Delija Posted September 23, 2021 Report Share Posted September 23, 2021 42 minuta ranije, Dražo said: Meni odgovara Odlicno! Dogovaramo se odmah posle vikenda - posto za vikend ni @sondek ni ja nismo u NSu. Tu je i dobra rakija, da bar malo opusti ledja Quote Link to comment Share on other sites More sharing options...
Dražo Posted September 23, 2021 Report Share Posted September 23, 2021 Dogovoreno! Ima kod mene tih vatrenih vocnih lekova (samo to valjda i imam) Quote Link to comment Share on other sites More sharing options...
Toza Posted September 23, 2021 Report Share Posted September 23, 2021 20 minuta ranije, Father said: Tek kada savladaš Grand Master nivo otvara ti se nivo Father prvi dan ... Dug put je pred tobom momče! Već imam crni pojas, treći dan nisam pomenuo VBS... Quote Link to comment Share on other sites More sharing options...
Toza Posted September 23, 2021 Report Share Posted September 23, 2021 Šta se dešava sa smajlićima? Koji god da kliknem na telefonu, ili neće da može, ili mi izbaci neki, random. Quote Link to comment Share on other sites More sharing options...
Zexx Posted September 23, 2021 Report Share Posted September 23, 2021 Prsti ogrubeli od pletenja kablova... Quote Link to comment Share on other sites More sharing options...
Toza Posted September 23, 2021 Report Share Posted September 23, 2021 Da. Bas sam ogrubio od siline zaplitanja. Baš! 👍 Quote Link to comment Share on other sites More sharing options...
Toza Posted September 23, 2021 Report Share Posted September 23, 2021 Wau, @Zexx pa ti si forumski kolaborator!!! Oću i ja da budem kolaborator. 😊 Quote Link to comment Share on other sites More sharing options...
Toza Posted September 23, 2021 Report Share Posted September 23, 2021 Auf, ne vidim dobro, ti si iznad toga. Quote Link to comment Share on other sites More sharing options...
Thecoki Posted September 23, 2021 Author Report Share Posted September 23, 2021 Pošto vidim da kolega @Tozakupi bodove moram da ga tagujem radi zajedničkog napretka. Vidim da kolege koje se bave izradom kablova od monokristalne zice (VBS uglavnom) pominju interkonekte,zvucnicke i msm @Dražoda je napravio USB kabel, pitanje je sta se dešava sa LAN kablom ? Da je neko probao da napravi LAN kabel od monokristalne zice? Quote Link to comment Share on other sites More sharing options...
Toza Posted September 23, 2021 Report Share Posted September 23, 2021 Nije probao niko do sad. Ali, ako može usb,onda može i lan. Bilo bi vrlo interesantno čuti, uporediti, slažem se. Quote Link to comment Share on other sites More sharing options...
Aibo Posted September 23, 2021 Report Share Posted September 23, 2021 A danas kod mene... Quote Link to comment Share on other sites More sharing options...
Toza Posted September 23, 2021 Report Share Posted September 23, 2021 Yup!!! Hehe, a upravo dobih informaciju od insajdera da ga praviš. Quote Link to comment Share on other sites More sharing options...
Thecoki Posted September 23, 2021 Author Report Share Posted September 23, 2021 1 hour ago, Aibo said: A danas kod mene... Sjajno! Koje konektore koristiš? Quote Link to comment Share on other sites More sharing options...
Aibo Posted September 23, 2021 Report Share Posted September 23, 2021 Telegartner: https://www.audiophonics.fr/en/rj45-plugs/telegartner-mfp8-t568b-connecteur-rj45-ethernet-highend-metal-p-7165.html Quote Link to comment Share on other sites More sharing options...
