redu, ali takva pumpa žestoko zvrÄi. RazmiÅ¡ljao sam o ovom:http://www.tehnomax.me/KUCNI%20APARATI/USISIVACI/Gorenje_MVC_48_WB.php ili sa nekim varijantama (vele bilo je i manjih) onih usisivaÄa na vodu... Da li to ima dovoljnu snagu usisavanja da pokupi sve cestice vode iz brazde i ostavi je suvom? Moj usisivac ima 1400W, ovaj malecki ima samo 40W. Ne uspevam da pronadjem snagu motora na fabrickim masinama za ciscenje ploca. . Quote Link to comment Share on other sites More sharing options...
空也 Posted June 5, 2013 Report Share Posted June 5, 2013 Simpatican polu-DIY: http://www.audioenz.co.nz/forums/showthread.php/11788-The-Kiwi-Record-Cleaning-Machine-is-here!?s=dbe0b923c700d938bffb5139cb571a35 Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted June 5, 2013 Report Share Posted June 5, 2013 Ljudi, probajte apotekarskim benzinom, neće vam trebati nikakva tehnika, oprema niti druge hemikalije. Quote Link to comment Share on other sites More sharing options...
空也 Posted June 5, 2013 Report Share Posted June 5, 2013 Ljudi, probajte apotekarskim benzinom, neće vam trebati nikakva tehnika, oprema niti druge hemikalije. Zanimljiva ideja. Koji je postupak? Kako se ukljanja iz brazdi prljavstina rastvorena benzinom, tj. sprecava da se ponovo zalepi kada benzin ispari? Kako benzin utice na etikete? Da li rastvara stamparsku boju? Quote Link to comment Share on other sites More sharing options...
空也 Posted June 5, 2013 Report Share Posted June 5, 2013 Svakako i to! E da, zaboravih, gde si kupovao onu Disc Doctor tecnost? Nigde je nisam nasao po evropskim sajtovima. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted June 5, 2013 Report Share Posted June 5, 2013 Zanimljiva ideja. Koji je postupak? Kako se ukljanja iz brazdi prljavstina rastvorena benzinom, tj. sprecava da se ponovo zalepi kada benzin ispari? Kako benzin utice na etikete? Da li rastvara stamparsku boju? ÄŒetkicom ili tuferom vate. Quote Link to comment Share on other sites More sharing options...
mmilovan Posted June 6, 2013 Report Share Posted June 6, 2013 E da, zaboravih, gde si kupovao onu Disc Doctor tecnost? Nigde je nisam nasao po evropskim sajtovima. U Americi... Quote Link to comment Share on other sites More sharing options...
mmilovan Posted June 6, 2013 Report Share Posted June 6, 2013 Ljudi, probajte apotekarskim benzinom, neće vam trebati nikakva tehnika, oprema niti druge hemikalije. Nisam baÅ¡ za ovo. PoÅ¡to meni treba "sigurna" teÄnost za viÅ¡e povrÅ¡ina (nitroceluloza, acetati, PVC i varijante u vidu Decelitha, Å¡elaci koji su u suÅ¡tini složena smeÅ¡a svega i svaÄega Äemu se ni ne zna sastav, polistireni itd), koja je, pritom i deklarisana i dokazana, izbegavam ovakva reÅ¡enja. Å to ne znaÄi da ne funkcioniÅ¡e. Quote Link to comment Share on other sites More sharing options...
mmilovan Posted June 6, 2013 Report Share Posted June 6, 2013 Da li to ima dovoljnu snagu usisavanja da pokupi sve cestice vode iz brazde i ostavi je suvom? Moj usisivac ima 1400W, ovaj malecki ima samo 40W. Ne uspevam da pronadjem snagu motora na fabrickim masinama za ciscenje ploca. . Možda, onda, ipak najmanji "vodeni" usisivaÄ? Ili videti kako se kreću snage na fabriÄkim maÅ¡inama za Äišćenje ploÄa. Quote Link to comment Share on other sites More sharing options...
