Aoxomoxoa Posted September 17, 2022 Report Share Posted September 17, 2022 Doslo je vreme da se kompletira sistem. Trenutno u opticaju: 1. Gramofon Technics SL150/Rega RB303/Ortofon 2MBlack/Rega Phono mk3 2. Pojacalo Unison Research Simply Four 3. Zvucnici Harbeth P3esr --------------------------------------------- 4. CD Philips CD614/M2Tech evo dac kockica. Upravo mi ovde treba pomoc oko dac-a. Znaci DAC samo kao eksterni dodatak cd plejeru sa digitalnim izlazom.Nema potrebe za opcijama za kompjuter,tv,slusalice,predpojacalo... Budzet bi bio oko 1.000e za novo/polovno. I,naravno,treba da svira bolje od kockice. Svaki savet je dobrodosao. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 17, 2022 Report Share Posted September 17, 2022 Neki Chord...Qute, 2Qute, Qutest,... Mnooogo bolje svira od M2Tech, čak i najstariji model koji sam lično imao, QuteHD. Quote Link to comment Share on other sites More sharing options...
petarjovic Posted September 17, 2022 Report Share Posted September 17, 2022 Acoustic Invader DAC 1. i 2. Oktobar sajam u Holiday Inn, pregledaš i obidješ sve, poneseš taj som evra i iskoristiš sajamski popust. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 17, 2022 Report Share Posted September 17, 2022 Zaboravih na AI...da, ovo je možda i najpametniji predlog, dobar DAC, imaš podršku "u komšiluku", sajamski popust, nov sa garancijom... Quote Link to comment Share on other sites More sharing options...
Ljuba Posted September 17, 2022 Report Share Posted September 17, 2022 @petarjovic ispravio sam ti datum. Sajam je 1. i 2. Oktobar www.hi-files.show Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted September 17, 2022 Author Report Share Posted September 17, 2022 Iscitavam staru temu:koji dac kupiti,pa evo nedoumice: Ja imam prvu kockicu,sa iFi napajanjem. Citam da zajedno sve cetiri kockice zvuce mnogo bolje od jedne. Da li te ostale tri kockice imaju ikakvog uticaja na zvuk ako se slusa samo cd plejer? Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 17, 2022 Report Share Posted September 17, 2022 Imaju, ali ja ne bih razmišljao u tom pravcu, pošto investicija ne opravdava dobitak. Prvo, tebi ne bi bio potreban USB2SPDIF konverter, jer ti verovatno sa CDP ide signal preko coax na DAC. To je jedna komponenta manje. Morao bi da uzmeš Clock i baterijsko napajanje. Obe komponente nisu baš na izvolte na second hand tržištu i ne bi te izašle manje od 300, i to ako neko prodaje kao combo (ja ni slučajno ne bih dao više para). Pri čemu imaš ozbiljnu opasnost da kupiš baterijsko napajanje sa problemom koje je budženo. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted September 17, 2022 Author Report Share Posted September 17, 2022 Upravo tako sam nesto i ja shvatio. Quote Link to comment Share on other sites More sharing options...
sondek Posted September 17, 2022 Report Share Posted September 17, 2022 2 sati ranije, petarjovic said: Acoustic Invader DAC 1. i 2. Oktobar sajam u Holiday Inn, pregledaš i obidješ sve, poneseš taj som evra i iskoristiš sajamski popust. Za staru verziju Dac-a je blizu sa budzetom, dok za novi koji ce biti na sajmu bogami tesko...trebace tu kreditčić. Quote Link to comment Share on other sites More sharing options...
Delija Posted September 17, 2022 Report Share Posted September 17, 2022 I to sve za Philips CD 614? Jel se salite? Quote Link to comment Share on other sites More sharing options...
sondek Posted September 17, 2022 Report Share Posted September 17, 2022 Pa taj Philips je fantastican transport. Sedi dole 1 ...naravno ako radi. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted September 17, 2022 Author Report Share Posted September 17, 2022 Da,da,sve to za CD614(imam ih dva,jedan za rezervu. Imao sam u isto vreme ovaj CD i California Audio Labs DX-2(svojevremeno 1.100 dem)...poredio ih direktno sa eksternim dacom...razlike necujne mom uhu...Cal otisao na dobos. Quote Link to comment Share on other sites More sharing options...
sondek Posted September 17, 2022 Report Share Posted September 17, 2022 Cdm4 ..odlican 5. Imao sam cd850mk2, pre toga i 614 ..poredio transport sa par CD plejera i odlican je, bolji. Od sadasnjih sklopocija svakako bolji. Cita bukvalno sve, za razliku od Linn kome smeta i suncan dan i podesen je samo za silverdisc. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 17, 2022 Report Share Posted September 17, 2022 Za “mićka” bih gledao (i probao) Chord DAC-ove, nisu jeftini, mogu da se nađu second hand (ne tako lako) i kao što rekoh, i “deda” model CuteHD delje tu kockicu, testirao 1:1. Noviji su za koplje i više bolji (ali i skuplji). CuteHD je negde oko 400-450€, polovan najnoviji model (ako se nađe) je tu oko 1k€, možda malo više. Npr. CuteHD svira tu negde kao DAC u Devialet Expert 200, i to sam poredio 1:1, zato sam ga i prodao (istog dana kada sam ga oglasio). Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted September 17, 2022 Author Report Share Posted September 17, 2022 Hvala,dobro je znati sve navedeno. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 17, 2022 Report Share Posted September 17, 2022 Chord kod nas prodaje @Sonichammer, pa možeš da ga pitaš sve što te zanima, a možda se i javi u temi. Quote Link to comment Share on other sites More sharing options...
