DejanM Posted April 24, 2022 Report Share Posted April 24, 2022 https://hifiplus.com/articles/kuzma-safir-9-tonearm/ Quote Link to comment Share on other sites More sharing options...
Zexx Posted April 24, 2022 Report Share Posted April 24, 2022 60 grama efektivna masa, bokte maz'o... Quote Link to comment Share on other sites More sharing options...
DejanM Posted April 24, 2022 Author Report Share Posted April 24, 2022 I 20.000 cena ... Quote Link to comment Share on other sites More sharing options...
Father Posted April 24, 2022 Report Share Posted April 24, 2022 Ja ne kapiram kako ovo neko može da izjavi i da to prođe? Effective Mass: 60g* * compatible with phono cartridges of CU (compliance) 25 or lower http://www.resfreq.com/resonancecalculator.html Ne kažem da sam u pravu, čak sumnjam da išta razumem. Voleo bih da mi neko objasni. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted April 24, 2022 Report Share Posted April 24, 2022 SME 3009 S2 је око 13.грама, бар је елегантна, обашка што је матора! Quote Link to comment Share on other sites More sharing options...
Father Posted April 24, 2022 Report Share Posted April 24, 2022 Jelco SA-50 na Rotel RP-1500 imao je EffectiveMass 5g i u zbiru sa glavom i šrafovima je ukupna masa bila oko 10.5g - 11g uz CU 25 nova Ortofon Super OM10 sam imao oko 9.7Hz - 10Hz rezonantnu freq. I ovde u nekom malom odnosu utiče VTF na dobijenu vrednost koje merenje konačno pokaže. Quote Link to comment Share on other sites More sharing options...
InSides Posted April 24, 2022 Report Share Posted April 24, 2022 Штета. 20+ сам година био убеђен да је Кузма вођен начелно инжинерским умећем. Очигледно није остао имун на cash grab потенцијале. Quote Link to comment Share on other sites More sharing options...
Nixie Posted April 24, 2022 Report Share Posted April 24, 2022 Tolika efektivna masa i pripadajuća mala kompilijansa, pa to će biti smrt za vinil. Poseća me malo na one trke kamiona. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted April 24, 2022 Report Share Posted April 24, 2022 Izoraće se ploče sa ovom ručkom, samo još da se turi i "adekvatna" glava, da sve bude kako treba.😁 Quote Link to comment Share on other sites More sharing options...
DejanM Posted April 24, 2022 Author Report Share Posted April 24, 2022 Ono sto je za mene novo jeste Kuzmina tvrdnja da je optimalna rezonancija rucke sa zvucnicom izmedju 5 i 7 Hz. Ja sam mislio da ta optimalna vrednost treba da bude izmedju 9 i 11 Hz. Kada se uzme u obzir najbolja Kuzmina zvucnica CAR60 u kombinaciji sa ovom Saphir ruckom, onda se dobije rezonancija od 5,7 Hz - sto se uklapa u ovu Kuzminu tvrdnju. Quote Link to comment Share on other sites More sharing options...
zbrujic Posted April 24, 2022 Report Share Posted April 24, 2022 Ima i objašnjenje: https://www.kuzma.si/media/uploads/files/SAFIR 9 Technical aspects 220409(1).pdf In reality, better turntables now have less bearing and motor noise as well as better support stands and various isolation platforms which eliminate noise in range between 3-8 Hz. Signals created by eccentric grooves on the record and warps are well below 2 Hz. Most best cartridges have lower compliance and therefore are suitable for medium to high efective mass tonearms and if we can keep tonearm resonance above 3 Hz it will do no harm. Quote Link to comment Share on other sites More sharing options...