Father Posted September 23, 2021 Report Share Posted September 23, 2021 2 sati ranije, Aibo said: A danas kod mene... Interesuju me dve stvari. 1. Koji korak pletenja je uzet kao zajednički za sve četiri parice, jer primećujem da svaka parica sa slike ima različiti korak. Ako je usvojen jedan za sve, tj. ujednačeno su upleteni, da li je meren kao kontrola npr. jednak kapacitet svake parice? 2. Da li je svaka parica obuhvaćena svojom folijskom zaštom (FTP) preko kojih je nakon međusobnog uplitanja konačno išao širm formirajući konačnu S/FTP konstrukciju? Quote Link to comment Share on other sites More sharing options...
lalelala Posted September 23, 2021 Report Share Posted September 23, 2021 14 hours ago, Toza said: Ajde da lanem koju pa da krenemo... Zanimljivo je da se monokristalni bakar, nebitno od proizvođača, ne ponaša zvučno isto kao i obični bakar pri konstrukciji kablova. Interesantno je zbog toga što ne može samo da se iskopira geometrija i da se dobije vr' rezultat. Odnosno, ako imamo dobro zvučeći i fino balansiran recimo zvučnički kabel od običnog bakra, isti takav, iste geometrije, presjeka itd monokristalni, uopšte neće zvučati tako balansirano. U nekim segmentima će biti bolji, ali u nekima baš i neće. Ne bih se složio u potpunosti sa ovom konstatacijom. Da te podsetim, probali smo zajedno istu geometriju zvučničkog kabela sa običnim bakrom u silikonu i monokristalnim žicama u teflonu i razlika je bila dramatična u korist monikristalnog provodnika, ali što reče @Father ima nešto i do tog teflona . . . Quote Link to comment Share on other sites More sharing options...
Aibo Posted September 23, 2021 Report Share Posted September 23, 2021 Interesuju me dve stvari. 1. Koji korak pletenja je uzet kao zajednički za sve četiri parice, jer primećujem da svaka parica sa slike ima različiti korak. Ako je usvojen jedan za sve, tj. ujednačeno su upleteni, da li je meren kao kontrola npr. jednak kapacitet svake parice? 2. Da li je svaka parica obuhvaćena svojom folijskom zaštom (FTP) preko kojih je nakon međusobnog uplitanja konačno išao širm formirajući konačnu S/FTP konstrukciju?1. Nema zajedničkog, što je i poenta. Počevši od najmanje uvrnute, svaka sledeća je otprilike 30ak posto gušće motana... Da se nigde ne gađaju paralelno.2. Svaka parica je u svojoj foliji... A na kraju sve skupa u širmu. Planiram da ih spojim samo na krajevima i drejnujem sve samo na strani izvora (switch ima uzemljenje). Quote Link to comment Share on other sites More sharing options...
Toza Posted September 24, 2021 Report Share Posted September 24, 2021 5 sati ranije, lalelala said: Ne bih se složio u potpunosti sa ovom konstatacijom. Da te podsetim, probali smo zajedno istu geometriju zvučničkog kabela sa običnim bakrom u silikonu i monokristalnim žicama u teflonu i razlika je bila dramatična u korist monikristalnog provodnika, ali što reče @Father ima nešto i do tog teflona . . . Pričamo o balansu. Ostalo je nesporno. Napredak je toliki da je jednostavno potrebno neko vrijeme da se čovjek opasulji, uši naviknu pa da se tek onda čuje zaista šta je po srijedi. Može @Dražo da potvrdi sa svojom prvom fascinacijom. Ustvari, može da potvrdi ko god je probao sa svojom prvom fascinacijom tog zvuka. Quote Link to comment Share on other sites More sharing options...
ab Posted September 24, 2021 Report Share Posted September 24, 2021 5 sati ranije, Aibo said: 1. Nema zajedničkog, što je i poenta. Počevši od najmanje uvrnute, svaka sledeća je otprilike 30ak posto gušće motana... Da se nigde ne gađaju paralelno. 2. Svaka parica je u svojoj foliji... A na kraju sve skupa u širmu. Planiram da ih spojim samo na krajevima i drejnujem sve samo na strani izvora (switch ima uzemljenje). Мора да буде уједначен ход парица, ни превише затегнут ни опуштен, иначе неће ваљати Quote Link to comment Share on other sites More sharing options...
laky Posted September 24, 2021 Report Share Posted September 24, 2021 10 sati ranije, Aibo said: A danas kod mene... Gde ima da se kupi bakarni sirm. Quote Link to comment Share on other sites More sharing options...