sondek Posted September 17, 2022 Report Share Posted September 17, 2022 Ako ti je interesantan, mogu ti doneti kad bude hifiles show moj Linn Numerik da probas, to i jeste bas dac za CD..iako ima dva ulaza ako zatreba jos nesto prikaciti. Cijena je prava sitnica(350eur) za ono sto zvucno nudi. Ja sam svoju CD kolekciju upetostrucio u par godina kad sam njime apgrejdovao svoj Phillips. Nije napadan za usi, tako da bi ti mogao leci uz gramofon kao glavni izvor. Meni su naspram njega vecina dac-ova i narocito CD plejera koje sam uporedio bili agresivni ... ostace para za pola metra ploca 😄 Quote Link to comment Share on other sites More sharing options...
Delija Posted September 17, 2022 Report Share Posted September 17, 2022 3 sati ranije, sondek said: Pa taj Philips je fantastican transport. Sedi dole 1 ...naravno ako radi. Ma da. Mozda pre 20 godina - kada je usao u pubertet Danas vredi cirka 50 evra - ako je savrseno ispravan. Quote Link to comment Share on other sites More sharing options...
sondek Posted September 17, 2022 Report Share Posted September 17, 2022 I kakve veze ima to sa njegovim kvalitetom. Transport radi ili ne radi, valjda je pokretac u to upucen. Ako radi onda je bolji od mnogo toga daleko skupljeg danas... cak i vrlo ozbiljno skupe firme danas ugradjuju krs od transporta. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 17, 2022 Report Share Posted September 17, 2022 Ovde mogu da se složim sa Milanom, DAC-ovi su neslućeno napredovali u odnosu na prve komercijalne sa početka ‘80., ali ono što je tada napravio Philips sa njihovim CDM transportima, do dan danas je neprevaziđeno. Možemo da polemišemo o tome da li je ostatak elektronike i dalje na nivou, ali transport iz tog vremena, sa laserom koji čita kako treba, je i dalje nenadmašan. Upravo slušam jedan takav koji je u Meridianu, guta sve živo, zvuk bolji nego što se čuje kad pustim rip CD-a…u oba slučaja DAC je iz Devialeta. Quote Link to comment Share on other sites More sharing options...
zek Posted September 17, 2022 Report Share Posted September 17, 2022 Ako je samo za CD plejer, onda možda ovako nešto (potražiti po netu šta ljudi misle) https://www.aliexpress.com/item/1005002680056072.html?spm=a2g0o.detail.1000014.11.2d4f6cdfIy4HZJ&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.33416.213724.0&scm_id=1007.33416.213724.0&scm-url=1007.33416.213724.0&pvid=0e385ac6-acce-4805-b565-11c3e10a74a8&_t=gps-id:pcDetailBottomMoreOtherSeller,scm-url:1007.33416.213724.0,pvid:0e385ac6-acce-4805-b565-11c3e10a74a8,tpp_buckets:668%232846%238112%231997&&pdp_ext_f={"sceneId":"23416","sku_id":"12000021682992626"}&compareFields=formatted_price:€ 33,39;itemId:1005002680056072;freight_formatted_price:null;source:recommend-sku;is_freeshipping:null;trade_order:21 Quote Link to comment Share on other sites More sharing options...
sondek Posted September 17, 2022 Report Share Posted September 17, 2022 Dok ih je Philips radio te velike i skupe firme se uopste nisu ni trudile da ista bolje ili drugo stave u svoje skupe modele CD plejera. Zapravo ih je jako malo i razvijalo svoj transport. Da ih Phillips pravi i danas bi ih te nobles firme koristile, stampa to naglasavala u pesnickim opisima i mi bi ih hvalili. Tako da ako radi, samo napred. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted September 17, 2022 Author Report Share Posted September 17, 2022 24 minuta ranije, zek said: Ako je samo za CD plejer, onda možda ovako nešto (potražiti po netu šta ljudi misle) https://www.aliexpress.com/item/1005002680056072.html?spm=a2g0o.detail.1000014.11.2d4f6cdfIy4HZJ&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.33416.213724.0&scm_id=1007.33416.213724.0&scm-url=1007.33416.213724.0&pvid=0e385ac6-acce-4805-b565-11c3e10a74a8&_t=gps-id:pcDetailBottomMoreOtherSeller,scm-url:1007.33416.213724.0,pvid:0e385ac6-acce-4805-b565-11c3e10a74a8,tpp_buckets:668%232846%238112%231997&&pdp_ext_f={"sceneId":"23416","sku_id":"12000021682992626"}&compareFields=formatted_price:€ 33,39;itemId:1005002680056072;freight_formatted_price:null;source:recommend-sku;is_freeshipping:null;trade_order:21 Ja mislio na upgrade ,ne downgrade. Quote Link to comment Share on other sites More sharing options...
zek Posted September 17, 2022 Report Share Posted September 17, 2022 Ne gledaj u cenu, ovde je u pitanju ”stari” čip za koji kažu da mnogo dobro svira (bilo bi naravno bolje da je PCM63). Quote Link to comment Share on other sites More sharing options...
Dragan Penev Posted September 17, 2022 Report Share Posted September 17, 2022 Earmen. Kupiš nov, manje od 1k. Quote Link to comment Share on other sites More sharing options...
