David.1992 Posted April 16, 2023 Report Share Posted April 16, 2023 У питању су звучници Pioneer CS-3070 Specifications Type: 3 way, 3 driver loudspeaker system Frequency Response: 45Hz to 20kHz Power Handling: 120W Impedance: 8Ω Sensitivity: 90dB Bass: 1 x 200mm cone Midrange: 1 x 77mm cone Tweeter: 1 x 66mm cone Enclosure: bass reflex Dimensions: 258 x 540 x 234mm Weight: 6.1kg Да ли би било добро да их купим за појачало Pioneer А 30К? Да ли би уопште радили? Power output: 40 watts per channel into 8Ω (stereo) Frequency response: 5Hz to 100kHz Total harmonic distortion: 0.05% Input sensitivity: 2.8mV (MM), 200mV (line) Signal to noise ratio: 77dB (MM), 105dB (line) Output: 200mV (line) Speaker load impedance: 4Ω to 16Ω Dimensions: 435 X 128 X 360mm Weight: 7.9kg Accessories: CARTA30 remote control Year: 2012 Quote Link to comment Share on other sites More sharing options...
zek Posted April 16, 2023 Report Share Posted April 16, 2023 15 minuta ranije, David.1992 said: Да ли би било добро да их купим за појачало Pioneer А 30К? Niko ne zna da li bilo dobro ili ne, zavisno u kakvom su stanju zvučnici, da li su premotavani, koliko koštaju itd. 18 minuta ranije, David.1992 said: Да ли би уопште радили? Ako su ispravni, radili bi. Quote Link to comment Share on other sites More sharing options...
filip2002 Posted August 23, 2023 Report Share Posted August 23, 2023 Pozdrav ako nije kasno za odgovor, uz Pioneer a-10k sam imao Bose 201, pojacalo je prodato a zvucnici ostali. To je radilo savrseno, ako nisi nasao nista preporucujem ti da dodjes i probas. Quote Link to comment Share on other sites More sharing options...