DejanM Posted April 24, 2022 Author Report Share Posted April 24, 2022 23 minuta ranije, zbrujic said: Ima i objašnjenje: https://www.kuzma.si/media/uploads/files/SAFIR 9 Technical aspects 220409(1).pdf In reality, better turntables now have less bearing and motor noise as well as better support stands and various isolation platforms which eliminate noise in range between 3-8 Hz. Signals created by eccentric grooves on the record and warps are well below 2 Hz. Most best cartridges have lower compliance and therefore are suitable for medium to high efective mass tonearms and if we can keep tonearm resonance above 3 Hz it will do no harm. Hvala na ovom linku. Sada su stvari dosta jasnije .... Quote Link to comment Share on other sites More sharing options...
paja959 Posted April 25, 2022 Report Share Posted April 25, 2022 14 sati ranije, zbrujic said: Ima i objašnjenje: https://www.kuzma.si/media/uploads/files/SAFIR 9 Technical aspects 220409(1).pdf In reality, better turntables now have less bearing and motor noise as well as better support stands and various isolation platforms which eliminate noise in range between 3-8 Hz. Signals created by eccentric grooves on the record and warps are well below 2 Hz. Most best cartridges have lower compliance and therefore are suitable for medium to high efective mass tonearms and if we can keep tonearm resonance above 3 Hz it will do no harm. pa treba prodati i one platforme sto pravi od cca 15000 eura... Quote Link to comment Share on other sites More sharing options...
Delija Posted April 25, 2022 Report Share Posted April 25, 2022 Sta vas muci? Ako umete, napravite vi duplo skuplje pa zaradite duplo preteranije pare. Quote Link to comment Share on other sites More sharing options...
paja959 Posted April 25, 2022 Report Share Posted April 25, 2022 1 sat ranije, Delija said: Sta vas muci? Ako umete, napravite vi duplo skuplje pa zaradite duplo preteranije pare. ma kiselo grozdje malo...proizvodjac koji je do skora sa dve noge stajao cvrsto na zemlji,prikljucuje se onoj "ako ih ne mozes pobediti,pridruzi im se" Quote Link to comment Share on other sites More sharing options...
zbrujic Posted April 25, 2022 Report Share Posted April 25, 2022 30 minutes ago, paja959 said: ...proizvodjac koji je do skora sa dve noge stajao cvrsto na zemlji,prikljucuje se onoj "ako ih ne mozes pobediti,pridruzi im se" Iako me to (na žalost ) nikako ne pogađa, intuitivno mi se ideja vrlo inertne ručke sviđa. Quote Link to comment Share on other sites More sharing options...
paja959 Posted April 25, 2022 Report Share Posted April 25, 2022 36 minuta ranije, zbrujic said: Iako me to (na žalost ) nikako ne pogađa, intuitivno mi se ideja vrlo inertne ručke sviđa. ni mene,al na svu srecu ..ali msm da imas predstavu kako se ta rucka velike efektivne mase moze ponasati na nekoj audiofilskoj ploci od 2LP/ 45 RPM,ako ima samo blagog talsanja u njoj,ili nije dobro centrirana,inercija ce da radi svoj posao...licno nisam odusevljen tom idejom niske rezonantne frekvencije,i dosad je postojao hard core korisnicki klub koji je to preferirao,not my cup of tea... Quote Link to comment Share on other sites More sharing options...
InSides Posted April 25, 2022 Report Share Posted April 25, 2022 3 sati ranije, Delija said: Sta vas muci? Ово: On 24.4.2022. at 16:38, InSides said: 20+ сам година био убеђен да је Кузма вођен начелно инжинерским умећем. Кузмине цене, за досадашње производе, потпуно оправдавам. Посетио сам погон, могу да замислим колики је улог, јасно ми је колики су ресурси потребни за развој и производњу. Али ово задње... Quote Link to comment Share on other sites More sharing options...
Delija Posted April 25, 2022 Report Share Posted April 25, 2022 Nemoj seci drugi deo mog post-a - on je jednako bitan Quote Link to comment Share on other sites More sharing options...
