Milan992 Posted September 7, 2021 Report Share Posted September 7, 2021 Misljenje i iskustva? Quote Link to comment Share on other sites More sharing options...
Nixie Posted September 7, 2021 Report Share Posted September 7, 2021 Imaš tri ista posta. 40Hz-100Hz +-3db, velika snaga, očigledno profi sprava za ozvučenje. Potreban mu je subsonic filter na 35Hz, minimum 2 reda. Pretpostavljam da je dobar za to zašta je namenjen. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 7, 2021 Report Share Posted September 7, 2021 1 sat ranije, Milan992 said: Misljenje i iskustva? Сам звучник или комплетна кутија? Quote Link to comment Share on other sites More sharing options...
nkrgovic Posted September 7, 2021 Report Share Posted September 7, 2021 Obrisao 2 teme viska Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 7, 2021 Report Share Posted September 7, 2021 Obrisao 2 teme viskaХоћеш рећи исте? Послато са Redmi 4 помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
Milan992 Posted September 7, 2021 Author Report Share Posted September 7, 2021 Pozz,slucajno sam otvorio 3 iste teme,izvinjavam se. Kupio sam ceo sistem eliminator,znaci 4 sub-a 18 i 4 satelita 15,sve originalno. Desava se to da nisam baš zadovoljan sa sabovima,trebao bi da bude nekako jaci,tu kada stojis kod njega oni izuvaju ali na 5 metara se doslovno necuju. Kupio sam 2 snagasa behringer 6000 sa dsp,jedan snagas je za sabove a drugi za satelite,sve lepo podesim,sabovima dajem cist bass sateliti full range samo skinem niske hz. Pojacala su 2x3000w na 4ohm,tako i povezujem na 4ohm Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 7, 2021 Report Share Posted September 7, 2021 1 sat ranije, Milan992 said: Pojacala su 2x3000w na 4ohm,tako i povezujem na 4ohm Докле иду пик метри и колику су појачани канали на снагашу за субове? Quote Link to comment Share on other sites More sharing options...
Milan992 Posted September 7, 2021 Author Report Share Posted September 7, 2021 Pa stimam do crvene lampe,snagas za bin bude do kraja pojacan,a satelite smanjim jer su ipak 15" i onda sve to kontrolisem mixetom,imam vise mixeta i aktivnih i pasivnih. Quote Link to comment Share on other sites More sharing options...
Milan992 Posted September 7, 2021 Author Report Share Posted September 7, 2021 Sabovi imaju zavojnice u sebi,probao sam da njih iskljucim i spojim na direkt sa pojacalom,jel na njemu odrezem hz i gotovo da nema neke razlike,i da napomenem nemam problem sa jednom kutijom nego sa sve 4. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 7, 2021 Report Share Posted September 7, 2021 А да провериш ти каблове од снагаша до сабова, јел идеш из кутије у кутију по страни? Quote Link to comment Share on other sites More sharing options...
Milan992 Posted September 7, 2021 Author Report Share Posted September 7, 2021 Da,idem iz kutije u kutiju i tako skidam na 4 ohm i tako drugu stranu,po strani ih teram sa 3000w na 2 bina a kablovi su 2x4mm imam kablove i od 5m,10m,15m i 20m imam 200 metara kablova ukupno. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 7, 2021 Report Share Posted September 7, 2021 Предпостављам да су спикони на крејевима каблова. Провери поларитете тј. да ли је на оба краја кабла иста жица на на истом контакту. Нема много четири кабла 2+2.. Quote Link to comment Share on other sites More sharing options...
Milan992 Posted September 7, 2021 Author Report Share Posted September 7, 2021 Sve je to provereno,kada se promene polovi izgubi se zvuk odmah,sve sam proverio,ovim se bavim 10 godina,imam vise sistema ali ovo mi nije jasno uopste. Prve kutije sam kupio za kucu jbl tr225 i onda sam skontao da nisu za kucu i poceo da iznajmljujem i tako malo po malo imam 5 paleta kutija. Onda sam kupio za te TR225 4 sub turbosound 15 i to lepo radi,ovaj sistem sam kupio zbog prosirenja posla,radim rentu svadbe punoletsva i ostalo,jer ovo mi se ucinilo zgodno jer gde ima manje ljudi tipa 30 40 gostiju,odnesem jedan stub,jedan sub i jedan satelit i radi posao a lepo izgleda pri tome. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 7, 2021 Report Share Posted September 7, 2021 Јел су субови са једним или два звучника? Има верзија Елиминатора "KW" који има два звучника у кутији. Quote Link to comment Share on other sites More sharing options...
Milan992 Posted September 7, 2021 Author Report Share Posted September 7, 2021 A inace volim taj svet ozvucenja i muzike i uzivam u tome,sa jbl sam prezadovoljan,kupio sam skoro i aktivne jbl 315 i one kidaju kako rade,u EV satelite sam ubacio jbl 2226 i ti sateliti kidaju kako rade. Quote Link to comment Share on other sites More sharing options...
Milan992 Posted September 7, 2021 Author Report Share Posted September 7, 2021 Jedna 18 po kutiji. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 7, 2021 Report Share Posted September 7, 2021 Да у моменту сам схватио да је по једна 18ца по кутији. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 7, 2021 Report Share Posted September 7, 2021 3 minuta ranije, Milan992 said: Баш лепо за видети бивши Динакорд, мислим на Q66 Quote Link to comment Share on other sites More sharing options...
Milan992 Posted September 7, 2021 Author Report Share Posted September 7, 2021 Pa da,ali jednostavno nmg da skontam sta se tu desava,jer sve je ispravno i ocuvano,snagasi jaki sa filterom zvuka digitalnim,debeli kablovi 4mm presek znaci nzm gde dalje. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 7, 2021 Report Share Posted September 7, 2021 7 minuta ranije, Milan992 said: sateliti kidaju kako rade. Ма пусти кидање , Ја бих то све лепо проверио. Значи ожичење у кутијама + саме звучнике, поготову поларитет. Quote Link to comment Share on other sites More sharing options...
Milan992 Posted September 7, 2021 Author Report Share Posted September 7, 2021 Pa da,ali jednostavno nmg da skontam sta se tu desava,jer sve je ispravno i ocuvano,snagasi jaki sa filterom zvuka digitalnim,debeli kablovi 4mm presek znaci nzm gde dalje. Koristim pojacala samo ona koja su D klase zbog potronje,jer skoro gde god radim imam problem sa naponom,imam i korektor od 2,5kw idem prekp njega. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 7, 2021 Report Share Posted September 7, 2021 2 minuta ranije, Milan992 said: Pa da,ali jednostavno nmg da skontam sta se tu desava,jer sve je ispravno i ocuvano,snagasi jaki sa filterom zvuka digitalnim,debeli kablovi 4mm presek znaci nzm gde dalje. 'си из престонице? Quote Link to comment Share on other sites More sharing options...
Milan992 Posted September 7, 2021 Author Report Share Posted September 7, 2021 Čurug Quote Link to comment Share on other sites More sharing options...
Milan992 Posted September 7, 2021 Author Report Share Posted September 7, 2021 Hoces na kafu da naletis? To je svega 45min ili 100km Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 7, 2021 Report Share Posted September 7, 2021 2 minuta ranije, Milan992 said: Čurug Ух, ко ће до Жабља да се котрља... Quote Link to comment Share on other sites More sharing options...
