fuyshe Posted December 6, 2020 Report Share Posted December 6, 2020 Zdravo. Jedan tviter je oslabio, to im je valjda neka serijska greska. Da li se tu moze nesto popraviti ili da trazim zamjenu? Kupio bih ako neko prodaje ovaj tviter (to je onaj s tri rebra). Hvala Srdja Quote Link to comment Share on other sites More sharing options...
sondek Posted December 6, 2020 Report Share Posted December 6, 2020 Najbolje uposli www.hifishark.com da ti ih lovi.Ima ih samo medju prodatima,znaci povremeno se pojave.Mozes da pitas neke Uk dilere polovnjaka tipa tomtomaudio ili probas na Pfm forumu pitati,pre ce odatle da neki uleti.Vreme radi svoje Quote Link to comment Share on other sites More sharing options...
sondek Posted December 6, 2020 Report Share Posted December 6, 2020 Probaj samo prvo da ih zarotiras da utvrdis da li je uopste do tvitera Quote Link to comment Share on other sites More sharing options...
fuyshe Posted December 7, 2020 Author Report Share Posted December 7, 2020 Hvala na pomoci. Quote Link to comment Share on other sites More sharing options...
Father Posted December 7, 2020 Report Share Posted December 7, 2020 12 sati ranije, fuyshe said: Da li se tu moze nesto popraviti ili da trazim zamjenu? Nisam našao info da li taj visokotonac poseduje ferofluid u procepu. Jedan od razloga stišanog rada visokotonaca može da bude njegovo zgušnjavanje vremenom i gubitak željenog viskoziteta koje se lako, brzo i jeftino servisira/obnavlja. Quote Link to comment Share on other sites More sharing options...
fuyshe Posted December 7, 2020 Author Report Share Posted December 7, 2020 Hvala. Vidjecu da probam nesto. Neko pominje neko namotavanje....nisam strucnjak... Quote Link to comment Share on other sites More sharing options...
Father Posted December 7, 2020 Report Share Posted December 7, 2020 Ako je do ferofluida. Visokotonac je ispravan, ali ga zgusnuti/osušeni ferofluid koči u radu pa radi tiše. Ne treba ništa da se premotava. Čak i kada visokotonac ne proizvodi zvuk, može biti prekid od kontaktne pločice do spulne i nije uvek najgori scenario da su pregoreli namotaji na spulni. Svakako se, u slučaju ferofluida, rasklapa i otvara ceo visokotonac, ali se samo čisti procep u magnetu od starog ferofluida i sipa novi ili se stari samo razredi. Jednostavan rad. Za tim se sklapa, centrira i steže na idealno centriranoj poziciji. Ništa skupo niti komplikovano. Visokotonac može i bez njega da radi. Quote Link to comment Share on other sites More sharing options...
fuyshe Posted December 8, 2020 Author Report Share Posted December 8, 2020 Hvala za savjete. Quote Link to comment Share on other sites More sharing options...
zeljko1974 Posted December 8, 2020 Report Share Posted December 8, 2020 Slobodno uguglajte Kef 104.2, ferofluid repair, pa cisto da vidite kako izgleda reparacija ferofluida. Just a sample, nothin else !!!! Quote Link to comment Share on other sites More sharing options...
fuyshe Posted December 9, 2020 Author Report Share Posted December 9, 2020 Evo nekih novosti: ovaj tviter sto je tisi je zapravo model 015/5. To sam vidio kad sam otvorio kutije. Ovaj sto se dobro cuje je 015/3. Quote Link to comment Share on other sites More sharing options...
Nixie Posted December 9, 2020 Report Share Posted December 9, 2020 Kaže ovako na jednom forumu: the difference between the 015/3 and 015/5 is the finish on the face plate Onda su to isti visokotonci koji se vizuelno razlikuju. U svakom slučaju, najverovatnije će biti sve u redu kad se zameni ferofluid na oba visokotonca. Ommetrom ih premeri svakako, treba da budu približno isti. Quote Link to comment Share on other sites More sharing options...
sondek Posted December 10, 2020 Report Share Posted December 10, 2020 Ljudi,zasto proverene informacije sa foruma.Ziva firma,postoji helpline.Pozovete i pripremite se na malo Škotskog dijalekta ili posaljete mail,usput pitate imaju li visokotonaca na lageru.Jest im to zadnja briga,al sam dobio par puta odgovore i pomoc i za 30g staru stvar.Cak i par sitnica gratis.Posaljete samo pri upitu serijski broj. Quote Link to comment Share on other sites More sharing options...
fuyshe Posted December 10, 2020 Author Report Share Posted December 10, 2020 15 hours ago, sondek said: Ljudi,zasto proverene informacije sa foruma.Ziva firma,postoji helpline.Pozovete i pripremite se na malo Škotskog dijalekta ili posaljete mail,usput pitate imaju li visokotonaca na lageru.Jest im to zadnja briga,al sam dobio par puta odgovore i pomoc i za 30g staru stvar.Cak i par sitnica gratis.Posaljete samo pri upitu serijski broj. Pa to je vec uradjeno u startu. Savjetovali su da ih zamijenim i to drugim proizvodjacem. Ne bih kopao po forumima bezveze. Quote Link to comment Share on other sites More sharing options...
sondek Posted December 10, 2020 Report Share Posted December 10, 2020 Odlicno.Nisi napisao da si ih kontaktirao. Predpostavljam da su te uputili na Hiquphon koji ih je snabdevao tviterima, pravili su neke zamenske koji su pasovali dimenzijama i karakteristikama na stare linn zvucnike. Quote Link to comment Share on other sites More sharing options...
