dragec Posted August 26, 2021 Report Share Posted August 26, 2021 Pozdrav! Treba mi DAC, jeftiniji, tipa do 150 EUR. Optika samo iz TV-a u pojacalo, dakle obrada zvuka za Youtube i HBO GO, serije, filmovi itd. Trenutno koristim Fiio D3, iskreno za te pare radi super ali bih uzeo nesto malo bolje. Dvoumim se izmedju Topping D10s i FX-Audio SQ5. Imate li jos neki predlog i sta je bolje od ovda dva? Quote Link to comment Share on other sites More sharing options...
zek Posted August 26, 2021 Report Share Posted August 26, 2021 1 sat ranije, dragec said: Topping D10s Ima samo USB ulaz, ne može da se priključi TV. Quote Link to comment Share on other sites More sharing options...
ivanp Posted August 26, 2021 Report Share Posted August 26, 2021 Nemoj da trošiš pare...................... Quote Link to comment Share on other sites More sharing options...
Zexx Posted August 26, 2021 Report Share Posted August 26, 2021 Gde je 150e tu je i 170...😉 https://novi.kupujemprodajem.com/audio/d-a-konvertori/topping-e30-hi-res-hifi-usb-dac/oglas/120972954 Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted August 26, 2021 Report Share Posted August 26, 2021 Lep dakić. Quote Link to comment Share on other sites More sharing options...
ab Posted August 26, 2021 Report Share Posted August 26, 2021 И немузикалан тотално Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted August 26, 2021 Report Share Posted August 26, 2021 Za filmove mu bolji ne treba. Quote Link to comment Share on other sites More sharing options...
ab Posted August 26, 2021 Report Share Posted August 26, 2021 Онда може било који Quote Link to comment Share on other sites More sharing options...
Zexx Posted August 26, 2021 Report Share Posted August 26, 2021 Već ima bilo koji...😉 Quote Link to comment Share on other sites More sharing options...
patason Posted August 26, 2021 Report Share Posted August 26, 2021 1 sat ranije, ab said: И немузикалан тотално Ali filmican Quote Link to comment Share on other sites More sharing options...
dragec Posted August 26, 2021 Author Report Share Posted August 26, 2021 1 sat ranije, ab said: И немузикалан тотално Stvarno? Jel si ga slušao, kako bi opisao zvuk? Quote Link to comment Share on other sites More sharing options...
ab Posted August 26, 2021 Report Share Posted August 26, 2021 Па, описао сам га већ. Слушао и није мој избор. Ако се некоме свиђа, његов избор. Quote Link to comment Share on other sites More sharing options...
dragec Posted August 26, 2021 Author Report Share Posted August 26, 2021 Ok, hvala, a sta je sa ovim kanadskim FX, ima li to iko, kakav je, da li neko zna? Quote Link to comment Share on other sites More sharing options...
Aibo Posted August 26, 2021 Report Share Posted August 26, 2021 FX-Audio je čisto kineski, taj što na oglasu lupa "kanadski" a video sam da neko kod nas to uporno piše... Nemam pojma odakle je izvukao.Inače OK uređaji sasvim.Moja preporuka ide za SMSL Sanskrit 10th MKII... Imaš ga za 130€... Za te novce mu se stvarno nema šta zameriti. Meni je čak legao nešto lepše od Topping E30 jer je muzikalniji. [mention=30057]ab[/mention] Ako se dobro sećam, E30 smo beše kod mene slušali. Nemoj da budeš toliko strog prema njemu... Išao je posle M2Tech kockica i Schiit Multibita... Bio je pripremljen teren da razočara. Kad se poredi sa drugim uređajima tu do 200€, sasvim je OK. Malo suvlji ali ima i kvaliteta, verovatno najviše detalja i vazduha ima od svih DACića te cene. Quote Link to comment Share on other sites More sharing options...
ab Posted August 26, 2021 Report Share Posted August 26, 2021 Управу си али ипак Schiit м.је појам музикалности за њега. Вероватно се мени није свидео, што не значи да ће се неком другом можда баш свиди. Quote Link to comment Share on other sites More sharing options...
dragec Posted August 26, 2021 Author Report Share Posted August 26, 2021 Ok, prelomio sam, poslusacu kolegu Aibo, kupicu SMSL za 130 evra pa javljam utiske. Pogledao sam par review-a na brzinu, koliko vidim za te novce mu nista ne zameraju. Mislim da ce biti predbar za ono sto meni treba. Citava prica se svodi na to da sam prodao Yamahu RN602 network risiver koji je imao dac u sebi i vratio pojacalo AX596, cd 560 i tjuner (srecom nisam prodao taj komplet). To mi zvuci duplo bolje od risivera, tako da mi sad fali samo malo bolji dac. Hvala svima na savetima! Quote Link to comment Share on other sites More sharing options...
gnu Posted August 26, 2021 Report Share Posted August 26, 2021 Smsl sanskrit 10th MKII je sasvim odličan dac, imam ga. Quote Link to comment Share on other sites More sharing options...
