Zexx Posted September 27, 2022 Report Posted September 27, 2022 185 soma jura, lovely jubbly... Quote
sondek Posted September 27, 2022 Report Posted September 27, 2022 Bice jos jedan Marten u Ai sobi. Skromniji doduse, mislim da je oko 20k. Quote
Delija Posted September 27, 2022 Report Posted September 27, 2022 Duplo manje. Oko 10k su Oscar Trio. Quote
sondek Posted September 27, 2022 Report Posted September 27, 2022 (edited) Taman prava mera za nas standard. ?My bad mislio sam da je ona skuplja (diamond)verzija od 20k. Jos bolje ovako, izbalansiraniji sistem je finansijski, koliko toliko dostizan i nasem trzistu Edited September 29, 2022 by sondek Quote
Ljuba Posted September 27, 2022 Author Report Posted September 27, 2022 Danas dobili potvrdu, pa sutra ide najava. Išli smo sa jednom najavom da dan, da vas ne štrecamo. Quote
Starch Posted September 27, 2022 Report Posted September 27, 2022 Bas se radujem da dodjem, dosta stvari su mi na listi da poslusam. Quote
Delija Posted September 27, 2022 Report Posted September 27, 2022 5 sati ranije, Zexx said: 185 soma jura, lovely jubbly... Verujem da ce i "soba" i setup biti adekvatni sistemu - posto bi i Marten delegacija trebalo da bude prisutna. Quote
srdjan_cvetkovic Posted September 28, 2022 Report Posted September 28, 2022 17 sati ranije, Delija said: Zlobica se podrazumeva uvek sa nekom ekskluzivom Koliko vidim, sistem “teška Hi-End artiljerija”, svaka čast.? Quote
sondek Posted September 28, 2022 Report Posted September 28, 2022 Wow, Nagra Reference gramofon ... padoh u nesves' !!! Čak 5 dobrih gramofona. Sad vec razmisljam da li mi je jedan dan uopste dovoljan za sajam. Ljubo , Respect za sajam. Quote
Relco Mantis Posted September 28, 2022 Report Posted September 28, 2022 3 sati ranije, sondek said: Wow, Nagra Reference gramofon ... padoh u nesves' !!! Čak 5 dobrih gramofona. Sad vec razmisljam da li mi je jedan dan uopste dovoljan za sajam. Ljubo , Respect za sajam. Biće i jedan Perpetuum Ebner kod našeg zajedničkog prijatelja? Quote
sondek Posted September 28, 2022 Report Posted September 28, 2022 Znam, to je jedan od tih 5. Nije bio u najavi pa nisam hteo da ga pominjem. Fono sekcija iza njega je takodje vrhunska. Lep mi je taj gramofon, volim taj klasican dizajn...na dobrom glasu sto se zvuka tice. Quote
srdjan_cvetkovic Posted September 28, 2022 Report Posted September 28, 2022 Meni deluje ovako na prvu loptu....možda grešim, ne znam....ali deluje mi kao da će ovo biti jaaaakooo dobar događaj, jedan od ponajboljih koji si do sada organizovao Ljubo. Iskreno se radujem i doćiću bar 1 dan. Quote
SWITCHERMAN Posted September 28, 2022 Report Posted September 28, 2022 Nagra+Marten+Way+Finite+ .....oko 700000 $....???? Quote
ceman Posted September 28, 2022 Report Posted September 28, 2022 On 9/19/2022 at 2:02 PM, sondek said: Stizem, ako neko iz NS zeli mozemo i zayedno... skup je dizel i treba ga pretvoriti u pivo. pff, mogao bih i ja da dodjem, iako imam dosta stvari planiranih ovaj vikend. Nisam do sad bio na slicnim desavanjima. Ali mi se dopada ideja sa Sokolom, taman ptiliks da probam, a i da ne brinem o parkingu Quote
Iron man Posted September 28, 2022 Report Posted September 28, 2022 21 sati ranije, Delija said: Verujem da ce i "soba" i setup biti adekvatni sistemu Znamo kolko je HolidejIn adekvatan Quote
sondek Posted September 28, 2022 Report Posted September 28, 2022 Prilika da proverimo kvalitet gradnje ? Quote
sondek Posted September 28, 2022 Report Posted September 28, 2022 36 minuta ranije, CoyoteKG said: Ali mi se dopada ideja sa Sokolom, taman ptiliks da probam, a i da ne brinem o parkingu I meni se dopala ideja da se prvi put provozam sokolom 200 na sat, a onda je pecass to pokvario pa cu sa njim 210 ...mama mia , razumite ako ne bidnem sav svoj...da malo vidimo kako delija izgleda u retrovizoru ??? Quote
nkrgovic Posted September 28, 2022 Report Posted September 28, 2022 Je'l vas dvojica dolazite u subotu ili nedelju? Obojicu treba da vidim odavno.... Quote
Ljuba Posted September 28, 2022 Author Report Posted September 28, 2022 35 minuta ranije, sondek said: I meni se dopala ideja da se prvi put provozam sokolom 200 na sat, a onda je pecass to pokvario pa cu sa njim 210 ...mama mia , razumite ako ne bidnem sav svoj...da malo vidimo kako delija izgleda u retrovizoru ??? Samo se čvrsto držite ? Quote
sondek Posted September 28, 2022 Report Posted September 28, 2022 Dacemo zeni da vozi, ona motorom nikad preko 200. Peca do 300 Quote
Dražo Posted September 30, 2022 Report Posted September 30, 2022 Ja cu se dogegati sutra, sa samo 210km/h, na krilima Sokola ? Quote
Sloba Posted October 1, 2022 Report Posted October 1, 2022 On 28.9.2022. at 20:19, SWITCHERMAN said: Nagra+Marten+Way+Finite+ .....oko 700000 $....???? Zvuči fenomenalno. Šteta što je izbor muzike takav kakav jeste. Bio sam 3 puta i sva 3 puta teška depra, ton svake 4 sekunde minus dire straits bio jednom. Preporučujem da se ne ulazi prvo u ovu sobu jer posle sve gubi smisao ? Dynaudio zvuči kao da je nešto pregorelo. Teoharov odličan! Triangle dobar. Quote
Iron man Posted October 1, 2022 Report Posted October 1, 2022 Ima li neko logično objašnjenje da reproduktor ( Nagra gramofon) košta duplo više od vrhunskog rezača mastera ploča? (Neumann recimo) Quote