InSides Posted April 25, 2022 Report Share Posted April 25, 2022 Ово? 4 sati ranije, Delija said: Ako umete, napravite vi duplo skuplje pa zaradite duplo preteranije pare. Лоше сам се удао? Quote Link to comment Share on other sites More sharing options...
sondek Posted April 25, 2022 Report Share Posted April 25, 2022 Samo ti svoj gramofon stavi u prodaju (komercijalizuj) i ne brigaj oko udaje. S moje strane bezrezervna podrska Quote Link to comment Share on other sites More sharing options...
DejanM Posted April 26, 2022 Author Report Share Posted April 26, 2022 22 sati ranije, InSides said: Ово: Кузмине цене, за досадашње производе, потпуно оправдавам. Посетио сам погон, могу да замислим колики је улог, јасно ми је колики су ресурси потребни за развој и производњу. Али ово задње... Meni ova Kuzmina rucka deluje kao pokusaj da se napravi nesto ultimativno, nesto sto ce prevazici sve druge pa i samog sebe. Profesionalni izazov, recimo ... Zbilja ne znam da li je bilo neophodno uzeti safir kao materijal (i kako se uopste setio safira ?) ali njegova prica deluje argumentovano. Cena od 20 hiljadarki ... naravno, skupo je ali to je i pravljeno samo za odabranu manjinu. Ne znam kakva je cena safira na trzistu, kao sto ne znam ni sta je sve potrebno da se napravi rucka od safira, ali da je egzoticno - jeste. Sa druge strane, na trzistu postoje gramofoni sa cenom od preko 100.000 USD/EUR ... pa i dosta skupljih. Tako da nece biti usamljen u toj klasi cena ... Quote Link to comment Share on other sites More sharing options...
DejanM Posted April 26, 2022 Author Report Share Posted April 26, 2022 18 sati ranije, sondek said: Samo ti svoj gramofon stavi u prodaju (komercijalizuj) i ne brigaj oko udaje. S moje strane bezrezervna podrska Tada sam propustio da komentarisem InSides-ov gramofon ali mi je slika ostala u glavi. Ne znam kako svira ali izgleda za cistu desetku. Svaka cast ... Quote Link to comment Share on other sites More sharing options...
InSides Posted April 26, 2022 Report Share Posted April 26, 2022 Можда сам сугерирао својим писањем, мада ми то није била намера, али нема уопште проблема са ценом. Када сам рекао да сам разочаран овим приступом, мислио сам на производна решења које је преузео да смањи трошкове, а истовремено умањи употребљивост ручице. Рецимо: Елиминарио VTA торањ, који је изванредно и пројектиран и изграђен, и заменио метричким штрафом и штрафцигером (види овде, а нарочито овде); Израдио цев од сафира (која је сигурно одлична) али оставио његов стандардни (претпостављам и овде алуминиумски) хедшел и тиме смањио предности (ригидност) сафирне цеви. Тиме речено, Kuzma XL / AirLine ми је још увек један од грамофона којих бих купио без размишљања. 20 sati ranije, sondek said: S moje strane bezrezervna podrska 1 sat ranije, DejanM said: Ne znam kako svira ali izgleda za cistu desetku. Svaka cast ... Хвала обојици. Позив на слушање је отворен, само се најавите. Што се тиче комерцијализације, то је практично немогуће. Тај грамофон има судбину да буде вечити прототип, зато што ствари које радим тамо се нико не би усудио урадити у производњи ако жели имати профит. Кад смо на теми ручица, дубоко верујем да су на то поље будућност композити и адитивна производња, а ла Continuum Cobra. Quote Link to comment Share on other sites More sharing options...
DejanM Posted April 27, 2022 Author Report Share Posted April 27, 2022 Continuum sistem sam slusao dosta davno. To stvarno svira izuzetno. Kosta takodje ... puno. Ono sto je mene dotaklo jeste ovo: https://www.vertereacoustics.com/reference-tonearm na Vertere Reference gramofonu. To je zbilja sviralo jako dobro. Ali isto kosta ... ne toliko koliko Continuum sistem ali ... kao i najskuplji Kuzma. Quote Link to comment Share on other sites More sharing options...
