milan-hk Posted April 30, 2021 Report Share Posted April 30, 2021 imam oehlbach USB A/B kabel od 5m ali zbog novonastale situacije i razmestaja mi je kratak. da li neko zna gde bi mogao da kupim taj kabel za dac od 10m? ili da kupim samo usb kabel sa usb a muski i usb a zenski pa da ga nastavim. da li je pametno nastavljati tako kabel i koliko bi moglo uticati na kvalitet Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted April 30, 2021 Report Share Posted April 30, 2021 FTA i Kanibal mogu napraviti kablove na željenu dužinu. Quote Link to comment Share on other sites More sharing options...
zoranzu Posted April 30, 2021 Report Share Posted April 30, 2021 20 minuta ranije, Willi Studer said: FTA i Kanibal mogu napraviti kablove na željenu dužinu. Samo Kanibal Napomena: odredjeni uredjaji ne mogu ostvariti protok signala na vecoj duzini od 5m bez extendera (pojacivaca) Quote Link to comment Share on other sites More sharing options...
Spachek Posted April 30, 2021 Report Share Posted April 30, 2021 Upravo to, kod mene je bio taj slucajSent from my SM-A530F using Tapatalk Quote Link to comment Share on other sites More sharing options...
milan-hk Posted April 30, 2021 Author Report Share Posted April 30, 2021 planski je da u neko skorije vreme kupim neki mrezni uredjaj. do tada ovo bi mi bilo neko resenje. ako ne pije vode sa tolikim kablom jbg izdrzacu dok ne stigne mrezni. moze li neki kontakt od momka za kablove da vidim sta kaze i predlaze kao resenje Quote Link to comment Share on other sites More sharing options...
Delija Posted April 30, 2021 Report Share Posted April 30, 2021 Kanibal nije momak http://www.kanibal.co.rs/ Quote Link to comment Share on other sites More sharing options...
milan-hk Posted April 30, 2021 Author Report Share Posted April 30, 2021 iskren da budem mislio sam da je neko od clanova na forumu Quote Link to comment Share on other sites More sharing options...
Iron man Posted April 30, 2021 Report Share Posted April 30, 2021 USB 2.0 po specifikacijama dobacuje 5m. Razmisliti o nekom ekstenderu. Preporučujem optički Quote Link to comment Share on other sites More sharing options...
Zexx Posted May 1, 2021 Report Share Posted May 1, 2021 Ovo je jednostavno i elegantno rešenje, koristi STP (Shielded Twisted Pair) kabl i nije potrebno nikakvo napajanje: http://www.netiks.rs/usb-extender-ckl-50u Quote Link to comment Share on other sites More sharing options...
milan-hk Posted May 2, 2021 Author Report Share Posted May 2, 2021 On 5/1/2021 at 7:08 AM, Zexx said: Ovo je jednostavno i elegantno rešenje, koristi STP (Shielded Twisted Pair) kabl i nije potrebno nikakvo napajanje: http://www.netiks.rs/usb-extender-ckl-50u cini se kao dobro resenje naruucio sam. nadam se da stize do kraja nedelje pa ce mo videti kako ce se pokazati Quote Link to comment Share on other sites More sharing options...
milan-hk Posted May 7, 2021 Author Report Share Posted May 7, 2021 mrka kapa... kad spojim sve na ekstender prepozna dac na kompu ali i ne daje nikakav zvuk. a kad spojim na laptop isto napise sta je spojeno kad ukljucim usb i to je to ni u opcijama nemam mogucnost da izaberem dac, a kad spojim direktno na kabem na laptop odma radi odma se prepaci na dac i sve radi. mozda nije raspored zica dobar na mreznom kabelu. ja sam stavio standardan mrezni kabel. da li gresim? Quote Link to comment Share on other sites More sharing options...
Zexx Posted May 7, 2021 Report Share Posted May 7, 2021 Napisah STP kabl, znači širmovan, ne može običan UTP na tu dužinu. Quote Link to comment Share on other sites More sharing options...
milan-hk Posted May 7, 2021 Author Report Share Posted May 7, 2021 ovo sam imao. kontao sam da ce raditi i ako nema plast. kupicu sutra. a da li je raspored zica standardan ili je crossover ili koji vec Quote Link to comment Share on other sites More sharing options...
milan-hk Posted May 8, 2021 Author Report Share Posted May 8, 2021 bio u schrack-u uzeo kabl i konektore cat6 stp. sve spojim, nista. napravim crossover opet nista. probam kabl na tester dobro je napravljen. e sad verujem da je do extenrera. nasao sam upustsvo i pise da je on 1.1 i da uredjaji koji su usb2.0 moraju biti kompatibilni sa 1.1 inace nece raditi. tako da mislim da je to problem. jbg Quote Link to comment Share on other sites More sharing options...
Zexx Posted May 9, 2021 Report Share Posted May 9, 2021 Verujem da je to problem, na linku koji sam ti poslao pogrešno je navedeno da su podržani i USB 2.0 uređaji, dok se na sajtu proizvođača pominje samo USB 1.1. Ja sam isti ovakav ekstender koristio za neki stomatološki uređaj i to radi i dan-danas besprekorno, mada ne bih smeo da stavim ruku u vatru da taj uređaj uopšte ima USB 2.0 s obzirom na godinu proizvodnje. Šta da ti kažem osim izvini, nemam običaj da preporučujem bilo kome nešto što nisam koristio ili barem probao, pa predlažem da pokušaš da im vratiš ekstender s obzirom da je specifikacija proizvoda pogrešna ili u najmanju ruku neprecizna. Quote Link to comment Share on other sites More sharing options...
milan-hk Posted May 9, 2021 Author Report Share Posted May 9, 2021 ma ne krivim ja nikog. i da sam ovako nasao isti procitao bi na sajtu isto. poslao sam im mail. pa se nadam da ce mo zameniti za neki drugi extender koji je 2.0. vidim da imaju neki USB 2.0 aktivni produzni kabl. videcemo sta ce odgovoriti. Quote Link to comment Share on other sites More sharing options...
