DejanM Posted January 5 Report Share Posted January 5 https://thenextweb.com/news/the-eus-8k-tv-ban-will-be-a-nightmare-for-startups Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted January 7 Report Share Posted January 7 Dok ne naprave modele koji ne troše mnogo. Quote Link to comment Share on other sites More sharing options...
DejanM Posted January 9 Author Report Share Posted January 9 Ja samo cekam kada ce da nam zabrane upotrebu A class pojacala. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted January 9 Report Share Posted January 9 27 minuta ranije, DejanM said: Ja samo cekam kada ce da nam zabrane upotrebu A class pojacala. То су поодавно требали да учине. Quote Link to comment Share on other sites More sharing options...
nesone Posted January 9 Report Share Posted January 9 Bicu zadovoljan kad puste TV signal 4K. Samo to ce biti jako tesko... 8K mi nije potreban. Quote Link to comment Share on other sites More sharing options...
Delija Posted January 9 Report Share Posted January 9 Za sada imas formulu 1 u 4K Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted January 9 Report Share Posted January 9 4 sati ranije, DejanM said: Ja samo cekam kada ce da nam zabrane upotrebu A class pojacala. Kako bude energije sve manje ima da zabrane sve što troši više nego što procene da je optimum. Quote Link to comment Share on other sites More sharing options...
Wizard Of Gore Posted January 9 Report Share Posted January 9 Da, ne bi me čudilo da nam svašta još zabrane, a za to vreme bogataši u svojim privatnim avionima lete po svetu iz čiste dosade, a mi da se stisnemo koliko god možemo jer "crkni sirotinjo!" Quote Link to comment Share on other sites More sharing options...
gvlada Posted January 9 Report Share Posted January 9 1 sat ranije, srdjan_cvetkovic said: Kako bude energije sve manje ima da zabrane sve što troši više nego što procene da je optimum. ЕУ одавно није под либелу. Quote Link to comment Share on other sites More sharing options...
Iron man Posted January 9 Report Share Posted January 9 TV TV in 8K Quote Link to comment Share on other sites More sharing options...
DejanM Posted January 9 Author Report Share Posted January 9 Sad sam pogledao potrosnju najnovijeg Sony 8K TVa od 75 incha ... Ima dva moda rada: - Standard Mode: 361 W - Vivid Mode: 590 W. I ova potrosnja ce da ugrozi stabilnost energetskog trzista ? Ili ce mozda smanjenje ove potrosnje da donese velike ustede ? Quote Link to comment Share on other sites More sharing options...
Arn Posted January 9 Report Share Posted January 9 Kolega je nedugo posle katastrofe u Fukušimi proveo nekih mesec dana u Japanu na stručnom usavršavanju, zaboravio sam koji je grad u pitanju. Japanci su tada morali da štede električnu energiju jer se ispad jedne nuklearke iz elektroenergetskog sistema itekako oseti. Izračunali su da će isključenjima struje verovatno napraviti više štete nego koristi, pa su se setili da apeluju na građane da ne peglaju garderobu. I bilo je najnormalnije da svi idu izgužvani, od spremačice do univerzitetskog profesora. Štaviše, ako bi neko imao da sebi ispeglanu majicu ili košulju, na njega/nju bi se gledalo sa odijumom ili prezirom. Hoću da kažem da kad imaš ideju, viziju i znanje, onda nađeš i načina da bude vuk sit i ovce na broju. Ovo sa televizorima mi ne izgleda tako. Quote Link to comment Share on other sites More sharing options...
Father Posted January 9 Report Share Posted January 9 Moj matori 49" LG UHD troši 105W-123W. To je oko 3x manje od podatka potrošnje 8K tv-a koji je naveden. Ipak rezolucija 8K je 4x 4K UHD u površini led ekrana. Ipak su negde uspeli da uštede energiju i učine ekran energetski efikasnijim. 🙂 Dodatno je i panel veće dijagonale namenjen za veće razdaljine i smatram da je sve to vrlo adekvatno za prostorije koje mali broj nas ima prilike da vidi u zivotu, a kamoli da oprema ovakvim tehničkim biserima. Treba samo ošinuti extra porez na ne ekonomičnu potrošnju apartaa tj. tu grupu koja opterećuje mrežu pa bogati neka plate više za luksuz. Neće to oni ni da osete, a od poreza će biti koristi za sve, čak i za njih. Quote Link to comment Share on other sites More sharing options...
Delija Posted January 9 Report Share Posted January 9 To me sve podseca na pricu o papirnim kesama u radnjama - u koje se pakuje gomila plasticnih flasa. Isto kao i elektricni automobili - licemerstvo nivo 500. Quote Link to comment Share on other sites More sharing options...
