Arkangel047 Posted October 1, 2022 Report Share Posted October 1, 2022 Molim za pomoc iskusnije audiofile. Dobio sam na poklon AV Reciver Sony STR-VA 555 ES, posto koristim vec Yamaha pretpojacalo sa pojacalom a imam samo 2 zvucnika povezea sam paralelno na tape out izlaz Sony STR-VA 555 ES u Yamahino pretpojacalo. Na Sony STR-VA 555 ES imam povezano jos nekoliko uredjaja, na Yamahu cujem samo kada na Sony Reciveru radi tuner, ali ne cujem recimo kada prebacim CD Player, Mini Disc. Ne znam kako da dobijem zvuk od ovih uredjaja jer ovaj Sony Reciver nema source opciju kao kod klasicnih pojacala, ja sam i ranije na tape out vezivao druga pojacala ali ovaj problem nisam imao, jer source odabire sta ces da slusas, ali sada ovde toga nema, Tuner moze da se cuej na yamahi, jer je valjda ugadjen u reciver, ali ostali uredjaji se cuju na samom Sony Reciveru ali ne i na Yamaha, ne dobijam na taj tape out izlaz njihov signal. Ima li ko da mi pomogne nekim savetom? Quote Link to comment Share on other sites More sharing options...
zek Posted October 1, 2022 Report Share Posted October 1, 2022 Probaj da povežeš na pre-out konektore, onda možeš da regulišeš jačinu na Soniju. Na Soniju namesti da radi u stereo režimu. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted October 1, 2022 Report Share Posted October 1, 2022 4 sati ranije, Arkangel047 said: Sony Reciver nema source opciju kao kod klasicnih pojacala А јел има "Rec Out" опцију? Quote Link to comment Share on other sites More sharing options...
Arkangel047 Posted October 1, 2022 Author Report Share Posted October 1, 2022 evo kako izgleda pozadi i sta sve ima Quote Link to comment Share on other sites More sharing options...
Delija Posted October 1, 2022 Report Share Posted October 1, 2022 Preout front sa AVR-a povezi na preamp. Quote Link to comment Share on other sites More sharing options...
Arkangel047 Posted October 1, 2022 Author Report Share Posted October 1, 2022 Jesam, tako sam odmah povezao po nekoj logici, ne funkcionise, na preot front se cak ni tuner ne cuje, na tape out se cuje tuner na Yamahi, ali ni jedan drugi uredjaj. Quote Link to comment Share on other sites More sharing options...
zek Posted October 1, 2022 Report Share Posted October 1, 2022 Tu nema logike, verovatno nešto ne radiš kako treba na Soniju. Quote Link to comment Share on other sites More sharing options...
Delija Posted October 1, 2022 Report Share Posted October 1, 2022 22 minuta ranije, Arkangel047 said: Jesam, tako sam odmah povezao po nekoj logici, ne funkcionise, na preot front se cak ni tuner ne cuje, na tape out se cuje tuner na Yamahi, ali ni jedan drugi uredjaj. To je jedino ispravno povezivanje. Ne znam da li negde gresis ili je nesto neispravno, ali proveri jos jednom. Quote Link to comment Share on other sites More sharing options...
Arkangel047 Posted October 1, 2022 Author Report Share Posted October 1, 2022 Sve sam uradio kako treba Sony Preout Front ide u Yamaha IN Aux, zvuk nema, nebitno dali je volume na Sony pusteno ili ne, podesio sam na 2 kanala, opet nista, spojio zvucnike na Sony, Sony sam za sebe funkcionise bez problema, ali sa out izlaza ne mogu dobiti zvuk nikako, a Sony nema Rec selector, koji inace resava ovaj problem. Quote Link to comment Share on other sites More sharing options...
Delija Posted October 1, 2022 Report Share Posted October 1, 2022 Proveri da li u opcijama postoji neko podesavanje preout-a. To jednostavno mora da radi - tome jedino i sluzi. Ako ne - neispravan je izlaz. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted October 1, 2022 Report Share Posted October 1, 2022 И Ја исто мислим, да нема неко подешавање за пре-аут! Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted October 1, 2022 Report Share Posted October 1, 2022 14 minuta ranije, Arkangel047 said: Sve sam uradio kako treba Sony Preout Front ide u Yamaha IN Aux А шта кажу упутства за употребу оба уређаја? Quote Link to comment Share on other sites More sharing options...
Arkangel047 Posted October 1, 2022 Author Report Share Posted October 1, 2022 Uspeo sam, ali ne preko pre out, nego preko MD/DAT Out, preko njega funkcionisu svi IN ulazi na Sony, to je ono sto sam i hteo, jedino ne znam zasto isti taj MD/DAT In , jedino na njemu se ne cuje nista, ali svi ostali CD, Tape, Audio in itd, cuju s ebez problema, ali na pre out ne dobijam nista jedino na MD/DAT out. Quote Link to comment Share on other sites More sharing options...
Arkangel047 Posted October 1, 2022 Author Report Share Posted October 1, 2022 I primetio sam tek sada, da ako povezem bilo koji uredjaj preko optickog kabla opet se ne dobija zvuk nikakav, funkcionisu samo analogni za OUT, ali OK i to je nesto, hvala svima na savetima. Quote Link to comment Share on other sites More sharing options...
gvlada Posted October 2, 2022 Report Share Posted October 2, 2022 Нека опција није активирана. Тај мд излаз је сума канала, треба пре за предње само. Quote Link to comment Share on other sites More sharing options...
Arkangel047 Posted October 2, 2022 Author Report Share Posted October 2, 2022 Na samom resiveru uospte ne postoi nista oko podesavanja Pre Out izlaza, logicno je kako kazete da on za to i sluzi d a, posalje signal, ali kada se na njega spoji kao sto sam objasnio nema zvuka, jako je cudno sto i na Tape Out nema zvuka ili na bilo koji out osim na MD Out. Quote Link to comment Share on other sites More sharing options...
zek Posted October 2, 2022 Report Share Posted October 2, 2022 Imaš li uputstvo za upotrebu tog Sonija? https://www.sony-asia.com/electronics/support/product/str-va555es/manuals Quote Link to comment Share on other sites More sharing options...
zek Posted October 2, 2022 Report Share Posted October 2, 2022 23 sati ranije, Arkangel047 said: ako povezem bilo koji uredjaj preko optickog kabla opet se ne dobija zvuk nikakav U uputstvu lepo piše da se na out konekcijama može dobiti samo analogni signal sa ulaza ne i digitalni (zaštita radi kopiranja). Quote Link to comment Share on other sites More sharing options...
gvlada Posted October 2, 2022 Report Share Posted October 2, 2022 То важи за линијски излаз, пре оут мора да шаље све за предње. Quote Link to comment Share on other sites More sharing options...
