Ćirko Posted September 22, 2023 Report Posted September 22, 2023 Dobar dan, dvoumim se koji gramofon da kupim. Zeleno bih nov ali ne znam koji brend da uzmem. Molim vas pišite mi? hvala Quote
Nixie Posted September 22, 2023 Report Posted September 22, 2023 Još samo napiši koliko para planiraš za tu zabavu. Quote
zek Posted September 23, 2023 Report Posted September 23, 2023 I napiši koliko ploča imaš za početak. Quote
Relco Mantis Posted September 23, 2023 Report Posted September 23, 2023 I šta ti je ostatak sustava.... Quote
Ćirko Posted September 23, 2023 Author Report Posted September 23, 2023 Do 150 evra, imam oko 30 ploča Quote
Ćirko Posted September 23, 2023 Author Report Posted September 23, 2023 10 sati ranije, zek said: I napiši koliko ploča imaš za početak. Oko 30 Quote
Ćirko Posted September 23, 2023 Author Report Posted September 23, 2023 5 sati ranije, petarjovic said: I šta ti je ostatak sustava.... Lg zvučnici iz Quote
Ćirko Posted September 23, 2023 Author Report Posted September 23, 2023 13 sati ranije, Nixie said: Još samo napiši koliko para planiraš za tu zabavu. Do 150evra, nov Quote
zek Posted September 23, 2023 Report Posted September 23, 2023 35 minuta ranije, Ćirko said: Lg zvučnici iz iz ??? Koje pojačalo imaš i da li pojačalo ima ulaz za gramofon? Quote
Ćirko Posted September 23, 2023 Author Report Posted September 23, 2023 1 sat ranije, zek said: iz ??? Koje pojačalo imaš i da li pojačalo ima ulaz za gramofon? Kucni bioskop ali mogu da povezem preko aux kabla Quote
sweeT_Tooth Posted September 23, 2023 Report Posted September 23, 2023 Kucni bioskop ali mogu da povezem preko aux kablaОнда погледај грамофон који има уграђен грамофонски преамп да би адекватно прикључио на аух улаз.Послато са M2006C3MNG помоћу Тапатока Quote
sondek Posted September 23, 2023 Report Posted September 23, 2023 Proveri prvo da li je gramofon uopšte 5.1 ? Quote
Ćirko Posted September 23, 2023 Author Report Posted September 23, 2023 56 minuta ranije, sondek said: Proveri prvo da li je gramofon uopšte 5.1 ? Ok Quote
Ćirko Posted September 23, 2023 Author Report Posted September 23, 2023 4 sati ranije, zek said: iz ??? Koje pojačalo imaš i da li pojačalo ima ulaz za gramofon? Nemam pojačalo Quote
zek Posted September 23, 2023 Report Posted September 23, 2023 59 minuta ranije, Ćirko said: Nemam pojačalo Kako sviraju zvučnici ako nema pojačala - ili imaš aktivne zvučnike? Quote
shon3i Posted September 23, 2023 Report Posted September 23, 2023 7 sati ranije, Ćirko said: Do 150 evra, imam oko 30 ploča https://gigatron.rs/gramofoni/audiotechnica-gramofon-at-lp60xbk-380573 Malo probija budzet, ali ima sve sto treba da bi ga ukliopio u postojeci sistem. Quote
Ćirko Posted September 23, 2023 Author Report Posted September 23, 2023 1 sat ranije, zek said: Kako sviraju zvučnici ako nema pojačala - ili imaš aktivne zvučnike? Nisam siguran mislim da imaju Quote
Ćirko Posted September 23, 2023 Author Report Posted September 23, 2023 8 minuta ranije, shon3i said: https://gigatron.rs/gramofoni/audiotechnica-gramofon-at-lp60xbk-380573 Malo probija budzet, ali ima sve sto treba da bi ga ukliopio u postojeci sistem. Hvala Quote
Ćirko Posted September 23, 2023 Author Report Posted September 23, 2023 2 sati ranije, Iron man said: Onda Toska Jel se proizvode novi ? Quote
Nixie Posted September 23, 2023 Report Posted September 23, 2023 To se ne proizvodi odavno. Predloženi AT odgovara jer ima phono preamp ugrađen te ga možeš povezati na AUX ulaz. Ne očekuj čuda za te pare, tek da radi. Usput kupi i kabl za povezivanje na LG. Quote
Ćirko Posted September 23, 2023 Author Report Posted September 23, 2023 7 minuta ranije, Nixie said: To se ne proizvodi odavno. Predloženi AT odgovara jer ima phono preamp ugrađen te ga možeš povezati na AUX ulaz. Ne očekuj čuda za te pare, tek da radi. Usput kupi i kabl za povezivanje na LG. Ok hvala ti! Koji nov bi mi predložio? Quote
Nixie Posted September 23, 2023 Report Posted September 23, 2023 Teško mogu da preložim bilo šta za 150eur a da je novo ima u sebi phono preamp. Quote
