ab Posted June 8, 2021 Report Share Posted June 8, 2021 Потребна ми је помоћ, како правилно терминисати обележени пин на фотографији (имам идеју али да питам и не скитам): у питању је шасијски конектор. хвала Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted June 8, 2021 Report Share Posted June 8, 2021 Lemljenjem. Quote Link to comment Share on other sites More sharing options...
gvlada Posted June 8, 2021 Report Share Posted June 8, 2021 Евентуално супер лепком хехе Quote Link to comment Share on other sites More sharing options...
ab Posted June 8, 2021 Author Report Share Posted June 8, 2021 Хвала све у складу са почетничким питањима Quote Link to comment Share on other sites More sharing options...
Father Posted June 8, 2021 Report Share Posted June 8, 2021 Poveži ga sa pinom 1 za shield. Quote Link to comment Share on other sites More sharing options...
ab Posted June 8, 2021 Author Report Share Posted June 8, 2021 Ено @Nixieми објаснио на другом форуму. хвала Quote Link to comment Share on other sites More sharing options...
Father Posted June 8, 2021 Report Share Posted June 8, 2021 Nixie je drugarčina! Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted June 8, 2021 Report Share Posted June 8, 2021 39 minuta ranije, Father said: Nixie je drugarčina! Quote Link to comment Share on other sites More sharing options...
Nixie Posted June 8, 2021 Report Share Posted June 8, 2021 Nisu teška pitanja. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted June 8, 2021 Report Share Posted June 8, 2021 Kad znaš ništa nije teško, treba samo biti čovek pa to podeliti sa drugima. Quote Link to comment Share on other sites More sharing options...
Father Posted June 8, 2021 Report Share Posted June 8, 2021 16 minuta ranije, Nixie said: Nisu teška pitanja. Quote Link to comment Share on other sites More sharing options...
ab Posted June 8, 2021 Author Report Share Posted June 8, 2021 Ево @Nixie-евог појашњења ако затреба неком: "Ako montiraš XLR na metalnu kutiju i imaš dobar kontakt sa kutijom, ne treba ga povezivati nikako, već je povezan. Proveri ommetrom nakon montaže da li je taj pin na šasiji, to je metalno kućište konektora. Ako montiraš na neprovodnu kutiju taj pin ide na GND zajedno sa Pin1 ali odvojenim žicama. Pin1 problem takođe postoji (Pin2 je plus izlaz, Pin 3 minus izlaz). Pravilno je da se taj pin veže na šasiju, ali može i na signal GND, dosta zavisi od toga kako je vezan na sledećam uređaju. U principu ako nema bruma ili smetnji može i jedno i drugo. Ja sam ga vezivao u DDDAC na signal GND koji je indirektno uzemljen na šasiju (grec+C+R) i kod mene i kod Wolanda, i nema problema za sada (brum, zujanje i slično). Ako ima problema odlemi se žica do Pin1 sa signal GND (jedna strana greca) i zalemi na šasijski GND (druga strana greca). Na šasiju je vezan i srednji pin IEC konektora ali ne na istom mestu već tamo daleko kod samog IEC. Pin1 treba da povezuje dve šasije i tu može biti problema sa ground loop, pa na profi opremi često postoji ground lift prekidač. Ako se balansirani signal nekim adapterom pretvara u SE (XLR to RCA kabal recimo), po pravilu se Pin3 (minus izlaz) vezuje za Pin 1. Zato sam vezao Pin1 na signal GND sa mogućnošću da se lako preveže i na šasiju ako zatreba." Quote Link to comment Share on other sites More sharing options...