sondek Posted December 10, 2020 Report Share Posted December 10, 2020 Imas ovde jedan tviter,covek ga je ponudio pa uz mal srece mozda nije otisao https://pinkfishmedia.net/forum/threads/linn-038-1-2-or-hiquaphon-ow1-92.249115/ Quote Link to comment Share on other sites More sharing options...
fuyshe Posted December 11, 2020 Author Report Share Posted December 11, 2020 19 hours ago, sondek said: Odlicno.Nisi napisao da si ih kontaktirao. Predpostavljam da su te uputili na Hiquphon koji ih je snabdevao tviterima, pravili su neke zamenske koji su pasovali dimenzijama i karakteristikama na stare linn zvucnike. Jeste Sondek, u pravu si. Huiquphon su mi skupi sad pa gledam ove 015 ili 038. Ocigledno Linn nisu imali srece ni pameti s ovim tviterima, sto mi je cudno. Hvala za link! Ja i dalje trazim po netu ove originalne ali sve ide ka tome da cu u buducnosti da uzmem ove danske u paru, kostaju 300e par. Inace, Linn podrska nisu puno pricljivi, nesto ih puno ne zanimaju price o popravci i sl, samo upucuju na Hiquphon. Quote Link to comment Share on other sites More sharing options...
patason Posted December 11, 2020 Report Share Posted December 11, 2020 Sinevoice servis u Zemunu. Odnesi ta dva drajvera i bice ti to sredjeno mnogo povoljnije a bice kao fabricki. Quote Link to comment Share on other sites More sharing options...
fuyshe Posted December 11, 2020 Author Report Share Posted December 11, 2020 2 hours ago, patason said: Sinevoice servis u Zemunu. Odnesi ta dva drajvera i bice ti to sredjeno mnogo povoljnije a bice kao fabricki. Hvala na pomoci. Quote Link to comment Share on other sites More sharing options...
sondek Posted December 11, 2020 Report Share Posted December 11, 2020 To ti je odlican predlog.Vrstan strucnjak. Quote Link to comment Share on other sites More sharing options...
sondek Posted December 11, 2020 Report Share Posted December 11, 2020 3 sati ranije, fuyshe said: Hvala za link! Ja i dalje trazim po netu ove originalne ali sve ide ka tome da cu u buducnosti da uzmem ove danske u paru, kostaju 300e par. Je si li kontaktirao tog tipa sto je ponudio te tvoje navodno nekoriscene?Registrovan sam na tom forumu pa mogu proveriti li potraziti ih tamo.Imaju oni Classifieds,ali ne mozes postaviti tamo oglas bez 50 postova.Ja bih to odneo Sinisi u Sinevoice,i to oba zvucnika.Ali ako nesto zatreba sa Pfm samo reci. Quote Link to comment Share on other sites More sharing options...
Nixie Posted December 11, 2020 Report Share Posted December 11, 2020 Kakva je skretnica u tim zvučnicima zna li ko? Ako ima bipolarni elektrolit ispred visokotonca možda je tu problem? Da li je urađen test međusobne zamene visokotonaca i šta se dešava? Quote Link to comment Share on other sites More sharing options...
fuyshe Posted December 11, 2020 Author Report Share Posted December 11, 2020 Prije svega, da zahvalim svima na forumu oko angažovanja i savjeta, prijatno sam iznenađen što postoje ljudi koji su spremni da pomognu. Poslao sam poruku liku na Pfm forum, mozda odgovori. Kontaktirao sam Sinišu, njegov je predlog da pošaljem zvučnike, a ako ne mogu, onda tvitere. Nešto od toga ću da uradim, mozda ne uspijem da transportujem zvučnike iz Podgorice a znam da bi tako bilo najbolje. Nisam rotirao tvitere, oni su zaliveni nekim silikonom a ja nisam stručnjak niti ih ima đe živim. Što se tiče skretnica, rečeno mi je i njih da slikam (moram da provalim što je to i kako uopšte da dođem do njih). Zvučnici inače imaju prelijep zvuk, uz ovu manu oko koje se sve vrti. Uzeo sam ih za kućno slušanje, imam skromne ostale komponente, koje ću vremenom da zamijenim. Zakacio bih slike nego su preteske, mozda ih okacim na neki sajt. Quote Link to comment Share on other sites More sharing options...
Zexx Posted December 11, 2020 Report Share Posted December 11, 2020 1 sat ranije, Nixie said: Kakva je skretnica u tim zvučnicima zna li ko? Ako ima bipolarni elektrolit ispred visokotonca možda je tu problem? Da li je urađen test međusobne zamene visokotonaca i šta se dešava? Nema elektrolit na visokotoncu: Quote Link to comment Share on other sites More sharing options...
Nixie Posted December 11, 2020 Report Share Posted December 11, 2020 Samo na midbasovima ima elektrolit, onda nema šta, visokotonce u servis a taj jedan elektrolit zameniti. Jedino što je čovek u Podgorici, malo je komplikovanije. I treba mu neko ko se pomalo razume u problematiku da se ne ošteti nešto pri rasklapanju. Quote Link to comment Share on other sites More sharing options...
fuyshe Posted December 11, 2020 Author Report Share Posted December 11, 2020 Javiću što uradim, pozdrav. Quote Link to comment Share on other sites More sharing options...