Scorpio(DDMF)! Posted June 6, 2013 Report Share Posted June 6, 2013 Ljudi, probajte apotekarskim benzinom, neće vam trebati nikakva tehnika, oprema niti druge hemikalije. Svojevremeno (kada je Willi izneo tu ideju) isprobano na test plochi - dodushe, sa obichnim (Zippo) benzinom i tuferom. Nisam primetio loshe efekte, tj. plocha je bila chistija, dok se pri razmazivanju i trenju tufera natopljenog benzinom o plochu chuje veoma primetno pucketanje statichkog elektriciteta, pa plocha po chishcenju postaje veoma naelektrisana... Pozdrav! Quote Link to comment Share on other sites More sharing options...
ninja Posted June 6, 2013 Report Share Posted June 6, 2013 Možda, onda, ipak najmanji "vodeni" usisivaÄ? Ili videti kako se kreću snage na fabriÄkim maÅ¡inama za Äišćenje ploÄa. Uzmite strari naj jaci i izbacite ga na balkon u neku platicnu kutiju da ne kisne. Zamjenite onu rebrastu cijev sa glatkom, dobicete puno na snazi. Te rebraste imaju puno veci dP od glatke, tako da ili dobijete vecu snagu usisavanja ili istu ali sa duzom cijevi ako se ne moze staviti blizu balkona. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted June 6, 2013 Report Share Posted June 6, 2013 Svojevremeno (kada je Willi izneo tu ideju) isprobano na test plochi - dodushe, sa obichnim (Zippo) benzinom i tuferom. Ala si je zamastio, napravio si komplet lepinju od ploÄe! Mora da bude apotekarski, Äisti benzin, bez masnih frakcija u sebi. Quote Link to comment Share on other sites More sharing options...
空也 Posted June 6, 2013 Report Share Posted June 6, 2013 ÄŒetkicom ili tuferom vate. Svojevremeno (kada je Willi izneo tu ideju) isprobano na test plochi - dodushe, sa obichnim (Zippo) benzinom i tuferom. Nisam primetio loshe efekte, tj. plocha je bila chistija, dok se pri razmazivanju i trenju tufera natopljenog benzinom o plochu chuje veoma primetno pucketanje statichkog elektriciteta, pa plocha po chishcenju postaje veoma naelektrisana... Pozdrav! Kapiram da je benzin super za uklanjanje otisaka prstiju i masnih fleka. Sta je za jako zaprljanim plocama sa tonom prasine sabijene u brazdama, kakve najcesce nalazimo po buvljacima? Da li takvu prljavstinu dobrim (vecim?) delom samo razmazujemo levo, desno po ploci? Prljavstina ce se usled dejstva benzina rastvoriti, ali kako da je izvucemo iz brazdi? Deo djubreta ce ostati zalepljen na dlake cetkice ili na tufer, ali dobar deo ce se ponovo zalepiti za brazdu posto benzin jako brzo isparava? Ja sam benzin koristio za ciscenje foto objektiva i za to je stvarno dobar, uklanja otiske prstiju bez razmazivanja i isparava brzo i ne ostavlja nikakav trag. Ipak, staklo je glatko a ploce nisu. Metodi sa vlaznim ciscenjem se delom zasnivaju, ili na slivanju, u vodi rastvorene, shtroke sa vertikalno postavljenih ploca, ili na usisavanju te tecnosti iz brazdi. To je sa benzinom neizvodljivo. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted June 6, 2013 Report Share Posted June 6, 2013 Prljavstina ce se usled dejstva benzina rastvoriti, ali kako da je izvucemo iz brazdi? Предлажем да Ñе проба иÑправан компреÑор из фрижидера. Он има две цеви кроз једну увлачи а кроз другу издувава ваздух. Можда треба пробати издувавати плочу! Ðаравно на тераÑи или...........!? Сам кромпеÑор је прилично Ñнажан а поврх Ñвега и тих. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted June 6, 2013 Report Share Posted June 6, 2013 A usisivaÄ za mrvice sa stola sa Äetkicama ili mekom gumom na ustima (ozbiljan sam)? Quote Link to comment Share on other sites More sharing options...