Toza Posted September 24, 2021 Report Share Posted September 24, 2021 Joj Laky, najbolja i najeftinija varijanta je da ga izvadiš iz nekog rg kabela, 50 tak din po metru. Ako bi kupovao širm posebno, em je muka da se pronađe, a da se ne dobavlja iz inostranstva, em je skup kao otrov. Quote Link to comment Share on other sites More sharing options...
laky Posted September 24, 2021 Report Share Posted September 24, 2021 hvala ali tesko je naci taj stari rg ove sto sam gledao imaju kako da nazovem polu alu sirm samo malo uvrnuto okolo. Quote Link to comment Share on other sites More sharing options...
Toza Posted September 24, 2021 Report Share Posted September 24, 2021 U pravu si. Teško ga je naći ali opet lakše nego samo širm. Quote Link to comment Share on other sites More sharing options...
Father Posted September 24, 2021 Report Share Posted September 24, 2021 1 sat ranije, ab said: Мора да буде уједначен ход парица, ни превише затегнут ни опуштен, иначе неће ваљати @Aibo Sa ovim se potpuno slažem, zato sam i postavio pitanje, jer mi se učinilo da je postojala namera da ne budu identičnog hoda. Ono Lan kablova što sam ja "oderavao" su imali identičan hod uvrtanja parica, da kažem po nekom standardu. To što su svaka u svojoj foliji je da se spreči isijavanje signala iz jedne u drugu i smanje menđusobne smetnje, kao i spoljašnje. Sećate se ranijih analognih telefona i kada se mogao čuti razgovor komšije ili da vam čak probije signal od komšije i pozvoni vaš telefon ... Zato su kasnija rešenja predviđala ili udaljavanje svake parice telefonskog korisnika ili uvođenje odvojenih parica folijom. Da ne kažem da je to dovelo i do čistijeg signala i ne postojanja preslušavanja između susednih parica. Nije me nikada interesovalo kako koja parica (Lan kabla) provodi i šta provodi, ali sam stekao utisak da se kod fabričkih kablova vodi računa o jedinstvenosti parametara svih parica. Ovde mislim na debljinu, dužinu i korak uvrtanja da bi se osigurali identični RLC parametri. Kvalitetnija izrada kabla je tu ujednačenost i na većim dužinama stremila da održi. Možda grešim, ali verujem da je ključ idealne propagacije Ethernet signala u stabilnosti i ujednačenim karakteristikama sve 4 parice. Ovde i dalje govorimo o konstrukciji i izolacijama. Kvalitet više donosi i provodnički materijal koji je iz mog ugla dospeo u prvi plan istiskujući suštinu fizičkih pojava koje se podržavaju dobrom ili kvare lošom konstrukcijom zajedno sa dielektrikom boljih ili lošijih karakteristika. Ako taj konektor dozvoljava naknadno otvaranje nakon terminacije, ti probaj kako i da li uopšte radi tako koncipiran Lan kabl. Možda si na tragu nečega, ali evo i ja po prvi put da izrazim sumnju u neku dajersku ideju. Podržavam rad i istraživanje ali mislim da je sinhronizacija sve 4 parice krucijalna za stabilnost ethernet veze. Quote Link to comment Share on other sites More sharing options...
somilenko Posted September 24, 2021 Report Share Posted September 24, 2021 Standardi za mrežne kablove postoje zbog garantovane propusne moći do određene dužine kabla i to izgleda ovako Sve je to za 100 m (propusna moć se povećava sa smanjenjem dužine) a @Aibo pravi možda 1 m dužine, tako da ne verujem da će imati toliko problema. Kod 100 Mbps (koji je dovoljan za stream muzike) se koristi samo 2 parice a ovde je veća poenta ukloniti smetnje i šum nego obezbediti 10 Gbps jer ta brzina nije potrebna za audio. Da rezimiram, mislim da je prerano prognozirati probleme, pogotovo na tako kratkom kablu i sumnjam da će ih biti, neka Aibo proba pa da nam javi utiske... Quote Link to comment Share on other sites More sharing options...