DejanM Posted January 9 Author Report Share Posted January 9 32 minuta ranije, Arn said: Kolega je nedugo posle katastrofe u Fukušimi proveo nekih mesec dana u Japanu na stručnom usavršavanju, zaboravio sam koji je grad u pitanju. Japanci su tada morali da štede električnu energiju jer se ispad jedne nuklearke iz elektroenergetskog sistema itekako oseti. Izračunali su da će isključenjima struje verovatno napraviti više štete nego koristi, pa su se setili da apeluju na građane da ne peglaju garderobu. I bilo je najnormalnije da svi idu izgužvani, od spremačice do univerzitetskog profesora. Štaviše, ako bi neko imao da sebi ispeglanu majicu ili košulju, na njega/nju bi se gledalo sa odijumom ili prezirom. Hoću da kažem da kad imaš ideju, viziju i znanje, onda nađeš i načina da bude vuk sit i ovce na broju. Ovo sa televizorima mi ne izgleda tako. Jedan malo OFF .... kada je Fukusima u pitanju. Kada je izbila havarija, trebalo je poslati inzinjere u elektranu da odrade neki posao (zaboravio sam koji). Kako je zracenje bilo jako, verovatnoca za dobijanje zdrastvenih problema (da ne kazem raka) je bila visoka. Onda se javilo nekoliko penzionisanih inzinjera, koji su ranije radili u Fukusimi. Predlozili su da oni udju u elektranu i odrade taj posao, jer oni su vec u godinama, pa ako se i razbole - naziveli su se. Njihove mladje kolege imaju sa druge strane tek zivot pred sobom. I tako i bi ... Quote Link to comment Share on other sites More sharing options...
DejanM Posted January 9 Author Report Share Posted January 9 11 minuta ranije, Delija said: To me sve podseca na pricu o papirnim kesama u radnjama - u koje se pakuje gomilu plasticnih flasa. Isto kao i elektricni automobili - licemerstvo nivo 500. To sa elektricnim automobilima se pretvara u cirkus. Sa ovim cenama struje, kao u onom vicu, ljudima se vise isplati da pune te aute strujom iz dizel generatora. Umesto ovako besmislenih mera, bilo bi mnogo bolje da neko strucan napravi razumnu energetsku strategiju za EU. Ali na zalost to se nece desiti ... Quote Link to comment Share on other sites More sharing options...
gvlada Posted January 9 Report Share Posted January 9 58 minuta ranije, Father said: 🙂Dodatno je i panel veće dijagonale namenjen za veće razdaljine... https://www.petra.com/blog/be-the-expert-8k-tv/ Погледај препоручене раздаљине. 75" 8К и велика просторија не иду у истој реченици. Quote Link to comment Share on other sites More sharing options...
JTGTS Posted January 9 Report Share Posted January 9 Malo bolja graficka kartica pojede sama 300-500w plus procesor itd. E sad i 8k TV ...... Evo ja koristim D klasu stedim struju Quote Link to comment Share on other sites More sharing options...
Father Posted January 9 Report Share Posted January 9 27 minuta ranije, gvlada said: https://www.petra.com/blog/be-the-expert-8k-tv/ Погледај препоручене раздаљине. 75" 8К и велика просторија не иду у истој реченици. Kao ni bioskopsko platno u bioskopu koje je npr 15m dijagonale. Vrv. ga treba posmatrati sa 20cm udaljenosti, ne znam nešto propuštam? Trinitron TV 72cm / DVD rezolucija da se gleda sa 5m!!?? A sve preko UHD sa manje razdaljine od 1.8m???? Ovo je ako ne grešim grafik razdaljina sa koje se ne vide artefakti. A možda je i preporuka za gledanje, bem ga ja u tu novu teKniku?? Quote Link to comment Share on other sites More sharing options...
nesone Posted February 5 Report Share Posted February 5 Cale, tako je kako je. Da bi mogao kod 4K da vidis svaki piksel. Ja OLED 55 incha gledam sa nekih 220 do 230 cm. Quote Link to comment Share on other sites More sharing options...
gvlada Posted February 5 Report Share Posted February 5 И то је горња граница... Quote Link to comment Share on other sites More sharing options...
nesone Posted February 8 Report Share Posted February 8 Taman je. Fotelja ide napred , nazad. Za 4K i stereo slusanje sistema. 2. opcija je najvaznija. Postoje tacke na podu, gde je savrsen stereo zvuk. I nema greske. Zakucane u podu tacke. Quote Link to comment Share on other sites More sharing options...
Father Posted February 8 Report Share Posted February 8 Meni je nezamislivo da gledam sad već stari 49" UHD LG sa 2m. Trenutno gledam sa 3.8m udaljenosti i priznajem da bih mogao da budem bliže (cca 50cm) ili da imam veći TV, ali onda su mi i trosed i glava 100cm udaljeni od zadnjeg zida i prostorija gubi smisao za korišćenje. Platno za projekcije, koje mi je namenjeno za 100" sliku se sasvim dobro sagledava iz postojeće pozicije. Ono je nekih 20cm bliže od TV-a ali se i na višoj poziciji formira slika u filmskim formatima koji su izduženiji od 16:9. Problem sa većim TV-om je više zbog uticaja na refleksije zvuka u sadašnjoj organizaciji pozicije zvučnika i sedenja, tako da se vrlo stidljivo ohrabrujem za promene u tom pravcu. Quote Link to comment Share on other sites More sharing options...
Delija Posted February 8 Report Share Posted February 8 Navikne se covek lako i brzo na razne varijacije. Cinjenica je da daleko vise prija sedenje dalje i gledanje veceg ekrana u odnosu na sedenje blize i gledanje manjeg. Quote Link to comment Share on other sites More sharing options...
gvlada Posted February 8 Report Share Posted February 8 Постоји разлика када гледаш у прозор и кроз прозор, тиме и када пратиш екран или дешавање у филму. Биоскопски осећај се добија када се на одређеној удаљености прати слика одговарајуће величине. Што каже Делија ствар је навике али када пробаш оно боље тешко се враћаш на горе, осим ако не мораш. 49" и 4м удаљености, ту може и дивх биоскопски да прође. Quote Link to comment Share on other sites More sharing options...