空也 Posted June 6, 2013 Report Share Posted June 6, 2013 A usisivaÄ za mrvice sa stola sa Äetkicama ili mekom gumom na ustima (ozbiljan sam)? Problem sa medicinskim benzinom je taj sto skoro trenutno isparava. Dok smo zavrsili brisanje, odlozili cetkicu i prineli ploci usisivac, on je vec odavno ispario a vishak prljavstine je verovatno ponovo zalepljen u brazdama. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted June 6, 2013 Report Share Posted June 6, 2013 A usisivaÄ za mrvice sa stola sa Äetkicama ili mekom gumom na ustima (ozbiljan sam)? Играчка, мала Ñнага уÑиÑавања ( преозбиљан Ñам ). Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted June 6, 2013 Report Share Posted June 6, 2013 Problem sa medicinskim benzinom je taj sto skoro trenutno isparava. Dok smo zavrsili brisanje, odlozili cetkicu i prineli ploci usisivac, on je vec odavno ispario a vishak prljavstine je verovatno ponovo zalepljen u brazdama. Mislio sam na suÅ¡enje usisivaÄem uopÅ¡te, za bensin si u pravu. Quote Link to comment Share on other sites More sharing options...
mmilovan Posted June 6, 2013 Report Share Posted June 6, 2013 Предлажем да Ñе проба иÑправан компреÑор из фрижидера. Он има две цеви кроз једну увлачи а кроз другу издувава ваздух. Можда треба пробати издувавати плочу! Ðаравно на тераÑи или...........!? Сам кромпеÑор је прилично Ñнажан а поврх Ñвега и тих. Da li prolazak vode može da ga oÅ¡teti? Quote Link to comment Share on other sites More sharing options...
mmilovan Posted June 6, 2013 Report Share Posted June 6, 2013 A usisivaÄ za mrvice sa stola sa Äetkicama ili mekom gumom na ustima (ozbiljan sam)? To sam bio predložio pre par dana (i to onaj koji usisava i vodu)... Quote Link to comment Share on other sites More sharing options...
mmilovan Posted June 6, 2013 Report Share Posted June 6, 2013 Uzmite strari naj jaci i izbacite ga na balkon u neku platicnu kutiju da ne kisne. Zamjenite onu rebrastu cijev sa glatkom, dobicete puno na snazi. Te rebraste imaju puno veci dP od glatke, tako da ili dobijete vecu snagu usisavanja ili istu ali sa duzom cijevi ako se ne moze staviti blizu balkona. A Å¡ema da bude kao ona koju je Kuja predložio? Na DIY forumima vidim da Äesto koriste i vodene pumpe. To se može kupiti kao zasebna jedinica (koliko videh). Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted June 6, 2013 Report Share Posted June 6, 2013 Ja mislim da ne treba da pristanete na manje od hidrofora! Hidrofor 1.5kw Zamena za Kovin Šalim se, nisam gramofondžija, samo sam preneo iskustvo sa benzinom. Quote Link to comment Share on other sites More sharing options...
mmilovan Posted June 6, 2013 Report Share Posted June 6, 2013 Ja mislim da ne treba da pristanete na manje od hidrofora! Hidrofor 1.5kw Zamena za Kovin Šalim se, nisam gramofondžija, samo sam preneo iskustvo sa benzinom. Možda je ovo kandidat? "Ruska pumpa ZA VODU KAMA10 USISAVA VODU SA DUBINE OD 7m, IZBACUJE U VISINU 32m. Jacina pumpe 500 W" Quote Link to comment Share on other sites More sharing options...
ninja Posted June 6, 2013 Report Share Posted June 6, 2013 Nisam siguran za vodene pumpe ..... a Dyson Quote Link to comment Share on other sites More sharing options...
